101 - 120 of 186 Posts
Discussion Starter #101
Here is a closer look are the Area 51 gaming board currently on the Maze of the dead kickstarter.
www.kickstarter.com/…/maze-of-the-dead-by-wargame-model-mods - private.
This is a 4x4 foot gaming board using 16 tiles 40 corners and 96 wall sections. you can select this exact set up on the kickstarter, it is the 4x4 Dungeon board.
The theme is that of a human outpost with Gothic style walls, although you can choose to use different walls with these tiles if another set takes your fancy.
There are 6 other designs as well on this project, numerous stretch goals and 8 add-ons.
i would love to hear feedback and suggestions.
Discussion Starter #102 (Edited)
Wargame-model-mods Maze of the dead Kickstarter - stretch goal 8 unlocked 14 revealed
Stretch goal 8 has been unlocked and number 14 revealed.
These stretch goals can be pledged for on there own and would be great to add details to your existing buildings at an amazing kickstarter price
use the "Building themes" pledge to get these or any other unlocked theme package.
Goal 8 is for the first of the themed sets this one is Sensors.
It Contains 6 consoles, 16 mini displays, 6 mini cameras and 12 sensors.
Stretch goal 14 is the brilliant mechanics room.
Featuring a bunch of damaged vehicles, drones and turrets and all the equipment to fix them.
it contains two drone docks and damaged drones, two jacks and mini vehicles, 2 work tables, 2 damaged turret parts, and a bunch of tools, bits and bobs and various parts.
https://www.kickstarter.com/projects/wargame-model-mods/maze-of-the-dead-by-wargame-model-mods
Maze of the dead
Discussion Starter #103
Stretch goal 9 has been reached today and 15 added.
I am also working on some new Add-ons and a new boards design and i still have plenty more stretch goals to add
9. Crates and boxes.
Add £10 to pledge.
Contains 27 various drums, crates and boxes.
15. Control room.
Unlocks at £11250
Add £10.
Contains 4 control terminals, four doors, two tables and two weapons locker + a bunch of weapons.
Discussion Starter #104
With so many different themed boards to choose from here is a look at the chaotic compound.
This ones theme revolves around the demonic and possessed featuring satanic symbols. The tiles have a good amount of detail cut out to allow plenty of light to shine through and really light up the symbols.
This is one of seven current board themes.
Discussion Starter #105
New stretch goal unlocked and another added.
This weekend i will be adding another wave of add-ons and a brand new board style these will not need unlocking.
10. Armoury.
unlocked
Add £10 to pledge.
Contains 6 gun racks, 2 turrets, 5 ammo crates and 6 missile pallets.
16. Test Facility.
Unlocks at £11500.
Add £10.
Contains a test firing range with targets, turrets and guns, propulsion experiment, a radiation station and a desk with bits and bobs.
Discussion Starter #106
Today stretch goal 11 was unlocked and 17 added
you can check out many more pictures on my website below
Maze of the dead
we are approaching £10,000 only £450 to go, the next freebie will be unlocked when we get there, its going to be a useful one for anyone regardless of your pledge.
keep an eye out this weekend for new add-ons and a brand new style of tiles and walls
11. Science lab.
unlocked
Add £10 to pledge.
Contains 27 science themed items.
17. Generators.
Add £10.
Contains 4 generators
Discussion Starter #107 (Edited)
Some more examples of how you can set up the gaming boards on my kickstarter. There a loads and loads of ways you can use them and every time you play you can be using a new layout.
We have a first look at a city board set up on a 4x4 board using buildings from my website and another one using both buildings and walls.
A space hulk style set up with boarding action between two ships alternately it could be two parts of the same base with one half captured by the enemy. This uses a few of the add-ons, the corridors and small stairs. This weekend airlocks will be added as an add-on which would add to this style of set up.
and finally a set up leaving a void in the center of the setup for buildings or use as a large open area, this area could even be a no go area making for a large board spread out in an odd shape.
The boards seen here are the Area 51 and Chaotic compound and the walls on the Area 51(blue) tiles are the Cyberspace corridors and on the Chaotic compound(red) tiles are the tech crypt walls. You can mix and max your tiles and floors to get setups like this or get an entire board of just one theme.
More information can be found here.
https://www.kickstarter.com/…/maze-of-the-dead-by-wargame-m… - private
And you can find a huge amount of pictures on my website many of which are not on kickstarter. you can have a closer look at the tiles, walls and all the stretch goals.
Maze of the dead - private
Please share this around in your groups and to anyone you think may like it, this kickstarter give you the opportunity to grab these at amazing discounts.
Freebie number 2
Storage boxes
These will store 8 tiles or a large amount for walls + corners.
Area 51, Chaotic compound, Tech crypts and Labyrinth walls.
20 corners and 54 wall sections in two layers.
Cyberspace corridor and mechanical construct walls.
22 corners and 42 wall sections in three layers, two of these layers need to be laid on their sides.
Nuclear vault walls.
