Tank compressor question
1 reading
1.2K views 11 replies 3 participants last post by  falcoso
#1 ·
So since my compressor broke and sending to the states to get repaired was too much, I decided to just buy a new compressor. My new one has a tank 3L tank and I have a few questions about it:
1. How long should it take for the tank to fill? I seem to be waiting a minute or two for the compressor to shut off and I have checked for leaks but it is fine. Is this normal?
2. I there a way to stop the air getting out the tank when the airbrush is disconnected? I have to do this when I clean it out and change colors and it just seems a waste of electricity, especially when compressor can get hot when they are pumping for a long time.
Thanks
#3 ·
Any compressor that has a tank, will always take atleast a min to fill up, so that is normal. Compressor tanks also have regulators so if they, for some reason, overfill then it'll release some air (IE pressure). A quick disconnect will help when working on your brush.
#4 ·
What is a quick disconnect? Is it something that goes on the hose that stops air escaping when you remove the airbrush?
Thanks for your help
#5 ·
It's a connector that has two parts. A female that goes on the hose and a male that goes on the airbrush. When you disconnect the airbrush by the slip sleeve it makes it where the airflow stops. Great if you need to disconnect often or switch airbrushes.
#7 ·
Ah great, I shall have to get one of those then, it will probably stop my compressor getting so hot too!
#8 ·
So another thing I have noticed is that the compressor is getting very hot (as in can only hold my hand against it for a few seconds) after about 45 minutes of work, is this normal? And what happens if the compressor overheats?
#10 ·
Ok, so it's not something I need to overly worry about then until it shuts off?
#11 ·
You still need to keep an eye on it. Especially if you notice that it's NOT shutting off when it gets really really hot. Also, because it's hot, you need to watch whats around it or what it's on. Even dust piled up on top of it can start a fire. But that being said, you don't overly have to worry about it. It's a machine, it's going to get hot the longer you run it.
#12 ·
Yeah generally I take a break after each colour to leave it to cool down but I may try and push on a bit longer if I can. Thanks for all your help guys
