1 - 3 of 3 Posts
Im having major issues getting the floating Slann model to stay on the thin clear, plastic flying base.
Has anyone else had this issue and does anyone have any ideas on how to make it stay in place?
Thanks
you can try drilling the hole on the underside deeper, so that it cant tip over as easily. or try to find a larger, thicker flying base and cut it down to the right hight.
Drill the mounting hole on the floating rock to 3mm (ie use a 3mm bit in a cordless drill). Drill to around 3-4mm deep.
Break off the little nubbin on top of your clear upright pole for the flying stand (use the small one).
Try them for fit. It should sit a couple of mm lower on the stand, and the weight will be supported by that much extra plastic, as opposed to the 1 cubic millimetre of plastic it had.
1 - 3 of 3 Posts
