1 - 6 of 6 Posts
so I posted this over in the armylist section but I didn't get many peoples help so I decided to post it over here
Hello everyone in the Fantasy section of this forum. I am in a slight problem I am buying my friends army off of him and need to figure out what units to buy next
from his army I have
1 Carnosaur with Rider (We have nicknamed it Fufy)
2 Skink Priests
40 Sauros Warriors
10 Temple Guard
20 Skinks
1 Old Blood Warrior
I am thinking about buying a Slann or two along with some Sallies maybe a Razordon? but after that I'm at a lost so here is where you guys come in
I would like you're help
in your reply post these three things
What Lore should a Slaan take? I'm thinking Lore of Light to give them that nifty little I10 W10 spell
What should be my next unit to buy (Either list the third or a replacement of the two listed)
What are some good magic items for these units? I'm new to the game so I don't know what would be good
EVERYTHING MUST HAVE REASONS
To further sweeten the pot I'll give +rep to responses that I find helpful to myself
Ok. First up, the Slann. The Slann is arguably the most powerful caster in the game. If you take the slann with the correct disciplines, he is a very powerful addition to the army. Of course, you do not want to rely on him to win the battle, but he will help. The standard lore for the Slann in 8th edition is the lore of Life. This lore allows you to ignore miscasts on a 2+ (you should also be taking Cupped Hands of the Old Ones anyway to give the first miscast you have over to your enemy-really good if you do not take life). Another good lore is Lore of Light. I used this lore this past weekend against HE, Skaven, and Goblins and Orcs. I was pleasantly suprised that it worked so well (although I did miss the buffs from Life). WS10 and I10 is a very good thing (Speed of Light I think that is). The disciplines that a slann can take range from an extra power die, etheral (immune to non magical attacks), becalming cogitation (removes all 6s from a chosen enemy caster during their magic phase--VERY good against your enemies), magic resistance, and Focus of mystery (all the spells from one lore). Top that off with 5 wounds at T4 and a 4+ ward save. Good stuff. Stick him in Temple Guard for a stubborn unit as well (really need Cupped Hands or the lore of Life for that).
Next up you need (NEED) something to go after war machines or lone characters. In 8th edition, this means Chameleons! These guys are amazing. You have an effective range of 24 inches (you can march 12 and shoot an additional 12 inches hitting and poisoning on 6s-drop that to an additional 6 inches for hitting on 5s and poisoning on 6s).
You could also use Terradons for this need to a lesser degree. The Terradons took a mild hit in 8th edition. The terradon did gain the vanguard move and the stomp attack with 8th edition. The vangaurd move will allow you to move 12 inches before any other moves are made int he 1st turn. You cannot charge if you go first (but you can charge if you go second). You can drop rocks with the terradons doing d3 STr4 hits to whatever you drop the rocks on (you cannot drop rocks on the turn that you charge). The hits that the terradon took in 8th edition are that they no longer have 360 degree sight and they cannot drop rocks on the turn that they charge. I usually put a skink chief on a terradon and give him the Fencers blades (WS10 +1 attack). It works pretty well.
Salamanders are also an absolute must now. These guys hit everything that the template touches now. I run 3 of these together and try to get a shot across my enemies flanks (or hit a horde unit). With 3 of these it is not uncommon to get 18 hits or so on an enemy. Plus, an automatic panic check for any wound taken. Make sure you take the extra handlers (snacks) though. When you misfire, your sally eats d3 skinks. Now, the skink handlers attack around the sally in close combat (all of them). That means that when the sally is in combat, you have the sally's 2 attack and 4 attacks from the back (sure it is at weapon skill 2 str 3, but it is an attack). The handlers cannot be targeted in close combat.
Another unit to consider is the Skrox unit (skink cohort-skinks with kroxigors). This unit is basically a kroxigor delivery vehicle. I usually take about 30 skinks (with full command) and maybe a character and 3 kroxigors. This unit is really good as the kroxigors cannot be targeted while there are skinks in the front rank. Plus, this unit is fast with a movement of 6. Now add in a slann with lore of life or light and you are looking at a very destructive unit.
Lastly, cold one cavalry are good in 8th. BUT! But, they have to be used in a unit of at least 10 so that they will break ranks. You almost have to hit a flank to make these guys worth it though. If you get a flank, they will be a force to be reckoned with.
Wow thank you for your response definitely worth some rep one question though
can you take skink skirmishers and make them chameleons? or do you have to buy chameleons seperate?
Models-wise, you can convert skinks, but they are separate entries in the army book.
Discussion Starter · #5 ·
thanks man
Whats with the "52e89bf2-1169-46a6-8e15-154c36d07ead"?
1 - 6 of 6 Posts
