Paint Strip Miniatures - UK Guide (Dettol) - Wargaming Forum and Wargamer Forums
post #1 of 35 (permalink) Old 09-14-09, 12:16 AM Thread Starter
Default Paint Strip Miniatures - UK Guide (Dettol)
How to strip plastic and metal figures using cleaning products!
This guide will teach you how to remove and strip the paint from all of your old miniatures - plastic and metal. I've used this process on Games Workshop / Citadel miniatures in plastic, white metal and lead forms and it works great. You can soak plastics for as long as you like and they will not melt, loose any detail or end up with scratched surfaces. This process also wont touch your glue bonds. I've used this process to remove just a single layer of primer through to stripping models which have been primed and painted 2,3, and in one case at least 4 times.
The Dettol will loosen the paint, and then using a combination of your fingers, toothbrush and a tooth pick you will scrub it off. How long this takes depends on the amount of paint on the model and the type of paint used. How much scrubbing depends on how impatient you are ;)
The guide is written with Brits in mind - using a safe household product (Dettol) that is cheap and easily found in this country. I know it sounds strange to think that an antiseptic disinfectant could paint strip your mini's, but honestly it really does work.
This method can be replicated with stuff like Simple Green (for folks from the USA and Canada) and Pine-sol as the method is the same.
Please note Brits, you do not need to buy £5-6 a litre worth of Simple Green from their UK site - Dettol works superbly on plastic and metal and is totally safe (both for your mini's and your health/enviroment/love lives/ parent realtionships!).
Why?
Why strip mini's? Why pay games workshop for new models that you already own but were painted at the start of your hobbying journey? Why
not pick up those cheap badly painted mini's from ebay?
Why write the guide?
Having searched around for a day or so for a decent guide I decided to put all this knowledge in to one place for future paint strippers. This information is all out there and nothing is new - but for shear convince I have compiled it here.
Why isn't there a GW master-class covering this sort of stuff? Why do you think.
What You Need
  • Dettol - Antiseptic Disenfectant (Get the brown stuff. DO NOT get the nice smelling stuff (purple/green?) - it wont work)
  • Jam Jar / Plastic Container - Big enough to submerge your models completely (or at least half in the case of tanks). I highly reccomend geting a container/jar with a lid if you don't like the smell of hospitals...
  • Touth Brush - An old one is fine, if it has a small head you may find it easier to get in between legs. Would not suggest anything too stiff as you are going to be scrubbing your minis with it..
  • Cocktail sticks - Wood ones.
  • Plastic Washing Up Bowl - An old one is best, this will get splatted with nasty funky dettol paint so please don't use the one your mum uses for the washing up!
  • Rubber Gloves - Whilst not toxic, neat dettol will dry your skin out and make it blister with prolonged exposure. These will get manky so again ask your mum/partner first!
  • Newspaper - For keeping the floor/desk/patio clean
  • Tea Towel - For drying models after - shouldn't get too manky but again it may be wise to check first
That's it. Nothing deadly, no battery acid or solvents. Everything might well already be sat in your kitchen cupboard...
Saftey
  • Don't drink the dettol you ninny.
  • Leave out of reach of small children and pets. (You may be leaving this stuff lying around for an hour, night or a whole day)
  • Put a lid on your container to escape spouse / parent wrath of doom +10 and to prevent any messy accidents
  • Carry this out in a well aired room or outside - whilst not toxic, you will stink afterwards
DO NOT
  • Use water to rinse your models without washing up liquid - you will end up with a superglue like sticky goo of paint on your minis! Until you are finished - always rinse by using neat dettol on your tooth brush
  • Expect this to be hugely tidy if your figures have already been painted several times and your in a rush.
Stage 1 - Soak
  • Break apart your minis (optional)
  • Take off the models base (optional)
  • Drop your figures into your container
  • Fill the container with enough neat detol to cover your models completely .
  • Put the lid on your container
  • Put it somewhere it wont get kicked or mucked about with.
Breaking apart your minis can help the dettol to get in and most importantly makes it much easier for your to scrub off the paint later. I recommend breaking off pieces that come away easy or those that very badly obscure part of the model. You really don't need to do this for all minis. Be careful as very small bits can be hard to pick up in rubber gloves!
Taking off the base can prevent flock from getting in your detol mixture, and hence this makes it last longer. You will be able to do more minis at once if you take the bases off (but don't put in so many that the detol can't reach lots of parts on your minis). If you do take the bases off I suggest you stick a gloved finger in every now and again to jiggle the minis around.
When doing anything with neat dettol or the unrinsed minis I would suggest doing it either outside or in a well ventilated room. This is not really for health reasons (unless you class bruised ears as health reasons...).
Neat dettol stinks, nuff said.
When filling the container, remember that anything not covered by dettol will not be stripped. For tanks it may be necessary to strip one half and then flip the model and strip the other.
Stage 2 - Wait
  • Wait some time
  • Scrub off a layer or two of paint (optional)
  • Wait some more time
How long this process takes varies greatly, based on the paint type, amount of paint, model type (metal/plastic), primer type etc
Some of my observations
  • Metal models which have been painted multiple times will need to stand between 8-12 hours.
  • Plastic models painted multiple times will need to stand for about 8-16-24 hours.
  • Metal models which have been primed and painted only once can be ready as quickly as 4 hours.
In order to speed up this process you can scrub some of the paint off and then return the miniature to the dettol stripping pot. Follow the method in stage 3 for scrubbing.
