1 - 10 of 10 Posts
Well I got a Baal tank for Christmas for my new Blood Angels army and Im unsure how I should Arm it. Thinking Las cannons are never bad. But Ill be doing a 3 player narrative campaign and Ill be facing off against my friend who is a new nid player, and another who runs Deamons. Ideas?
So be it.
Well, if it's really a baal predator, you can only have an assault cannon or flamestorm cannon and heavy bolters or heavy flamer side sponsons. I suggest either Assault/Bolters or all the flames. Both clock in at 135. If, though, you mean a normal predator, I'd stick with the normal predator and either do a dakka pred (autocannon + heavy bolters for 95) or take lascannon sponsons for 115. You could take 3 lascannons for 140, but that's a bit steep for my taste.
If you're worried about tanks, you want an autolas pred, if you're facing swarms you want a fired-up baal, and if you're facing anything else then take the bolter side sponsons with the standard gun.
140pts for 3 lasccannons? That isn't bad at all. If you need the Antitank then there is very little that is equivalent. Stormraven? 200pts plus for a Lasccanon and Multimelta? In this edition, hp damage kills vehicles, rather than outright explodes (niche options work, though, namely AP1. ) AP2 has a chance, but mostly for each 1/6 penetrating hit chance you cause a HP damage. Unless it has 7 HPs and isn't Super Heavy you are more likely to cause the requisite HP in damage.
I don't know why I thought I could have las cannons on it lol. I'm feeling like I might outfit it to take on hordes. I feel like maybe an assault canon with heavy bolters. I find flamers don't do much good on carnies
Neither do Heavy Bolters to be fair. If you need to take on Carnifexes then max out the assault cannons available to the army.
Having said that Deimos Plasma Executioner Predators do better.
Imperial Armour Volume 2 2nd Edition, from FW. Not sure if BA have access to multiple versions through Master of the Forge or equivalent as I'm AFB, but with 3 Plasma Cannon Shots and 2 Lascannons they chew through MC's.
Where do I find info on those?
Vas already explained that, but, the model itself is expensive from Forgeworld.
Really, this model is best kitted out to your preference. If, like me, you do not like flamers then run assault cannons and heavy bolters, I like that they have a far reach compared to templates.
Just make sure to build it to your personal specs.
1 - 10 of 10 Posts
