Dark Angels 2: Electric Boogaloo
5175 Views 42 Replies 7 Participants Last post by  venomlust
CODEX: DARK ANGELS V.0.1
Army Special Rules:
Inner Circle:
A model with this special rule has the Fearless and Preferred Enemy: Chaos Space Marines special rules.
Deathwing Vehicle:
A vehicle with this special rule has the Preferred Enemy: Chaos Space Marines special rule, and if a Deathwing Vehicle suffers a Penetrating Hit you can force your opponent to re-roll the result on the Vehicle Damage table. You must accept the result of the second roll even if it is worse than the first.
Combat Squads:
See Codex: Space Marines.
Relic Technology:
The Dark Angels maintain an unusually high number of ancient technological marvels; in particular, suits of Terminator Armour and prized plasma weapons. Many in the Imperium, not least the high-ranking members of the Mechanicum, look upon this proliferation of valuable wargear with suspicion; some whisper that the Rock contains a number of functioning STC devices, impossibly rare relics from the Dark Age of Technology allowing them to reproduce high-quality plasma weapons and new suits of Tactical Dreadnought Armour on demand. The Chapter Masters of the Dark Angels and their Successors are noticeably silent on the issue. Regardless, each brother of the Unforgiven is given additional training pertaining to the proper maintenance and use of the unstable plasma weapons; an invaluable skill when the Dark Angels come across a power-armoured foe...
Models with this special rule may re-roll failed To Hit rolls of '1' when using Plasma Pistols, Plasma Guns or the Plasma Gun element of a Combi-Weapon. They may also re-roll failed Gets Hot! rolls when using Plasma Cannons.
A replacement 'Chapter Tactic' for Grim Resolve as suggested by Xabre - a la Imperial Fists, but re-rolling 1s on Plasma Weapons instead of Bolters. Many units still have Stubborn, it's just applied on a unit-by-unit basis to clean up the rules. Jury's still out on whether I'll keep Stubborn overall - it does kinda reflect the DA mindset, but it's a pretty annoying rule to have tacked on.
Warlord Traits:
Rapid Maneouvre:
The Warlord and every unit within 12" add D6" to their Turbo-Boost or Run distance.
The Hunt:
If your Warlord has this Warlord Trait, you gain an additional Victory Point if a friendly model was within 6" of the enemy Warlord when the Warlord was removed as a casualty. This Victory Point is separate to the one conferred by the Slay the Warlord secondary objective.
Unwavering Resolve:
The Warlord and all friendly units within 12" may re-roll any failed Morale check or Pinning Test.
Brilliant Planning:
While the Warlord is alive, any model arriving from Reserves using the Deep Strike special rule only scatters D6" when Deep Striking.
Hold at All Costs:
The Warlord and his unit have the Feel No Pain special rule whilst they are within 3" of an objective.
Tenacious Defense:
The Warlord and his unit may fire Overwatch at full Ballistic Skill if they are within 3" of an objective.
The Dark Angels traits were pretty good as they were, so I kept most of them - cleaned up the Leadership one to stop it affecting Perils and such for no reason, and changed Brilliant Planning to work more with what Dark Angels want to be doing.
RANGED WEAPONS
Ranged Weapons:
Avenger Mega-Bolter:
Range: 36"
Str: 5
AP: 3
Type: Heavy 6
Blacksword Missiles:
Range: 48"
Str: 7
AP: -
Type: Heavy 1, One Use Only
Plasma Storm Battery:
Burst mode:
Range: 36"
Str: 7
AP: 2
Type: Heavy 3
Charged mode:
Range: 36"
Str: 7
AP: 2
Type: Heavy 1, Large Blast, Blind, Gets Hot!
Plasma Talon:
Range: 18"
Str: 7
AP: 2
Type: Rapid Fire, Gets Hot!, Twin-Linked
Ravenwing Grenade Launcher:
Frag Shell:
Range: 18"
Str: 3
AP: 6
Type: Rapid Fire, Blast
Krak Shell:
Range: 18"
Str: 6
AP: 3
Type: Rapid Fire
Rad Shell:
Range: 18"
Str: 2
AP: -
Type: Assault 1, Blast, Rad Charge
Stasis Shell:
Range: 18"
Str: 2
AP: -
Type: Assault 1, Blast, Stasis Anomaly
Rad Charge: Every model in a unit struck by a weapon with this special rules suffers a -1 penalty to their Toughness value until the end of their next turn. This may affect their Instant Death threshold.
