81 - 100 of 186 Posts
Discussion Starter #82
Large Dome shield generator featuring a large energy ball in the centre.
This comes with white LEDs only.
Choice of plastic Red, Blue or Yellow. Measures 220 x 200 x 250mm.
Discussion Starter #84
21st stretch goal - locked
Modular stackable hab units, with Perspex windows and a huge array of detail.
Measures 100 x 95 x 50mm
22nd stretch goal - locked
Modular stackable hab units, with Perspex windows and a huge array of detail. This is a double size unit
23rd Stretch goal - locked
Large hab unit, it can have the smaller units stacked on the centre and they will tessellate around the outside. Single hab unit will fit around the tower, but stand proud by 1mm around the edges.
corridors to come early next weeks
Discussion Starter #85
The lunar outposts come with doors and some of the windows are optional, they can be solid panels or window panels. The buildings are pretty quick and simple to make and look great. There is a larger version to come and a few extras for them.
The temporal distortion field has a rotating section that spins around the central plasma ball.
The rotating arms are mounted on two metal ball bearings and powered directly from the motor rotating about once a second.
The building is pretty compact and has the motor and batteries in the top and the whole plasma ball can be removed to allow easier battery change.
Measures 215 x 180 x 205mm.
Requires 2 x aa batteries and 4xaaa batteries.
Discussion Starter #86
Down to the last 24hours
final add-on. A set of wide corridors for the lunar out post buildings, three in a set a small airlock and a 75mm corridor and 150mm corridor. They can fit straight up against your buildings or have an airlock bulkhead on the side facing out.
Final stretch goal has been unlock at £23000.
This is the tower to fit on the skypad. It comes with ladders, various detail panels such as fans and grills and 4 barricades high enough to block line of site.
If you have the skypad pledge add £12 for the tower. If you would like both add £29.
I have been asked by a fair few people about a pledge manager. I will not be using one.
This means if there is items you would like on here you need to pledge for them before the time runs out. you will not be able to add after the kickstarter is over.
Regarding post cost, please make sure you have added the charge quoted by kickstarter when pledging or altering a pledge.
If you want to run your pledge past me to check it’s correct please do so.
A massive lunar outpost building, featuring plastic windows, doors and optional wall panels, you can choose between having some of them windows or solid panel.
Roof is removable to allow access to inside, this building features a lot of etching work.
Measures 300 x 225 x 135mm
Similar to the above building this is the Quad version and it is huge, featuring plastic windows, doors and optional wall panels, you can choose between having some of them windows or solid panel.
Measures 300 x 300 x 135mm
A set of four solar panels that fit nicely onto the lunar outpost buildings, they fit on any of the base walls and the large roof panels, it the actual solar panel can be positioned at 0, 22.5 or 45 degrees.
2 corridors and a mini airlock, corridors are 75 and 150mm long and 45mm wide, perfect for joining the separate building together and providing extra cover. Roofs are removable.
The temporal distortion field now includes a set of steps, it was added to some spare space that would of gone to waste.
Discussion Starter #87
The Kickstarter was a great success and i managed to turn it around pretty quick.
since then there hasn’t been too much new stuff as it took me a while to get it all in stock and set up for sale on eBay etc.
A new version of my draws, extra deep so you can store larger items in them.
the standard paint racks fit on top as normal
available from the 6th of April along with some more new items I will show soon
Discussion Starter #88 (Edited)
New version of my paint racks to support the Tamiya color paint range and other ranges with large pots up to 37mm in diameter
Holds 36 pots and up to 12 brushes.
Measures 420 x 160mm x 65mm.
It will be available on its own or with either set of my draws from Wednesday
Another new version of my paint rack to support Revell Aqua Color.
it holds 40 Paints and 9 brushes
Measures 420 x 160m x 54mm
This is the laser fence set
4 long, 4 shot, 4 corners and 2 gates make up this great set.
its fits in perfectly with the other fence systems.
The lasers are made from Perspex with the choice of three colors red, blue and yellow.
long panels are 304mm short are 152 and the corners are 86x86mm
The design for this kit was done by john Morrison
Discussion Starter #89
Painted Ingot Factory
This is my ingot factory, it has been painted by Dan Taylor and he has done an amazing job. It has been painted as i imagined the building when i designed it a year ago. The molten metal stored in the Center of the building and slowly making its way down to the ingot molds.
The rest of the building features numerous industrial themed details. Along the walls we have air vents to feed the internal furnace to keep all the metal molten and heat extractors to take away excess heat
At the front of the control tower we have some pipes supplying fuel to heat the metal. (These are included in the kit)
Dimensions are
wide 250mm
depth 290mm
height 106mm
Discussion Starter #90
An example of the Tool Factory painted. It has been painted by The Goldfish of Justice.
The building is packed with details and interesting parts.
The entire building is surrounded by a conveyor belt, this belt is raised up on small wheels and a network of detailed supports.
On the belt are a series of tool molds, that are filled with the metal to make the tools, we can see this represented with the how the model has been painted
Discussion Starter #91
The launch of a new kickstarter by wargame-model-mods is today
Wargaming tiles with integrated lighting. For use as game boards or with corridors as dungeon style gaming tables for 28mm games
The Maze of the Dead is a fully customisable dungeon style gaming board which allows you to place walls in a totally different configuration every time you play.
check it out here
https://www.kickstarter.com/projects/wargame-model-mods/2006688734?token=aff06d73
This really looks stellar, you've done some real great work here! Absolutely love the magnets everywhere. I checked out the link but there's no real mention of them, do you just make the holes for them and leave the rest up to us?
