1 - 8 of 8 Posts
This is more of a fluff question, not a gaming one; just a heads up.
I am writing a space marine fic, and I need to know a few things about the various marks of armor.
1: The beaky helmets are Mark six right?
2: What mark uses the studded shoulderpads?
3: What improvments were made with the mark 8 design? Is it just the throat protector?
Jac "Baneblade" O'Bite
Hey man, good to see more people writing, look forward to reading it. I thinking about the very same thing the other day. Went on the net and found that Wiki has got a fair amount on it. So instead of just reguritating the infomation and making me look very smug and smart I'll give you the link... when I can find it.
Ok here it is:
http://en.wikipedia.org/wiki/Equipment_of_the_Imperium_(Warhammer_40,000)
Also, here is one on weapons.
http://en.wikipedia.org/wiki/Weapons_of_the_Imperium_(Warhammer_40,000)
And another I just found on Vechiles, this one isn't as good as it is quiet breif but does cover some older stuff.
http://en.wikipedia.org/wiki/Vehicles_of_the_Imperium_(Warhammer_40,000)
Most of it isn't bad actually, I should add it to the links section. Wiki can be a bit suspect at times but all these seem genuine.
Hope that helps. Good luck with your writing.
Mark 5 and mark6 both have studded pads, but mark five also has studded helmets and greaves. mark 6 have the beakies.
Mark 8 armor has a larger neck protector, a superior vox system, and a better movement with the synthetic muscles.
Executive Nitpicker
As I understand it, the studded shoulders originated in the old heresy armor, but remained popular trough the centuries in a more symbolic manner.
Often times a marine's armor will be passed down or parted out, especially if he had something of a reputation. So these days it's not uncommon to see studded shoulders on even the newer Mk7 and Mk8 armors, either as a piece of an ancient suit that was passed down, or simply as a symbol of someone's status as a veteran.
In other words, studded shoulder pads go on whomever you want ;-)
Left side only, though.
1 - 8 of 8 Posts