18 corners and 42 wall sections in three layers, two of these layers need to be laid on their sides.
Reaching £10,000 gives one of these free to everyone who has pledged for 8 or more tiles. For those with only 4 tile pledges the box would be too big, for these pledges you will get a half size box that will hold 4 tiles.
Extra boxes can be purchased for £6 each half size boxes are £4 each.
12. Premium board 2 Mechanical construct unlocked.
This set is themed around a mechanical cog design. The boards come with 16 cog designs that glue on the underside of the base, each cog section is individually lit and can use the standard Red, blue and green lights or Multi colour lights. (please note the colours on each set of the multi colour lights are not always the same) by having two lights in one section you can mix the colours to get even more. Multi colour lights are currently not available for the other boards as they are a different type of kit.
unlocked.
add 5% to the initial pledge, no additional post charges.
18. Wall Breacher
Unlocks at £12250.
Add £10. Extra breached walls £2 each.
Contains 1 breaching unit and one breached wall of your choice, there is one for each style.
Discussion Starter #108
Today stretch goal 13 has been unlock and 19 added, we also have 5 new add-ons as well
Corner ramps.
2 in a set.
£5 per set.
These ramps can be added in the corners to join two large ramps.
Hanger door.
£5 each.
Covers 1x4squares.
A large 4 square long door great for hangers, vehicle bays and access for larger models.
Airlock set.
2 small 1 large and two control pannels
£7 per set.
A set of airlocks, great for simulating ships or for outposts on hospitable planets.
Tile height block.
£5 each.
2 for £8.
These can be used underneath your tiles to increase the height of them.
They stack and also use the clip system to join them together.
Plinth.
£5 for 1 set.
Designed to allow you to use buildings next to the tiles.
A set contains 4 corners 4 small lengths and 8 long lengths.
It can be built to any size between 10x10cm up to 35x35cm in 1 cm increments.
13. Troop platform.
Unlocked
Add £12 to pledge.
Covers 3x3 squares, and can be placed next to walls.
Versions for each style view them all below.
Stretch goals 13
19. Fighter Bay
Unlocks at £12750.
Add £12. Extra fighters can be bought for £6 each
Contains 1 Fighter, Transport vehicle and bed, cargo pods and missiles racks
Discussion Starter #109
This is the brand new Shambolic Compound added to the Maze of the dead kickstarter currently running. The set features a very ramshackle theme. With the walls and tiles covered in patch jobs, holes and plates. This set does not need unlocking and can be chosen straight away. It costs the same as the other 5 standard boards.
Kickstarter page here
Discussion Starter #110
Three stretch goals unlocked today see below
14. Mechanics.
Unlocked
Add £10.
It contains two drone docks and damaged drones, two jacks and mini vehicles, 2 work tables, 2 damaged turret parts, and a bunch of tools, bits and bobs and various parts .
15. Control room.
Unlocked
Add £10.
16. Test Facility.
Unlocked
Add £10.
Two new stretch goals added today.
20. Barracks.
Unlocks at £13350.
Add £10.
Contains 30 pieces of barracks furniture such as beds lockers and showers
21. Med Bay.
Unlocks at £13750.
Add £15.
Contains one cryo pod, 2 surgery beds, 2 cat scanners, 6 patient beds, and desks + chairs.
The Cryo pod opens and closes and can hold one small model on a 25mm base.
Discussion Starter #111 (Edited)
Competition. Win some Maze of the dead tiles from the kickstarter.
The Maze of the dead kickstarter has a pile of amazing stretch goals you can see all of the current ones in the photos below. All of these can be pledged individually without the need for getting any of the actual maze of the dead sets, they are very cheap ranging from £5 to £15.
They range from gun turrets, drones, all the way up to Entire room sets such as a mechanics, science labs and testing facilities.
These have a much faster fulfillment date as I do not need to wait for magnets or light kits to be manufactured. They are also currently priced at very good rates and will increase once released on general sale after all pledges are fulfilled.
Use pledge number 6 to get these. Titled "Stretch goal backer"
Anyone who pledges for a set of these will be entered into a draw to win a 2x2 Gaming board of your choice and lighting of your choice. One entry per kit pledged for. The competition is open worldwide, a non PO box address is required. Funds must clear to be eligible. The winner(s) will be announced on the kickstarter page after the campaign has finished.
Share the word, if we reach 50 entries to this competition a second 2x2 Gaming board will also be available to win.
These sets can add some amazing details to your existing buildings and terrain.
There is also an entire section on my website with a huge amount of pictures of all these sets.
Stretch goals - private
Discussion Starter #112 (Edited)
Full product review by The Dark Artisan of the Maze of the dead kickstarter currently running.
Wargaming tiles with integrated lighting. For use as game boards or with corridors as dungeon crawl style gaming tables for 28mm games.
Any comments, thoughts or suggestions are welcome let me know.
Review is up on youtube
Kickstarter page below.
