1 - 7 of 7 Posts
So I have just starte plyaing this game. Coming from a 40k background, some of these rules and concepts are hard to get around.
The one thing im getting kinda hung up on right now is "Charging".
I just want to make sure I am getting this concept right.
Tell me if i am wrong.
You DO NOT need to "Charge" a modle to "Engage" it in close combat.
You can move into Melee range and make attacks without "Charging"
The reason I as is becuse I am so used to a Charge being a phase of the game, not a menuver.
Thanks,
Yes, you're right on that. In warmahordes, you can move around freely, you can walk into combat if you want, or walk out of combat (taking a free strike if you do). You can even run in, if you don't mind being unable to attack for the turn - great for tying up ranged units/jacks. Basically, just move, and, if you're within your melee range, you're in melee. Simple as that.
Charging is basically a manoeuvre that allows you to get an extra 3" range when moving in to attack, and gives you a Boost on the first damage roll against your charge target. There are restrictions placed on it (you must try to move into melee distance, and if you fail, you lose the rest of your action, you can't use a Power attack, must make a melee attack, ect.) but that's the crux of it.
Hope that helps :)
Maddermax is correct. You are not required to charge in order to engage a model. A charge does have some extra rules to make it work correctly, but as said before it does carry some extra benefits. I've played Warmachine since shortly after original release and one thing that most players skip on a charge (especially players who cross from 40k) is that at the end of the charge movement the charging model must turn to directly face its target. This is very important since all models in warmachine have a facing with front and back arcs being very relevant.
Is it possibilistisk to "run" in to cc? Or dó you losse All action when decide to run?
At the end of your run movement, your model's activation immediately ends - no actions or attacks of any kind are possible. So while you can run into melee range, you won't be able to do anything to them. It can still be useful to engage ranged opponents, to stop them shooting at you.
Running to engage is a very common tactic used when facing gun lines or models you don't want charging you. You don't get any attacks on them as stated above however they will not be able to charge any one els and will have to stay in your melee range or risk a free strike.
~Joker
Handmaiden of Slaanesh
If you can somehow run into a unit of Bile Thralls, your opponent cries as they have no melee. But running something like Kayazy or Daughters into melee is good since their high DEF is beastly to get over.
1 - 7 of 7 Posts
