25mm/40mm 'Double' Bases - Wargaming Forum and Wargamer Forums
post #1 of 3 (permalink) Old 09-27-08, 04:48 PM Thread Starter
Heresy's Graphics Slave
Syph's Avatar
Syph's Flag is: United Kingdom
Default 25mm/40mm 'Double' Bases
I have an old Tigurius model that comes on a 25mm base - but I thought being a character he deserved more of a base. I was concerned about the rules lawyers, but between Galahad and myself we thrashed out a bit of a work-around: a double base.
Here's the prototype, which I may actually go on to refine with a bit of Greenstuff and more scenic stuff on the actual base - but here's the principle of the project.
You'll need:
1x 25mm base
1x 40mm base
1x piece of card (like the back of a blister pack) - plasticard would be better.
A craft knife
Scissors
A pencil
Superglue and PVA
Whatever basing materials you use.
Step 1:
Use the 25mm base to draw a circle onto the 40mm base as a cutting outline. Get the 25mm as central as possible before you draw - I recommend a bit of bluetac to hold it in place.
Step 2:
Use a craft knife to cut the circle out. I messed up the initial 40mm base I did, and the one above isn't pefect - it's because of the peg holes that are molded underneath the base. If you can remove these, do so. I don't think my knife was sharp enough.
Don't worry too much about neatness if you're going to add a ton of scenery.
2a: Draw around a the 40mm base on a piece of card and cut it out. Glue to the bottom of the base.
Step 3:
Test fit. It might be worth, at this point, magnetising the bottom of the base to the card of the 40mm base.
Step 4:
Ta da! Based, ready to prime. Base however you want, but obviously ensure you can still remove the model from it's 40mm holder. I'm going to paint a light effect around the join, thus making a feature of the crack. Finer basing materials would make the join far less prominent.
Don't forget to prime the inside of the base.
Done!
Last edited by Midge913; 02-10-12 at 01:31 PM. Reason: Replacing images from the Heresy-Online Gallery
Syph is offline
post #2 of 3 (permalink) Old 09-27-08, 06:34 PM
imperialdudes's Avatar
imperialdudes's Flag is: USA
kool and practical
imperialdudes is offline
post #3 of 3 (permalink) Old 04-25-09, 05:33 PM
johnnymajic's Avatar
johnnymajic's Flag is: Canada
thats an aweome way to do it
johnnymajic is offline
Go Back   Wargaming Forum and Wargamer Forums > Hobby > Tutorials > Wargames Terrain and Basing