Check his channel out drop him a like and sub.
https://www.youtube.com/channel/UClbmK5kNUd2-bzH9fjlFgpA
Discussion Starter #113
Brand new board design perfect for Mordheim, Warhammer age of sigmar and other 28mm fantasy wargames. This has been added to the Maze of the dead kickstarter that finishes on the 1st Aug.
Based on Tudor style walls with Brick/cobbled tiles.
Plain walls with wooden slats that give a huge deal of choice of where and how you place the slats. Several types of wall design are included for each size, some have door, some have large gateways other are just walls or feature windows.
This set works great with the labyrinth theme set to create a city of mixed wood and stone buildings
The set has x corners for joining in each direction and L shape corners which only join two walls
Unlocked stretch goals
20. Barracks.
Unlocked
Add £10.
Retail price £12.50
21. Med Bay.
Unlocked
Add £15.
Retail price £17
22. Engine room
unlocked
Add £15.
Contains one engine, walkway and tubes to build it.
Retail price £16.50
23. Torpedo bays.
unlocked
Add £10.
Contains two torpedo tubes and wall section.
Retail price £12.50
New stretch goal
25. Portal
Unlocks at £16000.
Add £10.
Red, blue, green or colour change light.
Perfect for an entrance/exit onto or off a board or use two to get from once to the other quickly.
Retail price £12.50
last bunch of new addons have arrived
Cyro pod
£5 each
One small cyro pod, can open and
close and will hold one small
Small bridge
£5 each
Fits accoss tiles and troop platforms
Large bridge
£7 each
Book shelve
2 in a set
£6 per set
Covers 1x2 squares each
Wall height block
£6 each
Raises the height of one tile so it is
equal in height to walls on top
of another tile
Battle report by The dark artisan, featuring the Maze of the dead currently on kickstarter.
Grey Knights Vs Khorne Daemonkin
Discussion Starter #114 (Edited)
Having reached £15,000 everybody gets another freebie.
1 for pledges up to an including 8 boards and 2 for pledges of 9 or more boards.
You can also purchase these in sets of 2 for £10.
They cover an entire square on a tile and can be used as corners or 1x1 walls.
Supplied with 2xCR2032 each.
Choose from Red, Blue, Green or colour change.
Undercity hab unit.
£10 each.
Seats a tile on top and
is the same height as walls.
8 doorways to enter and
includes doors to seal them off
Reach them with the large steps or
wall height ramp.
Wall height ramp.
£6 each.
Ramp that reaches up to the
top of a wall or a tile on the
undercity hab unit or wall
height block.
26.Dynamo
Unlocks at £16500.
Add £10.
Red, blue, green or colour change lights.
Retail price £12.5
New stretch goals
27. Fantasy Props.
Unlocks at £18000.
Add £10.
Contains various fantasy style street props.
Retail Price £12.50
28. Force field
Unlocks at £19000.
Add £10.
Contains two small and one large force field
Red, Yellow, Blue or clear plastic.
Retail price £12.50
Discussion Starter #115
Final couple of days to grab yourself a Maze of the dead board at these prices. There will be no pledge manager so if you want to get in you need to do it during the kickstarter. They will go on general sale after every pledge has been fulfilled.
Please share this post in your gaming groups/clubs and to anyone who may be interested in this as time is running out.
If you are after one of these but do not want the lights or magnets you can choose not to have them.
There are a huge range of add-ons and stretch goals to add a lot of depth and new play style to these boards.
So far there are also several freebies, including Doors, connectors for the boards, a storage box and a small light up add-on called the relay.
They can be setup for a Huge variety of games such as Warhammer 40k/30k, Infinity, Mordhiem, Space hulk, Zone Mortalis, Dungeon crawls and any other 28mm games.
You can get just the tiles, the tiles and walls or the tiles and a selection of my buildings.
The pictures show a variety of the different boards and stretch goals, there are several other boards and a huge amount of stretch goals and add-ons to be seen on the kickstarter page.
Discussion Starter #116
The final stretch goal has been added and unlocked. That's it nothing else to be added now.
Thank you all for an amazing project with many of the add-ons and new stretch goals fueled by your suggestions and ideas.
If you have a minute please share the project on Facebook and twitter etc.
29. Distress beacons
Unlocked
These would make great objectives and could represent many different objects such as distress beacons, shields, transmitters etc
£5 each or 6 for £20
Red, Green, Blue or colour changing
Discussion Starter #117
After a great month with loads of suggestions and feedback from wargamers from all over the world the kickstarter comes to an end tonight at 7.00pm GMT
There will not be a pledge manager so get your pledge in if you would like to grab yourself a set.
There are various themes for scifi and fantasy games.
You can opt of of the lights and magnets if you don’t fancy them.
The project has unlocked all of the stretch goals and a bunch of add-ons are available.
Also several freebies have been unlocked during the project.
Discussion Starter #118
My website and eBay at open as normal after the Kickstarter for the maze of the dead.
Currently there is a sale on a few building on the website, 10% off a selection of items
Wargame-Model-Mods
wargame-model-mods on eBay
