Gene-seed Failure Rates
4.2K views 5 replies 4 participants last post by  Rems
#1 ·
Does anyone have any idea about the failure rate for the Space Marine gene-seed implantation process? Despite the rigorous screening that aspirants go through to check genetic compatibility, some of them must fail. For example, Lexicanum says that for the Blood Angels' recruits, a good portion of them die during the process, and others go insane. So do other chapters have similar failure rates?
On a related note...for the Blood Angels, isn't this an exorbitant waste of gene-seed? Of the 50 aspirants that are chosen, only a few survive to become Space Marines. Does this mean for every two failed aspirants, one full SM essentially died in vain? 0_o
Discussion starter · #4 · (Edited)
Thanks for the responses. So in general, failure rates should be extremely low, given the screening aspirants go through.
However, if the implants begin being added, and they fail, it essentially means that a full set is wasted, yes? The implantation process takes years, and if the process fails at any point, it's not like they can just give the remainder to another recruit.
I know progenoids are the last to be implanted, but I'm assuming they won't work unless the process in general is successful.
So in the Blood Angels example above, two full sets of organs are harvested from a dead Marine's progenoids. They are implanted into aspirants, many of whom don't survive the process. Regardless of the stage at which they fail, the un-implanted progenoids (proto-progenoids?) can't be saved for anyone else, since each potential marine's body can only support two, yes? Same for any other organs that have yet to be implanted, so a begun-but-failed transformation is essentially a waste of half a Marine's contributions to the chapter.