Stasis Anomaly: Every non-vehicle model in a unit struck by a weapon with this special rule suffers a -5 penalty to their Initiative value and treats all terrain, including open ground, as Difficult Terrain.
Rift Cannon:
Range: 18"
Str: 8
AP: 2
Type: Heavy 1, Blast, Stasis Anomaly
Stasis Bomb:
Range: -
Str: 2
AP: -
Type: Heavy 1, Bomb, Large Blast, One Use Only, Vast Stasis Anomaly
Vast Stasis Anomaly: Every non-vehicle model in a unit struck by a weapon with this special rule reduces their Initiative to 1 and halves their movement, Run distance, Turbo-Boost distance and charge distance (rounding up).
Space Marine Shotgun:
Range: 12"
Str: 4
AP: 6
Type: Assault 2, Pinning
Whirlwind Multiple Missile Launcher:
Vengeance Missiles:
Range: 12" - 60"
S: 5
AP: 4
Type: Ordnance 1, Large Blast, Barrage, Pinning
Castellan Missiles:
Range: 12" - 60"
S: 4
AP: 5
Type: Ordnance 1, Large Blast, Barrage, Pinning, Ignores Cover
Hyperios Missiles:
Range: 48"
S: 8
AP: 3
Type: Heavy 2, Skyfire, Twin-Linked
Bunch of changes. Avenger Mega-Bolter is now worth a damn, although the Nephilim is actually an Interceptor now instead of whatever the hell it is in the current codex so giving it a weapon for chewing up infantry still seems odd. Blacksword Missiles now able to hurt Flyers. Dark Talon weapons improved drastically. Stasis Anomaly now slows people down a lot, instead of -1 WS -1 I which was a strange penalty anyway. Stasis Bomb is now really quite dangerous since halving all movement is a serious debuff. Storm Bolters get three shots each, because they feel like they should.
MELEE WEAPONS:
Blade of Caliban:
Range: -
Str: +1
AP: 3
Type: Melee, Specialist Weapon
Corvus Hammer:
Range: -
Str: +1
AP: -
Type: Melee, Rending
Flail of the Unforgiven:
Range: +2
Str: User
AP: 3
Type: Melee, Concussive, Bane of the Traitor
Bane of the Traitor: When a weapon with this special rule is used to attack a unit containing one or more models from Codex: Chaos Space Marines, the weapons AP value is improved by 1 (to a minimum of 1).
Halberd of Caliban:
Range: -
Str: +2
AP: 2
Type: Melee, Two-Handed, Bane of the Traitor
Mace of Absolution:
Range: -
Str: +2
AP: 4
Type: Melee, Concussive, Bane of the Traitor, Smite Mode
Smite Mode: At the start of any Fight sub-phase, a unit of Deathwing Knights may activate Smite Mode. Their Maces of Absolution have the following statline until the end of the turn:
Range: -
Str: +6
AP: 2
Each unit of Deathwing Knights may only activate Smite Mode once per game.
Blades of Caliban no longer AP3 Power Axes, because seriously, they're atrocious at the moment. Still niche since they're kind of hard to come by in the book, but no longer a detrimental weapon. Maces of Absolution Smite mode fixed wording-wise, but honestly DA don't have many combat weapons so not much work in this section.
SPECIAL ISSUE WARGEAR:
Auto-Targeter
A model with an Auto-Targeter treats all Storm Bolters as Salvo 2/3 and Assault Cannons as Salvo 4/5 instead of their normal types.
Auspex: 10pts
A model with an Auspex can use it instead of shooting. If he does, cover saves taken against his unit's shooting suffer a -1 Penalty.
Camo-Cloak:
A model with a Camo-Cloak has +1 cover save. This results in a 6+ cover save in open ground.
Combat Shield: 5pts
A model with a Combat Shield benefits from a 5+ Invulnerable Save against wounds caused in close combat.
Conversion Field: 15pts
A model with a Conversion Field has a 4+ Invulnerable save. At the end of any phase in which they passed one or more save conferred by the Conversion Field, they must take a Blind test.
Digital Weapons: 5pts
A model with Digital Weapons can re-roll one failed To Wound roll in each Assault Phase.
Displacer Field: 25pts
A model with a Displacer Field has a 3+ Invulnerable Save.
