Hi! A conundrum appeared in a lizardmen discussion... Lizardmen have a mixed unit that contains both skink (T2 W1 20mm models) and Kroxigors (T4 W3 40mm models). Now, du to rules, kroxigors must be placed on the second rank of the unit until there are less skinks in the first rank than the width of the krox in the secon rank. So, if we have a unit that has 6 skinks in the front and 2 kroxigors on the second rank and that units gets attacked in CC. The attacks are made against the skinks (in the front), but are the wounds removed on the Kroxigors (which would, then, have been wounded on T2!)?
On one hand, the rules are quite clear: casualties must be removed from the rear of the unit. On the other hand, you can only attack models with which you are in CC. PLus, you have to remove as many whole models as possible...
What do you al, think?
Phil
Phil
