Ok, so I may have a problem that will probably screw my painting over tonight. I have recently experienced what I believe is called Blossoming. I used Chaos Black GW primer on my mini (which I had recently stripped with Rubbing Alcohol) and went outside after I believed it dry to spray it down for a new paint job. Only problem is, now it seems some of the primer dried in a way that looks like it "gunked" up in in certain areas, and it really looks like crap. THe spray didn't do this the first time I used it, so does anyone know what may have caused this? Will I need to strip the paint again inorder to paint the mini and have the primer not ruin it? Note that it was very humid outside when I was priming, if that helps at all. Thanks