Infravisor: 5pts
A model with an Infravisor has the Night Vision special rule, as does any unit he joins.
Iron Halo:
A model with an Iron Halo has a 4+ Invulnerable save.
Jump Pack: 10pts
A model with a Jump Pack gains the Jump unit type.
Narthecium:
The bearer of a Narthecium and his unit have the Feel No Pain special rule.
Perfidious Relic of the Unforgiven: 10pts
The bearer of a Perfidious Relic of the Unforgiven has the Eternal Warrior and Adamantium Will special rules.
Porta-Rack: 10pts
If the bearer of a Porta-Rack kills an enemy character in close combat, he immediately gains Preferred Enemy: X, where X is the Faction that the slain character was from.
Power Field Generator: 30pts
Any model, friendly or enemy, within 3" of a Power Field Generator benefits from a 4+ Invulnerable Save. If the bearer is embarked upon a transport, only the vehicle upon which he is embarked gains the Invulnerable Save.
Rosarius:
A Rosarius confers a 4+ Invulnerable save.
Servo-Harness:
A Servo-Harness gives the Techmarine an extra Servo-Arm, a Plasma Cutter and a Flamer. In the Shooting Phase, the Techmarine can fire one additional weapon than would normally be allowed.
Plasma Cutter:
Range: 6"
Str: 6
AP: 1
Type: Assault 1, Armourbane
Signum:
A model with a Signum may use it instead of shooting in the Shooting Phase. If he does so, nominate one model in the bearer's unit. That model gains +1 Ballistic Skill for the remainder of the shooting phase. Declare the use of a Signum before any dice are rolled To Hit.
Ravenwing Bike: 25pts
Changes the bearer's unit type to Bike. Ravenwing Bikes are equipped with a Twin-Linked Boltgun and Teleport Homer. In addition, any model with the 'Independent Character' special rule mounted on a Ravenwing Bike gains the Scout, Skilled Rider and Hit and Run special rules.
Storm Shield:
A Storm Shield confers a 3+ Invulnerable Save. A model with a Storm Shield can never gain the additional attack for having two close combat weapons.
Teleport Homer:
Friendly units equipped entirely in Terminator Armour do not scatter when they Deep Strike, so long as the first model is placed within 6" of the Teleport Homer. The Teleport Homer must have been on the table at the start of the turn in order for it to be used.
A bunch of changes. Auspexes are now a unit buff, to make them work better for stuff like Devastators, both types of Field were cleaned up significantly to get rid of all the extra Blind or scattering crap, Perfidious Relic now gives Eternal Warrior because it has to do something, right? Porta-Rack has an effect now, because it's a pretty cool idea that had terrible execution. Plasma Cutters can cut up bits of metal now, because that's what it does in the fluff. You can bring a Ravenwing character now, in case you wanted to do a Successor or whatever.
ARMOUR
Artificer Armour:
Confers a 2+ Armour Save.
Power Armour:
Confers a 3+ Armour Save.
Scout Armour:
Confers a 4+ Armour Save.
Terminator Armour:
Confers a 2+ Armour Save and a 5+ Invulnerable Save. Terminator Armour includes a built-in Auto-Targeter. Furthermore, models in Terminator Armour have the Relentless, Bulky and Deep Strike special rules, but cannot make Sweeping Advances. Characters in Terminator Armour gain the Deathwing Assault and Vengeful Strike special rules.
No changes.
Vehicle Equipment
Frag Assault Launchers:
Models that disembark from a vehicle with Frag Assault Launchers count as having Frag Grenades until the end of the turn.
Locator Beacon:
Friendly units do not scatter when they Deep Strike, so long as the first model is placed within 6" of the Locator Beacon. The Locator Beacon must have been on the table at the start of the turn in order for it to be used.
Siege Shield:
A vehicle with a Siege Shield automatically passes Dangerous Terrain tests.
No changes.
BANNERS AND STANDARDS
When determining assault results, add 1 to your total if there are one or more friendly units with a banner or standard locked in that combat. In addition, all friendly units from Faction: Dark Angels within 12" of a banner or standard may re-roll failed Morale checks and Pinning tests. Some banners have an additional effect as detailed below:
Dark Angels Chapter Banner:
All units with Faction: Dark Angels within 12" of the Dark Angels Chapter Banner have the Zealot special rule. You may only have one Dark Angels Chapter Banner in your army - this is the only Chapter Banner the Dark Angels have!
