1 - 7 of 7 Posts
I've been debating how to do the camo cloaks on my SM Sniper Scouts and I think I've come up with a decent solution.
I've decided to use the Citadel Texture Astrogranite paint for the color of them cloaks, then use a mixture of a black wash/shade and various gray tones for the dry-brushing. This way the cloaks will blend into the basing I plan to do as well.
Has anybody else used the Citadel Texture paints in this way before?
Only on bases, it's literally just grains in paint. I thought maybe the mud one would be different than the astrogranite one, nope. Just paint and sand.
I would suggest not spending $5 on it and just getting some sand- though if you don't live by a body of water I can see that being tricky. There may be other less expensive options at a local arts supply store.
I like the idea of incorporating your basing material in your camo cloaks though, that will surely look bad ass when you execute the idea.
that is avery cool idea. i wonder what will the result be. i'm waiting for pics! :)
Some kind of sealing agent on top of the final cloak might be a good idea - textured paints only work because the base of a model receives zero wear and tear, while cloaks do a lot of rubbing on fingers, trays and other models. Varnish or something would help protect from that.
1 - 7 of 7 Posts
