Cult of the Armoured Serpent - Wargaming Forum and Wargamer Forums
post #1 of 3 (permalink) Old 09-03-17, 12:50 PM Thread Starter
Feed
Serpion5's Avatar
Default Cult of the Armoured Serpent
An offshoot of the Coiled Serpent, this cult has instead infiltrated an Astra Militarum regiment. I want to build this in a way that will allow me to use both the Genestealer and Militarum codexes, so for now this list is out of the Genestealer Index and all models will be genestealer rules with converted Militarum models.
I want some feedback on this list before I invest heavily on any kits though.
Primus: ... 76
Iconward: ... 53
10 Neophytes: Lasguns, Autocannon Crew ... 75
Cult Scout Sentinel: Missile Launcher ... 55
Cult Leman Russ: Exterminator Autocannon, Heavy Bolter ... 165
1089
Magus: ... 73
Iconward: ... 53
Iconward: ... 53
20 Neophytes: Lasguns, Leader with Cultist Knife ... 100
Cult Chimera: Multi Laser, Heavy Bolter, Lasgun Arrays ... 93
1,991 points. 2 Detachments, 9 Command Points.
So, opinions? Is this over the top? not enough? Do any counter strategies instantly spring to mind?
Nonsense is our Salvation
Serpion5 is offline
post #2 of 3 (permalink) Old 09-03-17, 07:47 PM
Shandathe's Avatar
One proposed adjustment, that's 5 HQs, 7 troops, 6 Fast Attack, 4 Heavy Support. With 2 Batallions, that means you have a spare HQ to split off with which you can form three Scout Sentinels into an Outrider Detachment, or 3 Leman Russ tanks into a Spearhead. Free extra CP.
Anyway... on to the actual units. My first thought was that the list seems horribly vulnerable to an enemy with dedicated CC squads. Neophytes are essentially Guardsmen, and there's no squad of Purestrains around to keep people honest. However, you've got the Cult Ambush so you'll probably be able to get the drop on things.
I'm honestly not sure of how it will all play out. Deployment is going to get funky and I'm thinking most games will get decided early on.
Shandathe is offline
post #3 of 3 (permalink) Old 09-04-17, 08:05 AM Thread Starter
Feed
Serpion5's Avatar
That is true.
Yea, I'm pretty sure the first two turns are going to be the deciders for most games with this list. It's gonna be heavy pressure on those autocannons and heavy bolters to thin out enemy heavy infantry as early as possible, and those blob squads in the Magus' detachment to form a solid if temporary shieldwall against charging units.
I know that deep striking assault units are going to be pretty devastating, but short of breaking the theme there aren't a lot of counters to this problem. I was considering converting ogryns and counting them as abberants, but even that would be of limited help.
Serpion5 is offline
Go Back   Wargaming Forum and Wargamer Forums > Warhammer 40K > 40k Army Lists > Tyranid Army Lists