Company Standard
Revered Standard:
All models in a unit containing a Revered Standard gain the Fearless special rule.
Ravenwing Company Banner:
All friendly units from Faction: Dark Angels within 12" of the Ravenwing Company Banner automatically pass Initiative Tests when attempting to Hit and Run and roll an additional D6 when determining the distance of the Hit and Run move.
Deathwing Company Banner:
All friendly models with the Inner Circle rule within 12" of the Deathwing Company Standard have +1 attack.
DA have a whole bunch of crappy banners that you only ever see two of: the Ravenwing Banner and the Banner of Devastation. Chapter Banner is no longer complete tripe as it benefits units who can actually *use* the combat boost as well as flat Fearless, Revered Standards now give the bearer Fearless instead of giving out Crusader which was a strange rule to give to a shooting army anyway, the Ravenwing Banner stays unchanged but the Deathwing Banner gets it's range doubled, because the Wolf Standard is nearly half the price for the same 6" bubble as it stands in the Codex.
Sacred Standards:
Only one Sacred Standard (of any kind) may be taken in your army. They follow all normal rules for banners and standards, as well as additional effects listed below:
Standard of Retribution: 60pts
All friendly models from Faction: Dark Angels within 12" of the Standard of Retribution gain the Preferred Enemy special rule.
Standard of Devastation: 60pts
All friendly non-vehicle models from Faction: Dark Angels within 12" of the Standard of Devastation fire one additional shot when firing Bolt Pistols, Boltguns (including the Boltgun element of a Combi-Weapon), Storm Bolters or Heavy Bolters. This bonus does not stack with the bonus from Auto-Targeters.
Standard of Fortitude: 75pts
All friendly units from Faction: Dark Angels within 12" of the Standard of Fortitude have the Feel No Pain special rule.
Standard of Retribution needed a fix, to be honest. Counter-Attack with no other way of getting combat onto Tacticals was a bad, bad ability, and very expensive. I'm not entirely happy with it being Preferred Enemy, but this is the draft version. Devastation is less a 'my Bikes and LRCs now shoot a bajillion shots each', more a 'my army in general puts out more firepower'. I never liked how it was kinda restricted to Bikers or vehicles. Fortitude remains unchanged because it didn't need fixing except not costing more than a Predator.
DARK ANGELS CHAPTER RELICS
Foe-Smiter: 15pts
Range: 24"
Str: 4
AP: 4
Type: Assault 5, Master-crafted
Lion's Roar: 20pts
The Lion's Roar is a Combi-Weapon. The secondary weapon has the following profile:
Range: 24"
Str: 7
AP: 2
Type: Assault 1, Blast, Gets Hot!, Master-Crafted
Mace of Redemption: 30pts
Range: -
Str: +3
AP: 3
Type: Melee, Concussive, Blind, Bane of the Traitor
Fall of Lupus: 35pts
Range: -
Str: +1
AP: 3
Type: Melee, Beastslayer
Beastslayer: If this weapon is used to attack a Monstrous Creature or Flying Monstrous Creature, it uses the following statline instead:
Range: -
Str: +2
AP: 2
Type: Melee, Instant Death
Shroud of Heroes: 30pts
The Shroud of Heroes confers the Shrouded and Fear rules on the bearer and his unit as long as it is completely made up of models from Faction: Dark Angels.
The DA Chapter Relics are pretty terrible at the moment, so I made them more useable. Monster Slayer of Caliban got renamed because it was a silly name and got made way better, because it's unuseable garbage in it's current incarnation. Same thing with Shroud of Heroes, which is now useable if a little niche due to the limitation that it only works on DA models. Foe-Smiter got made slightly more relevant, and didn't juts give in to my temptation to clone the Ded Shiny Shoota from the Ork book.
