1 - 6 of 6 Posts
hi guys what colours should be used to paint desert terrain? Anyone with tips they would be HIGHLY appreciated
I wouldn't paint the majority of it-- just the buildings and whatnot. I'd just glue modelling sand to the board/terrain pieces. I mean, sand is sand. Can't get much more realistic than that.
True, but i think it doesn't look quite finished when you do this. I was thinking maybe if i painted the whole sanded layers in a light brown and then glued sand over it it might help?
· Porn King!!!
You're right, it doesn't. My advice:
Brown basecoat UNDER the sand
Sand
Brown Ink stain (next to no water)
Vermin Brown
50/50 Vermin/Bubonic Brown
Bubonic Brown
Add White to the Bubonic in large areas.
This will give a nice sandy appearance that is also somewhat patchy in places. Try it on a small piece first to see if you like it.
Yes, I am a huge fan of many layers. I got into this hobby first and foremost for the modelling/painting aspect (painted minis before I ever heard of GW). I just CAN'T paint a model quickly or with just 3 simple colours :D
· Banned
Go with a brown basecoat, or black spray base then a painted-on brown base. Then use a slightly lighter mix of brown fan/dry-brushed on heavily. Then again, slightly lighter.
Last, a fast drybrush of white/bleached bone.
So, base dark brown (scorched or bestial).
Thick fan/dry-brush of lighter mix of brown.
Again, even lighter over previous.
Drybrush bleached bone mixed with hint of white.
Maybe even do a couple corners with a slight dab of white drybrush alone.
I'd keep the sand to around the base of whatever it is, whether rock formations or structures. Use PVC Glue, or Elmer's-eqsue watered down a tad and placed where you want the sand, sparingly. Shimmy it in the sand til how much you want sticks.
I used all of this on my own desert terrain. It came out amazing. Just make sure to use your imagination of what it SHOULD look like and modify the mixes and colors from there.
Oh, and to make little dunes against structures, just either keep glueing over the previous sand and re-adding, or glue a small piece of plastic or card there at the right angle and add sand to that.
-Khaine-
1 - 6 of 6 Posts
