81 - 100 of 175 Posts
Discussion starter · #81 ·
THE 6TH FELLOWSHIP ARE INBOUND!
With the main Thousand Sons force complete it’s time to expand and begin work on their allies first up is the Legio Cybernetica robots employed by the Legion’s 6th Fellowship and Pyrae temple. When the robots were described in the book strangely the way I pictured them was the old space crusade dreads so what better model to convert my basic dreadnoughts than a pair I got for cheap of eBay.
The plan is to replace the cylinders with two pairs of sentinel Autocannons and mount the ammo drum on the side, I had to replace the feet for purposes of basing so I’ll be adding some armour plates above the feet to cover the blank area where they slotted into the original feet and base. Again anyone have any spare autocannons please PM me.
For the smaller robots that will act as my Paladins or replace the terminators at GW events, I’ll be using a conversion from a previous army project but with imperial weaponry. I thought it best to try and increase their height using a part from a Necron destroyer but I’m worried it may look a bit thin round the waist? I’d likely be creating another mask design for these guys and it allows more posing options instead of having them all looking forward.
Here are my ideas regarding the weapons…
Storm Bolters; I’ll convert those the same way I did the gauss weapons only with GK storm bolters.
Psycannons; 1 large cannon like weapon.
Hammer; Powerfists
Sword; I was thinking converting a blade & shield gauntlet like ones from the golden army from Hellboy 2.
Halberd; creating an air powered ram like the librarian dreads from the GKT special weapon arm might work.
The robot conversion from my old renegade machine cult army.
In the book they are described as coloured in blue and gold, at first I was tempted to paint them the same metallic metal as my former machine cult robots but metallics are very flat unless you have at least 3 different shades to paint with. So I plan to paint them up in the same blue as the chaos thousands sons in a horrific parody of what most of the legion would later become.
Anyway I'm eager to hear any feedback regarding these conversion concepts, especially the dread?
Very cool, looking forward to seeing these complete!
Everything new that you post up just amazes me. The creativity and love you are putting into this project is truly inspiring man. Can't wait for your next post.
Loving what you've done with this army... you almost have me wanting to do something similar myself if I could get one tenth of the result.
I can't wait to see what you come up with next!
Also where did you find the scarabs?
Discussion starter · #85 ·
KHALOPHIS’ HEAVY HITTERS
I decided to give up on trying to find 8 sentinel Autocannons and used the ones from the heavy weapon team instead, only this time I didn’t shorten the barrels as I wanted to make the robot look designed for long range support. I then used Ravenwing assault cannon parts to attach them to the main body. Other details include the armoured plates from the Furioso dread to cover the blank parts on the legs and grey knight apothecary bits for the scanner and searchlight.
I’ve played a lot of RTS games and the concept was based off the usual cumbersome heavy walkers so I’m pleased in how it’s come out. Now I’m just worried about painting it, the problem being that some of the old dread’s details are very faint so I‘ll only really have one shot. I just wish I had one used or unwanted crusade dread to try out different shades on first!
Aome stunning work throughout the thread Grots! Well impressed!
A brilliant use of the old SC dreads too! If you need a test dread I have one here I can post to you? It'll only get ebayed, so if you want it I'll post it down to you for nowt. Be good to see how they turn out, and a test run can only improve the finished dreads! :)
The stunning and spectacular work continues. As for gw. What a bunch of wankers. I am glad we don't have gw sanctioned comps where i am. I like the work you are doing with the space crusade robots and the epic knights. More rep if i can. Outstanding.
Truly fantastic work mate, great conversions and attention to detail really gives the army a personal feel, will keep watching this with interest.
Discussion starter · #91 ·
THE CATAPHRACTS OF THE 7TH
I’ve always loved robots and whilst my previous attempt to create an army of them failed I couldn’t help but want to include a unit of Khalophis’ Cataphract robots from the novel in my army.
I guess I’ll start with the main body; the first thing I did was add a joint between the epic knight titan torso and Stealthsuit legs to increase it’s height using a part of a Necron destroyer’s spine. I reused the head design from my old project using a Cadian helmet and pulse rifle tip as it adds more posing options and makes it look even less human.
The Storm bolter is the from the grey knight terminators, the original plan was to place a chapterhouse combi weapon underneath but I instead went with a grenade launcher, I also added the smaller Necron spine bit to allow me the option to rotate the weapon.
I refused to have the robot holding anything as it should be built in so I converted the sword from a lightning claw based off the golden soldier’s blades from Hellboy 2. I did cut a triangle shape from plasticard but then lost it, luckily I found a much better solution by sticking together a pair of Falchions. Lastly I added the shield to look a power generator for the weapon and a defensive shield for parrying.
One final addition to the model was the 2nd weapon as most robots I’ve seen in the art books have a shoulder mounted weapon so I added one just for show, I’m also thinking of making a few with the weapon on standby (bottom right of the image).
The model will be painted using regal blue and gold as stated in the novel like the current (traitor) thousand sons.
OLD HOBBIES DIE HARD!
Whilst I said this would be my last army I’m tempted to expand the 10 Cataphract robots and 2 dreads into a full automaton force of their own after the spire guard are completed! I’m thinking of using a Space Wolf Loganwing list mainly due to the fact the robots can have their shoulder mounted represent their 2nd combi weapon and have acute senses. I’d probably convert Captain Khalophis from Marcus Calgar to represent logan. I might even include some thousand sons squads for objective grabbers or devastator support but the focus will be on the bots.
So what do you think to the robot and the idea of a army of them after the spire guard are completed?
Discussion starter · #92 ·
COMMANDER OF THE PYRAE!
Since Mini Magnus didn’t turn out as well as I had hoped he’ll now represent Draigo. So for my grand master I’ll instead field this converted Pyrae Force Commander , I love those pyrokinetics so of course he’d have a flaming sword to count as both his nemesis weapon and incinerator for when he swings it in a wide arc at the enemy.
If the flaming sword weren’t enough of a challenge I’m going to try and paint the robes white with perhaps either red flames on the bottom or gold symbols round the edges? Anyway it will have to wait till after the robots are painted.
I have no idea why there hasn't been any comments, I think of all the pre heresy armies i have seen your is the closest to what i have imagined. I also love the empty scarab for his sword on his belt :)
I really need to read the thousand sons book now though.
As for your love of the bots you can honestly do as you please but how individual would a squad of bots be compared to a squad of marines? :)
Discussion starter · #100 ·
CONQUEROR ONLINE!
Gotta say these old models do take a long time to paint, credit to the golden daemon winners who won with old models back in the day.
I’m very pleased with how the model came out using the chaos thousand sons paint scheme as described in the novel as a vivid blue and gold, halfway through painting the model I decided to paint the upper half gold, which makes it look less like an ultramarine robot and more a thousand sons‘.
I was a bit worried about the blue and red clashing but I feel the gold ties the robots and thousand sons together really well.
I’m eager to hear your thoughts on the choice in colours?