Armoury:
Ranged Weapons:
A model may replace his bolt pistol and/or close combat weapon with one of the following:
Boltgun for Free
Storm Bolter for 5pts
Combi-Flamer, -melta, or -plasma for 10pts
Plasma Pistol for 10pts
Melee Weapons:
A model may replace one weapon with one of the following:
Chainsword for free
Lightning Claw for 15pts
Power Weapon for 15pts
Power Fist for 25pts
Thunder Hammer for 30pts
Terminator Weapons:
A model wearing Terminator Armour may replace one or both of his weapons for any of the following:
Power Weapon for Free
Power Fist for 5pts
Chainfist or Thunder Hammer for 10pts
Special Issue Wargear:
Combat Shield - 5pts
Infravisor - 5pts
Melta Bombs - 5pts
Digital Weapons - 5pts
Porta-Rack - 10pts
Jump Pack - 10pts
Auspex - 10pts
Conversion Field - 15pts
Ravenwing Bike - 25pts
Displacer Field - 25pts
Power Field Generator - 30pts
Chapter Relics:
Only on of each Relic can be taken per army.
Foe-Smiter for 15pts
Lion's Roar for 20pts
Mace of Redemption for 30pts
Shroud of Heroes for 30pts (note - does not replace a weapon)
Fall of Lupus for 35pts
Banners and Standards:
Company Standard for 15pts
Revered Standard for 20pts
Ravenwing Company Banner for 20pts (Ravenwing Command Squad only)
Deathwing Company Banner for 40pts (Deathwing Command Squad only)
Dark Angels Chapter Banner for 70pts
Standard of Retribution for 60pts
Standard of Devastation for 60pts
Standard of Fortitude for 75pts
Vehicle Equipment:
Dozer Blade for 5pts
Pintle-Mounted Storm Bolter for 5pts
Extra Armour for 10pts
Hunter-Killer Missile for 10pts
  • Like
Reactions: 1
21 - 40 of 43 Posts
With regards to making them 'plasma marines' and them no longer being valid against horde and light infantry armies, how do you figure? Plasma has the same rate of fire and range as the ubiquitous Bolter with a better chance to-wound. I hardly see that as less effective vs. any type of model or unit than the standard armament, the only instance of such might be in the case of the heavy bolter v. plasma cannon or the flamer v. plasma gun (but then only at close range). Making Plasma more reliable and less expensive for DA just makes sense to me from a fluff perspective, I wouldn't see it as a 'restriction inherent in the codex' but rather as something unique to a chapter. The Chapter Tactics in the SM 'dex provide blanket rules that benefit some units more than others, or generally improve the individuality of the army so that it's more than just coloured marines on the table.
tl;dr I like Xabre's tactic idea.
That's fair - yes, Plasma Guns do kill light infantry just as well as they kill Heavy Infantry. It's just the case that against Guard, Eldar, Daemons, Tyranids etc., you pay 10pts to wound on 2s instead of 3s. That's pretty inefficient, considering 10pts is almost enough to get you another dude in a squad. On the other hand, DA also have a bunch of ways to get a bunch of Bolters and being Space Marines they generally have pretty strong small-arms presence simply through virtue of being BS4 with a Str4 AP5 gun.
It'd be reasonable to give them a buff instead of a price drop, and a 'Combat Tactic' fits in more with the MEQ standard (BA get Red Thirst, SW get Counter-Attack, SM get Combat Tactics).
I think I'll implement the suggestion. Good addition :eek:k:
EDIT: Gone and added 'Relic Technology' to let them re-roll Gets Hot, and put Plasma Prices back up. Should I get rid of Stubborn?
I agree that termys need a point reduction. One of the major reasons why csm and gk ones are cheeper is the fact that they arent paying over the odds for powerfists on every model. If you take a csm termy and give it a powerfist it suddenly is really expensive at 38pts each i think with a combi bolter rather than storm.
i think some of the pts costs of termys are stuck where they are because they arent going to rerelease the sm + da + ba + sw all at once. Otherwise the others will bitch like they have with the GK.
another example of the cost of eternal warrior + adamant will is the shield eternal at 50pts what is also a stormshield. So with the ss cost or 15, that leaves the value of those 2 skills at about 35pts. The other reason for the necron one being overcost is that the necro lord is T6.
Yeah, I'm not sure why you'd want to bring Power Fists on Chaos Terminators - a Chainfist in a squad, maybe, but Power Axes will be nearly as good and far cheaper in most circumstances.
That's almost true, but they changed Tacticals with the DA book which set the precedent for Codex: Space Marines. Okay, Dark Angels does have a bit of history as being Codex Space Marines: Alpha Release, but it goes to show that the 'sacrosanct' things have been changed, albeit only a little. Besides, I don't have GW's problems; I can change whatever I like, it's my work!
