1 - 12 of 12 Posts
Silly question but how many d6 do cab get when wanting to run ? Is it still 1 just wondering because of the 12" movement
D6".
The appendix at the back of the BRB is great for this sort of stuff, starts on pg.424. I mean, there's always the relevant sections, but having those 6 pages handy is great.
Entropy Fetishist
Hmmm. Similar musing: what happens when you have a cavalry independent character in a biker squad? Can the bikes turbo boost while the HQ runs to keep up? Mixed unit type running, arg.
normaly you can only move as fast as your slowest model, in this case no the bikes could not turbo burst, unless you planned on leaving the hq behind
actually the bikers could turboboost and goes as far as unit coherency allows. and he cannot run to keep the pace, because the unit he joined is not able to run.
In reply to the original question, Cavalry run d6", but can re-roll it due to their innate fleet.
In reply to MossyToes, it would mean the independent character would leave the unit, but could join up next movement phase, as the rules for joining units state 'In the movement phase,.
normally you can only move as fast as your slowest model, in this case no the bikes could not turbo burst, unless you planned on leaving the hq behind
This is not a rule in 6th edition. Read BRB pg 10, right column, 4th para.
The unit may turbo boost, then the Character may Run so long as the unit stays in coherency the entire time.
So the IC can run? i thought that running was a unit thing...well that's good.
ah, now i got it clear. You run modelwise but you may not shoot unitwise! Thank you DK.
1 - 12 of 12 Posts
