21 - 32 of 32 Posts
LOL, I was thinking the same thing (in regard to charge distance).
Anyway, in response to the Cabbage - read asian avatars post, or my post from the first page. There is a clear reason for including the rule - mixed initiative combat. I used an IC in my example, but it could just as easily be a squad member with a higher initiative.
Basically, the rule states that you are locked into fighting whomever you were in base contact with before blows were struck. As my post from page 1 shows, if you are in B2B with an enemy, but that enemy was eliminated (and you are no longer in base contact with any others) you CANNOT allocate your attacks as per the 2" rule if they are going to a different unit than you were originally in B2B with.
This can and will come up whenever you have mixed initiative combat (SM terminator squad, Eldar squad with an exarch, or any two squads with differing I attacking someone else).
It was explained clearly several times, there shouldn't be any contention at this point.
PMT and crimson_chin have it down and with the exception of the point made above by elessar. This is not that hard a rules query to answer. Crimson's point about IC's is really important here.
As far as the OP goes- you had it right my friend, and PMT's post above will help you clarify that. And like crimson says, there really shouldn't be any doubt at this point.
War and mayhem to you all!
Crimson has it as well. If your opponent disappears, you have no one left to fight...you decide and declare who you will attack, then roll dice in initiative order.
Definite props for bringing that up crimson.
If we take a look at the numbered khorne berzerkers in the picture we can see this.
Berzerker 1 - base contact with tsons (He must attack them)
Berserker 2 - Base contact with tsons (he must attack them)
Berserker 3 - Base contact with tsons (he must attack them)
Berserker 4 - Base contact with both units. (he may choose which unit to attack)
Berserker 5 - Base Contact with both units. (he may choose which unit to attack)
You know, I think the implication this rule was going for was to make it so that the models in base to base with both had to attack their original opponents, even though that doesn't really come across in translation.
Awesome post and pictures.
Grey Knight Converter
Only comment about the above is that Berserker 2 and 3 might be able to attack the terminators because they are within two inches of an model in their unit who is in b2b with an enemy (Berserker 4 and 5). Other than that, the example is a pretty good one.
You got it exactly right Troy, and nice idea with the photos.
I really can't understand how this has gone on 3 pages, it should have been a 1 post answer, it's a very simple rule.
Anyway, the one thing I have to comment that you did wrong there, Troy, is that the closest assaulting model has to make contact with the closest enemy model.
The first Terminator has to assault the first Berzerker, although I'm not really sure which one is closer.
Other than that, fine.
Which is exactly what elessar already said... ;)
No, they're in base to base with something, if you have base to base you MUST attack a model in base to base.
Didn't see this posted, but GW has put out an erratta on this:
Page 41 – Multiple Combats, Attacking.
A third bullet point should be added, as follows:
• Models that at the beginning of the combat
(before any model attacked) were engaged with
more than one enemy unit, but were in base
contact with just one of the enemy units, must
attack that unit.
Key point here is that they clarify the timing, and just as has been posted by several here, beginning of combat means before attacking...............
So OP right, new 'friends' wrong
Hey dude been away for a day or so. I read all of the thread several times hence my ears bleeding. :laugh:
My point was that the rules discussed up until my post said no such thing. The errata posted later says exactly that but the BRB does not. I tried to explain above the rules for engaged. Basically B2B or 2".
To use your example of a character. Before the errata a terminator with a PF in base to base can attack any models, still alive, with which he was engaged. B2B was not mentioned at all and was therefore irrelevant. At the points myself and then you posted this, and in fact for all time, the first bullet point says absolutely no such thing
The new bullet point in the errata covers your points exactly and makes the discussion this became pointless. But the first bullet point is still a waste of ink which adds nothing but confirmation to earlier rules.
It was explained clearly by some posters, clearly and incorrectly :p
21 - 32 of 32 Posts