That's really overcosted for not getting ID'd and getting some irrelevant psychic defence.
What is it about the Necron Phase Shifter that makes it seem over-costed?
I realize that Space Marines now generally pay about 15 pts for a 3++, but then the characters who can take one usually start off with a 4++ anyway, the Librarian being an obvious exception. The Necron characters aren't paying for the same +1 tick in a pre-existing Invulnerable save, they're paying for the jump from nothing to 3++.
The only reason I can think of that they didn't bother to provide an alternate cost for no-invul cases like the Libby would be that it fits with their general desire to simplify and streamline things these days.
Because Necron Lords are T5, get back up on a 5+/4+ every time you kill them, and have reasonably cheap access to a 2+ save; and that's assuming you can even attack them through Mindshackle Scarabs.
Giving your Overlord Sempiternal Weave and Mindshackle costs less than a Phase Shifter and is significantly more likely to help you. A Phase Shifter only really helps against dudes with Unwieldy weapons, and at that point you have Mindshackle and a Warscythe - you're probably going to kill them anyway. Even if they have a Power Fist or Thunder Hammer or otherwise hard-hitting weapon, they still have to get through your 3 wounds since very few characters with access to a Str: User x2 weapon are base Strength 5. The chances of them doing so while you swing away with a Warscythe and force Leadership on 3D6 is significantly insignificant as to make a 45pt Invulnerable totally unnecessary.
That, and the fact that the Phase Shifter costs more than a Wraith with Phase Shifter.
Going off on a bit of a tangent, GW doesn't really know their pricing - Dark Angels pay 15pts to upgrade a Company Master to a 3++ from a 4++, but 25pts to upgrade an Interrogator-Chaplain from a 4++ to a 3++. This is why the Armoury system is inferior to 5th ed codexes - one of the best examples being the extortion for a Chaos Terminator Champion's weapons. Even when it was unit-by-unit it wasn't perfect; a Space Marine Sergeant with 1 attack at WS4 pays 25pts for a Power Fist, as did a Chapter Master with 4 attacks at WS6. The Power Fist, in itself, was neither undercosted nor overcosted - it was overcosted for the Sergeant, and about right for the Chapter Master (incidentally, this is why Timesplinter Cloaks are worse than Phase Shifters - despite being a full 33% cheaper for an identical item, it comes on a fairly useless dude who can't use it, while the Phase Shifter at 45pts is actually fairly reasonable on an AV13/13/11 vehicle).
The way I see it, adding the 'Relic Technology' to DA is kind of like adding Flamecraft to Salamanders.
Stubborn still works, since it sort of overrides ATSKNF... and some people don't like it. So it's both benefit/hindrance.
How is Stubborn a hindrance? All it does is allow you to ignore negative modifiers to your Ld tests, I don't see the down side. Was there something in 6th that made it worse?
I might have it confused with Fearless. One of them people DIDNT like, because you couldn't voluntarily fall back the way you could with ATSKNF.
Fearless means you automatically pass Ld tests.
Ah! Grim Resolve also stipulated that you could never choose to fail a Ld test separately from Stubborn. I still like Stubborn, it wins with my Guard.
The Reason I had included Adamant Will is because the item you tied Eternal Warrior to had Adamant Will. You replaced Fear with Eternal Warrior on the item, but kept the same points cost.
Anyone who thinks Fear is worth the same as Eternal Warrior is quiet mad :p.
Stubborn is bad because every unit who has it is shitty in combat and wants to be fleeing (since ATSKNF means fleeing has no disadvantages) - I could count on one hand the number of times you'd want your Tacticals or Ravenwing or anything other than Terminators to stick around in combat, and for those very few occasions, Dark Angels can hand out Fearless and leadership re-rolls like nothing else.
Grim Resolve would be fine if Dark Angels were combat-competent with their Power-Armoured units, but since they're not, it actively prolongs being tied up in combat. For Marines, that's really shitty (there's a reason that 5th ed Combat Tactics was REALLY strong).
And anyone who thinks that Fear is worth points is also mad.
Stubborn itself doesn't mean you can't opt to fail Ld test. Grim Resolve stipulates that units have Stubborn, and in addition to that rule can never opt to fail Ld tests.
I get why Grim Resolve is a bitch and a half, my buddy's DA Captain once got stuck in with one of my Furiosos and he just stood there until he failed enough ++ saves to die. Stubborn as a rule to itself is great, but if you can have Fearless go that way obviously.
