1 - 9 of 9 Posts
Hail, heretics. As the title says, I accidentally glued several magnets in the wrong way on my latest project. Anyone have some tips for how to get them out? I tried searching for tips on the forum and couldn't find any, so I apologize if this has been addressed elsewhere. (The pieces are currently chilling in the freezer.)
If the soapy water doesn't work you can try some fingernail polish remover it will desolve the super glue making them easy to pop out then rinse in water to remove the nail polish.
this is why you should always work with two magnets stuck together so you get the positive and negative lined up correctly.
I've generally just attemoted surgical precision in making inciions around the plastic, though using nail polish remover and hot soapy water sounds like a much safer bet!
I don't know what warm soapy water would do to Industrial strength super glue (I use Loctite industrial strength super glue). I've never tried it so I wont bash it.
I usually take the smallest drill but I have and drills 3 small holes in the form of a triangle. instead of drilling straight down, drill on an angle, trying to get the drill bit underneath the magnet. This usually cracks the super glue and gets the magnet free... sometimes it works with just one drill but hole if your lucky!
1 - 9 of 9 Posts