Discussion Starter #93
hello yes the boards have 36 holes for magnets and the base of every wall/corner has a hole/s for magnets and then you just glue them in. each hole comes with a small square to stick over the back so you have something to press the magnets against
Discussion Starter #95
After a great first day 4 stretch goals are now unlocked.
1. Mini Defense turrets pack 1
Add £5 to pledge
2. Mini Defense turrets pack 2
Add £5 to pledge
3. Mini vehicle variant pack 1
Add £10 to pledge
4. Mini vehicle variant pack 2
Add £10 to pledge
i have added four new stretch goals
7. Defence drones
8. Sensors, consoles and displays
9. crates and boxes
10. Armory
https://www.kickstarter.com/projects/wargame-model-mods/maze-of-the-dead-by-wargame-model-mods
Discussion Starter #96 (Edited)
The 5th stretch goal was unlocked yesterday meaning the first freebies have been unlocked.
This means anyone who has a pledge between 1 and 8 boards gets 2 free small doors and anyone who has pledged for over 8 boards get 4 free small doors.
it also opens up the doors for sale, a set of 2 small doors and 1 large door are now available at £5 per set
also today is the addition of the 11th stretch goal
11. Science lab
unlocks at £11000
Add £10 to pledge
Contains 27 science themed items
Discussion Starter #97
Building theme pledge
now added
Are you just looking at the room themes that are part of stretch goals, if so. You can use the special pledge to back and get just these as rewards.
They would be great to spruce up your existing buildings, by adding extra details or internal themes to them
Here are a few examples of the reveled ones there are many more to come
Discussion Starter #98 (Edited)
The 7th stretch goal has been unlocked
7. Defence drones
unlocked
Add £12 to pledge
contains 2 small and 2 large drones
13. Troop platform
unlocks at £12500
Add £12 to pledge
Covers 3x3 squares, and can be placed next to walls
Versions for each style view them all below
Stretch goals 13
I am also working on some add-ons that will be added shortly, these are things such as ramps, stairs, and some other bits and bobs
Discussion Starter #99
Hello everyone
The first batch of changes are here from the feedback and suggestions.
There are two minor changes to the tiles.
The first one is the ability to add wiring under the boards for those of you who want to connect all the lights to a mains power supply.
The addition of two squares on each side of the tiles that are held in place with tabs allow you to do this, and means those of you who do not want to do this can leave them in place.
For those wanting to add wiring, you would simply cut the tabs and clean up the hole with a file or scalpel you can then fit wires up to 4mm under the tiles.
The second change relates to the second shape seen in the above pictures, again it is optional. By removing this section you can now fit in a small connector sections to hold your separate tiles together
Connectors in place, at the end of each connector are some rounded bumps which slot into the underside of the tiles, the round shape help them find the locators on the tiles and slot quickly into place.
The connectors allow for a slight amount of give for ease of set up but will prevent you from knocking your tiles apart
Above one of the connectors below slotting a second tile onto connectors
Below are pictures of the tiles upside down, you can see the square cut out for wire to pass through and the slots for the connectors and in the second picture are the connectors in place.
I will be providing two free connectors for each board you have pledged for.
Finally i have been asked a couple of time how the lights fit in place, here is a picture of an internal part inside the tiles, the wire slots into the cut outs with the LED sitting on the protruding piece of wood in the middle.
Tomorrow i will be adding the first sets of add-ons these are all inspired by suggestions and ideas from my backers, if you have any thing you would like to see please suggest it.
There will be 8 coming tomorrow, most of them relating to access such as ramps and stairs. None of them will need unlocking and they will all be cheap around the £5 mark per set / item
Discussion Starter #100 (Edited)
wargame-model-mods - maze of the dead kickstarter addons
Here are the first 8 add-ons, these are all responses to ideas and feedback so if you have any suggestions please let me know.
http://www.kickstarter.com/projects/wargame-model-mods/maze-of-the-dead-by-wargame-model-mods
https://www.facebook.com/wargamemodelmods
Maze of the dead
Small ramps
2 in a set
£5 per set
Covers 1x4 squares
These ramps allow for travel on and off
tiles and to stack your tiles
Small Stairs
3 in a set
£5 per set
Covers 1x2 squares
Similar to the ramps these steps
allow you to on and off the tiles as well
Corridors
2 in a set
£5 per set
Covers 1x6 squares
Two corridors which allow travel
between tiles, they can be place end
on end or next to each other
Large Ramp
1 in a set
£6 per set
Covers 4x6 squares
These large ramps allow for travel on
and off tiles and to stack your tiles
Barricades
5 in a set
£5 per set
A set of the large and 2 small
barricades
Troop nest
2 in a set
£5 per set
Covers 1x2 squares each
Two troop nests to add defensive
areas
Large steps
2 in a set
£5 per set
Covers 1x3 squares
These large steps allow access to
the top of the walls
There are 5 sets of these walkways.
Set One 3 single walkways, 2 double walkways, 1 triple walkway and 2 entrances
Set Two 1 triple walkway and 2 quad walkways
Set Three, 1 corner, 1 T junction and Crossroads
Set Four, 1 Bridge section and 2 End sections
set Five, 4 end sections
These sets are £5 each or 4 for £15