I'm not talking about opting to fail a Leadership test - I'm on about simply failing a Leadership test through dice and modifiers. Your DA Tacticals get charged by Termagants, lose three dudes, kill one back, they take Ld8 Ld and probably make it. You're stuck in combat with a bunch of Termagants. Your SM Tacticals in the same situation take Ld6 Ld and probably fail it, reasonable odds of getting away, then ATSKNF means you can rapid fire/charge them next turn or move away and do something else entirely instead of getting locked up in combat.
Being able to opt to fail a Leadership test is hugely powerful, as I said, but since that's not really a thing in the game anymore barring combat with an AV13+ Walker, simply being able/more likely to fail Leadership on a unit that's crappy in combat is a strong, flexible option (at least, for ATSKNF, where running from combat can only ever be a positive result).
See, now that makes sense! I really wasn't getting the whole 'fail a Ld test naturally' part. Guess I'm just way too used to having it on a Guard blob where Sweeping Advance is a thing. Wouldn't you also have to win an Initiative test to get out of combat? In all honesty I've been playing BA for years (who don't have this rule, nor way of getting it from the 'dex) and they have broken from a fight and actually gotten away after the Initiative test maybe a handful of times. Even in your example, that really works if they break during your opponent's turn but totally strings you up if it happens in your turn leaving you out in the open as opposed to tied up in combat. I dunno, maybe it's that I play units that do better in combat than out (like TH/SS DW squads) but I am still a fan of Stubborn even now understanding why you dislike it.
Yeah, you still have to break away, but Stubborn just makes it more unlikely you'll get to that stage. I4 isn't bad either - falling back from a charge by Ork Boyz or Necrons isn't too difficult if you're testing on Ld 4/5.
It's also the fact that as a shooting army, you don't want to engage enemy melee units - if a squad of Terminators with Lightning Claws charges your Tactical Squad and kills 9 of them, that one dude is going to hang on with Grim Resolve, die horribly in your turn, leaving the Terminators free to do what they like next turn. There is a minor plus that if you charge someone and the rolls go horribly, you stay in combat during the enemy turn, but it'd need to be a pretty wacky roll to go that badly for you, and you'd need to be charging with Tacticals in the first place (which means the enemy is either very weak in combat or you're on the win anyway).
In short; I don't like Grim Resolve because Dark Angels really like breaking from combat.
@MidnightSun
Will go reading through all the 3 pages of comments (aaaand done) but got to mention this
DW Command Squad pays 25 points for CML while DWT pays 20 points
Flail of the Unforgiven doesnt have +2 strength modifier is that intentional?
Conversion field and Displacer Field were fine , the blind and teleport were very fluffy and provided a nice touch to the items.
Loving the "fix" for Terminators another way to make them worth the price is T5 and remove Unwieldy from Power Fists, they were developed for Terminator armor after all.
Also you should create BattleScribe file for your homebrew, I would definitely give it a try with my friends, you dont even need to start from scratch can just outright modify the current DA file. :)
Also Fear is not worth the point but it is fun I made a Daemon Prince run away from my Interrogator Chaplin once (we forgot he is fearless).
Thanks for picking up on those, I've edited them.
I think there's a thin line between 'fluffy' and 'obnoxious' and while the Blind effect was rare enough that I didn't really mind, the Displacement effect was simply annoying.
T5 could certainly be an option, but bear in mind the suggestions here that edit 'baseline' units would edit the SW/BA/SM/CSM/GK versions too if/when I did all the codexes; hence the Auto-Targetter being part of Terminator Armour, to stop it giving Strike Squads and such an undue boost. T5 Terminators could be T6 with Mark of Nurgle, which would be pretty crazy. The other, internal balance issue is that there's basically nothing wrong with Deathwing Knights or Hammernators other than a slight overcosting. Making them T5 as well as the shooting Terminators does nothing to address the current internal balance issue in basically every book that Hammernators are strictly better than the others as shooting Terminators are damned inefficient. Removing Unwieldy from the Fists is a no-go; Terminators already crush the things they're supposed to in melee, fightiness isn't their problem; it's that they suck at shooting and have costing issues.
:spiteful::spiteful::spiteful:
Homebrew sees your Nurgle Bikers, and raises you Terminators...
21 - 40 of 43 Posts
