Snow Bases - Wargaming Forum and Wargamer Forums
post #1 of 10 (permalink) Old 09-18-08, 12:18 PM Thread Starter
Where is Jessica Hyde?
humakt's Avatar
humakt's Flag is: England
Default Snow Bases
There are several methods for making snow. Here is my method, which are steps taken from other people’s ideas mixed with my own experiments. I use bicarbonate of soda as my ‘snow’ because it has a nice glistening quality similar in appearance to real snow. You don’t to get this from the GW snow scatter.
What you will need
Material
1. Baking Soda
2. Pollycell ‘No Sanding Pollyfila’
3. PVA Glue
Tools
1. Something to mix the stuff in
2. Something to mix with
3. Something to apply the mix with
Step 1
Mix some PVA and baking soda. The mix is about 50/50 in quantity. You will need to add water until the mix becomes ‘gloopy’.
NOTE - The mix needs to be watered down prior to adding the pollyfilla. If you don’t the entire mix will be ruined as it turns into a big blob of rubbery type material.
Step 2
Add pollyfilla until the mix becomes a soft paste. It should be slightly wet. I normally find the volume of pollyfilla required is double what is already in the mixing pot, but it can vary depending on how much water has been added already.
Step 3
Apply mix to base or scenary as required. It is possible to form drifts with this mix.
Step 4
Cover snow with more bicarbonate of soda. Leave for around 5 minutes and then light tap of excess. Place figure to one side to thoroughly dry over night. Once completely dry further excess can be shaken off. I also use a dry brush to dust off any bicarbonate that has got stuck in awkward places.
Step 5
Varnish the model. This will secure any loose bicarb in place. Here is a objective marker that has been varnished with dull coat spray.
A word of warning. This method does not allow things to be glued on top of it. If you glue figures onto this mix once it is dried, it weakens the mix and the figure will come off with a big clump of snow attached to the base. To get figures standing on hard snow I would recommend glueing them to the base with spacers under their feet to allow the snow to be level with the bottom of the foot.
Last edited by Midge913; 02-08-12 at 11:51 PM. Reason: Replacing images from Heresy-Online Gallery
humakt is offline
post #2 of 10 (permalink) Old 09-19-08, 11:57 AM
The Wraithlord's Avatar
Excellent tutorial Humakt, +rep!
My Thousand Sons Project Log
My Cryx Project Log
My Necron Project Log
The Wraithlord is offline
post #3 of 10 (permalink) Old 09-19-08, 12:05 PM
Must keep painting....
squeek's Avatar
Humakt you are my hero!
I forsee a large number of night goblins and Eldar going to war only in the winter from now on
squeek is offline
post #4 of 10 (permalink) Old 09-19-08, 12:06 PM
Drax's Avatar
Drax's Flag is: England
good stuff!
i'll be using this on my forthcoming board!
Drax is offline
post #5 of 10 (permalink) Old 09-20-08, 01:50 AM
Any clue that the Pollycell ‘No Sanding Pollyfila’ is called in the USA?
evar is offline
post #6 of 10 (permalink) Old 12-15-08, 02:29 PM
Inane's Avatar
We can't get the mix just right. Besides from the mix getting filled with clumps the steps generally don't look like yours.
If this is where you added water
http://img.photobucket.com/albums/v4...orial/mix2.jpg
and this is where you added the pollyfilla
http://img.photobucket.com/albums/v4...orial/mix3.jpg
Then when does it get like this?
http://img.photobucket.com/albums/v4...orial/mix4.jpg
What exactly is the pollyfillas function? Is it to accelerate the drying process? Is it absolutely necessary? Our Swedish version of the filla seems to have a slight yellowish or greyish tone.
The biggest problem though is that whenever we sprinkle the whole thing with baking soda, it swells up to look like a big blob of bubbling shaving cream.
Thanks
EDIT: The core problem seems to originate from a misconception. Apparently there's polyfilla in powder form (The pic I couldn't identify). I only knew of and owned a tube of polyfilla in paste form. I'll try to get my hands on some powder filla and give it another go!
Inane is offline
post #7 of 10 (permalink) Old 12-15-08, 03:46 PM
Underground Heretic's Avatar
Underground Heretic's Flag is: USA
I was wondering, Humakt, if the same process would work with baking powder. I've tried mixing it with glue but it comes out flaky and clumps. The only problem I can see is that Baking powder reacts to water, do you have any thoughts on how to avoid this?
That which doesn't kill me has made a tactical mistake.
Rites of Battle Your source for 40k opinions, news, and hobby updates.
Underground Heretic is offline
post #8 of 10 (permalink) Old 12-29-08, 12:09 PM Thread Starter
humakt's Avatar
The pollyfilla I used is not the 'wet' premixed but a very dry lgith version so yes this could be the cause of you difficulties. Let us know the results.
The problem with replacing the bicarbonate of soda with baking power/sod is that the 'cream of tartar' has a chemical reaction when exposed to liquid and goes all bubbly as you have found. I would edit the main instructions to make it clear that bicarb should be used and not baking soda/powder as I stated. Hope this clears this up.
humakt is offline
post #9 of 10 (permalink) Old 12-29-08, 01:32 PM
Inane's Avatar
I tried it with bicarbonate of soda, worked great : ) Yet to have tried with pollyfilla though but from these results I'm not sure it's even needed.
All is dust, all is microscopic dust acting seemingly random and unpredictable
Inane is offline
post #10 of 10 (permalink) Old 12-29-08, 03:51 PM Thread Starter
humakt's Avatar
Great stuff, glad it worked for you. I found the pollyfillas gives it more solidty for deeper drifts on the base, but thats my experience.
humakt is offline
Go Back   Wargaming Forum and Wargamer Forums > Hobby > Tutorials > Wargames Terrain and Basing