Stage 3 - Scrub
  • Use the toothbrush to remove the loosened paint
  • Use a toothpick to get in the very tight cracks
  • Return the model to the dettol stripping pot and return to stage 2 if needed
RINSE THE MODEL USING NEAT DETTOL - DO NOT APPLY ANY WATER AT THIS STAGE!
- Other wise you will end up with a gluey messy model ;)
Using your rubber gloves simply scrub the model with your touthbrush. Put your hands and model inside your washing up bowl to keep stripped paint splatters to a minimum and your ears a healthy pink colour. You should see metal, or a much deeper level of paint very quickly (one or two stokes).
If you don't find this process easy then return the model to the paint stripping pot. If your in a rush, scrub as hard and as long as you like, your toothbrush should not scratch plastic or metal.
If you find the model gets a bit gooey, or you end up with paint fragments dotted around then just get some neat
dettol on your brush and wash it away.
Repeat this process until all of the paint is gone from the model. You can stop earlier if you like, but it is certainly possible to get 99.9% of the paint off the model using this process.
Stage 4 - Rinse
  • Plunge the model into warm soapy water
  • Rinse throughly
  • Towel dry
  • Check for a tacky residue
Once the model is totally stripped, plunge it into a bowl of warm water and washing up liquid. Make sure the water isn't too hot or you may deform plastic. The washing up liquid prevents the nasty guming affect mentioned in the stage 3. Wiggle the model in the water for a while to make sure all the dettol is off. If you don't get all the dettol off then you will find that paint and primer will not hold well to model.
I've found that it is possible at this stage to use a toothpick or cocktail stick to scrape out any gummy bits of paint left in cracks. If you clean out your toothbrush (in the soapy water) you can also give the model a quick scrub with it to knock of any paint flakes.
Rinse the model in cold water to get off any soap residue once this is done for the same reason.
When the model is dry check for a tacky residue, this will indicate that the model needs a bit more washing ;)
Well done you... guess what, your done!
You will find your mini now smells of dettol almost as much as you do. This is fine, in both cases the smell will dissipate ;) You will also find that you figure is free of paint and very, very clean. So much so that metal models shine far more then when you first got them out of a blister.
You can reuse the dettol if you wish, however I find that after a few paint stripping sessions the solution becomes pretty paint laden and that the stripping effectiveness drops off sharply.
If people need pictures to show the stages let me know. Simples!
demize2010 is offline
post #2 of 35 (permalink) Old 01-07-10, 01:25 PM
bonswizzle's Avatar
bonswizzle's Flag is: England
Fantastic, I've been looking for a good UK based stripping guide for a while, seeing as we don't have easy access to Simple Green, and I have about 1500 points of awfully painted Space Marines from way back in the day.
Very clear guide and well written, I will be trying your techniques this weekend! Any chance you could show me a before and after shot of a sample model? That'd be great.
Keep on strippin'
bonswizzle is offline
post #3 of 35 (permalink) Old 01-07-10, 02:03 PM
fatmantis's Avatar
yes this really does work, i have posted some pics of before and after of my dettol cleaning, time consuming but well worth it
fatmantis is offline
post #4 of 35 (permalink) Old 01-19-10, 03:21 PM
this is genious ill be using it tonight on my IG thanks so much for the info
cazmac is offline
post #5 of 35 (permalink) Old 02-02-10, 11:27 AM
fatboy955's Avatar
fatboy955's Flag is: United Kingdom
this rocks!!! tried it before but ended up with the superglue type paint Well plesed that i had this step by step guide
fatboy955 is offline
post #6 of 35 (permalink) Old 02-08-10, 05:24 PM
Sethis's Avatar
For the record, you state that Dettol takes 4+ hours... which seems to be a rather long time to me!
I use exactly the same process, except my solvent of choice is Acetone-free brandless Nail Polish remover from Superdrug. It's about £1.50-99 per bottle depending on where you live and does the job in literally 5 minutes. Much more convenient than a whole day spent stripping!
Thanks for taking the time to write all this out!
Sethis is offline
post #7 of 35 (permalink) Old 03-12-10, 11:32 PM
King_of_eldar's Avatar
King_of_eldar's Flag is: Australia
Awesome guide. I live in Australia but we can get all this stuff so I tried it. It worked great! There was still some black on the figures but that's because I didn't break parts off. I didn't use rubber gloves so my hands were really sore and wrinkly. Next time I'm using rubber gloves. TY so much.
King_of_eldar is offline
post #8 of 35 (permalink) Old 03-22-10, 06:30 PM
The Madman's Avatar
The Madman's Flag is: United Kingdom
cheers for the tutorial but i have a question.
what do you mean by "neat dettol" at stage three?
Click the Signature for my blog.
The Madman is offline
post #9 of 35 (permalink) Old 03-24-10, 06:47 PM
warsmith7752's Avatar
warsmith7752's Flag is: United Kingdom
ive had 3 minis siting in dettol for 3 days and only a tiny little spec has come off it may have been because i used scented detol but it hasnt seemed to work for me.
current win rates;
csm 3/1/1
daemons 1/0/0
warsmith7752 is offline
post #10 of 35 (permalink) Old 03-24-10, 08:35 PM
countchocula86's Avatar
countchocula86's Flag is: Canada
Dettol that isnt diluted with water
I tried an acetone free nailpolish remover, and when I let them soak, the plastic started to melt. I think maybe it can do the job, but its a bit risky if you soak for too long.
countchocula86 is offline
