1 - 8 of 8 Posts
Interested in upgrading your 25 mm miniatures into 32 mm? We have the perfect solution! Tabletop Adapters is a company that has used 3D technology to developed the best possible adapter. Any 25 mm miniature should be able to fit the new gaming standard, without any risk to their well being. The adapter not only increases your miniature from 25 mm to 32 mm, it also increases the height. Increasing the height enable us to match the size of new 32 mm bases. It also enables the adapter to attach firmly to the model. One problem we experienced is that without a bottum, leveling all three components neartly is actually quite hard.
To get started we need funding. For this, we have created a kickstarter. You can pledge your support and gain adapters for a nice discount! On top of this, we offer the STL file for a range of products for high pledges. Print adapters at your own will!
Pledge your support at kickstarter.
View a 3D display of the product here.
Visit our website www.ttadapters.com
I understand you are worried. Infact, the extra height is made so the miniature base will look more alike the 32 mm original. If you take 25mm and 32 mm, the 32 mm base is higher. This is what we try to replicate. In addition, the base will be easy to "slide in" and level both sides perfectly with the base.
Interesting. Could you show off a pic of your base next to a 32mm base instead of the pictured comparison with a 25mm one? I have yet to buy a new kit (though play three SM armies) and didn't even realize that there was a height difference. So far your solution has me the most interested.
nice boy, daft though !
what material will the adapters be when produced? have you any prototypes in the material you intend to produce in? and can you supply samples, i may be interested in a large order if the price is right and the product and the material is suitable.
it looks like in the pic above, the white prototype is ontop of a black 32mm base (upside down)
I've backed it, looks interesting and will work well with some of my custom bases, most of which are pinned into the feet of my models.
1 - 8 of 8 Posts
