1 - 5 of 5 Posts
Firing from long distance, the Basilisk can lay down a fearsome barrage ahead of the advancing ranks of the Solar Auxilia. Its hull, derived from the Solar pattern Leman Russ, offers enhanced protection from enemy weapons and can equip a pintle-mounted weapon such as the ubiquitous multi-laser, adding a close quarters defence capability should enemy infantry advance too near.
Whilst it does not have the huge firing range of the Basilisk, the Medusa loads even more devastating shells than its sister tank. Its hull, derived from the Solar pattern Leman Russ, offers enhanced protection from enemy weapons and can equip a pintle-mounted weapon such as the ubiquitous multi-laser, adding a close quarters defence capability should enemy infantry advance too near.
Guess what army has access now to cheap (?) AV14 (?) vehicles with Line of Sight drawn by Nuncio Voxes in the field.
interesting, they seem to be based on the Lemen russ chassis rather then the normal chimera were used to. are these full kits or upgrade kits? the medusa looks rather like it's using normal plastic along with the resin.
1 - 5 of 5 Posts
