Help Finishing 1500 Points of IFs - Wargaming Forum and Wargamer Forums
post #1 of 7 (permalink) Old 10-21-13, 03:26 PM Thread Starter
ntaw's Avatar
ntaw's Flag is: Canada
Default Help Finishing 1500 Points of IFs
I've stripped down what I have to be bare bones in an attempt to clear out as much space for options. This is what I have for my IF army, the only things made up and set in stone (or set with glue, whatever) are the librarian who I modeled with a big old SS already (which could be a Shield Eternal...), my terminators w/2x LCs and 3x TH/SS, and their LRC (that is fully magnetized). Aside from that this list is barely even assembled, really. I'll be borrowing Rhinos from my BA army for a loooong time. Here's the list:
Libby w/terminator armour, staff, ML2, SS
ELITES
Dreadnought w/2x TLAC
Terminator Assault squad w/ 3x TH/SS, 2x LC in a LRC w/MM
TROOPS
2x 10 man Tactical squads in Rhinos
HEAVY SUPPORT
10 man Devastator squad w/4x MLs (could go LCs, but MLs stay much more relevant against a unit of troops)
FORTIFICATION
ADL w/QG
Things I'm looking for:
What weapons to arm the Tacticals with. (The sergeants of every squad of marines will have a SB, but that's more aesthetic than anything else. My opponents and my own sense of OCD are cool with that little proxy if they don't actually have the weapon)
How people feel about MLs vs. FMLs, and whether to combat squad the unit splitting the heavy weapons up essentially for spliting fire purposes. Tank Hunter makes 4 shots overkill in a few circumstances.
If it's worth it to give the Libby the SE for EW. 4+ Deny the Witch rolls are nice, but I rarely if ever face someone who uses psykers at this point.
and most importantly:
What to do with that remaining 130 points!
The special weapons for the Tacticals will come out of that, but even then I'll have almost 100 points left. I do generally face a lot of fliers, and have considered buying a Hunter tank to hang out with the Dreadnought and Devastators behind the ADL.
Thanks!
40k Army Projects
Industrial Table WIP
ntaw is offline
post #2 of 7 (permalink) Old 10-21-13, 08:57 PM
Lord Pestilice's Avatar
Lord Pestilice's Flag is: USA
What about a Thunder Fire Cannon?
What do you mostly face on the battlefield when playing your local group? Knowing this will give us a better idea of what to advise.
Lord Pestilice is offline
post #3 of 7 (permalink) Old 10-21-13, 09:06 PM
Xabre's Avatar
Xabre's Flag is: USA
Have you considered turning your Rhinos into Lascannon Razorbacks? I don't know if you plan to rush the squads, or maybe combat squad them... the Razorbacks will give you some anti tank that you're lacking. I'd suggest kitting the Tacticals with meltagun/Missile Launcher... Keep the half with the ML back, like on the Aegis (someone has to man it), and use the forward group with the close range MM in the Razorbacks... though admittedly the Lascannons can hide in the back.
Xabre is offline
post #4 of 7 (permalink) Old 10-21-13, 09:37 PM Thread Starter
ntaw's Avatar
I have considered this, but am still on the fence. Mostly because:
I don't face horde armies. Most often, MEQ in the form of other marines or chaos marines. On occasion I face IG, Tau, and Necrons, but not often enough to warrant buying a new model for such an occasion to arise. I've been contemplating changing the arms on the Dreadnought to accommodate a higher rate of fire. What do you think of that idea?
I could easily do this, as the Rhinos are on loan from my BA and I have pretty much two of every turret aside from las/plas (only one until I really want to make another) and heavy flamers (none. I think this is a bad option). My thing with using the Rhinos was to keep the squads at full strength, it's hard enough not getting squads that large wiped away by Heldrakes or Vindicators.
-OR- I could use two five man devastator squads, one MLs and one LCs. What do you think of that option? Keep in mind I have 130 points to spare here, more if I drop half of the ML Devs.
Even if I'm not combat squadding them? I get two weapons shooting out of the top hatch, so if I'm not mobile that turn I can still take a heavy weapon shot. Plus I really use transports to hinder LoS if they make it to the late game objective grabs.
The Devastators will be manning the ADL. Tank Hunter with a twin-linked skyfire/interceptor weapon? Yes fucking please.
40k Army Projects
ntaw is offline
post #5 of 7 (permalink) Old 10-21-13, 09:55 PM
Xabre's Avatar
Keep in mind that if your Devs are manning the ADL, you could lose use of half your firepower depending on what you're shooting at. Without Flakk, if you Skyfire, you might be wasting missiles on snapshots, or not firing at all. What I'd suggest if you want to use the Devs is to Combat Squad the Devestators, OR grab a 5man squad of Autocannons, and use that one with the Aegis. that way at least all the firepower is similiar, you have some throw away wounds, and your missile launchers are still doing missile'y things at all times.
Another option, which was never mentioned, is going with a Stormraven over the Crusader.
Xabre is offline
post #6 of 7 (permalink) Old 10-21-13, 11:26 PM Thread Starter
ntaw's Avatar
My thought process here:
T1: no fliers, no problem
T2: if fliers enter, interceptor means I'm not firing next turn and if they don't show up then no problem
T3: see T2
T4/T5: by this point my opponent has either closed in on that squad and I have other priorities or I've wasted what I need to waste and no longer care about snap shot-ing 4 heavy weapons.
Conversely, what I have considered doing is doing a ten man squad w.2x LC and 2x FML and CSing them so there's two heavies in each CS. That way the Flakk can man the QG and the LCs can do what they do, both with 3 marines as meat shield (yes, the sergeant is included in this even though he has a Signum). What do you think about that?
This can't happen, ACs aren't available to SM Devastator squads.
I don't feel like Stormravens fit in with IF, and the two that I have are most certainly staying BA oriented (one's painted, the other I keep in a drawer until game time because of how long it took to paint the first one). Also, with a LRC I have the ability to charge T2 if my opponent moves forward. With the SR the soonest that is happening is T3 if you Fly on the board...and really, why the heck would you not so early in the game and IF the SR comes in T2.
Back to the Tactical squads for a moment:
I'm torn on even taking a heavy weapon. I would really like to rely on other things to do armour damage, and leave my Troops to shred other Troops. I was thinking of leaving them all bolters and only taking a PG for the squad in case some TEQ/CC threat gets up in my grill. This means I'm never losing shots to Snap Shots on the move and I take the most advantage of Bolter Drill with the few guys with bolters. It also limits their effective range to 24/12", but hey. That's what the Rhinos are for. Thoughts?
40k Army Projects
ntaw is offline
post #7 of 7 (permalink) Old 10-23-13, 01:03 AM Thread Starter
ntaw's Avatar
Just a revamped list with some of the things we're talking about in mind:
Originally Posted by ntaw View Post
ELITES
Dreadnought w/ TLAC, TLLC
TROOPS
2x 10 man Tactical squads w/ PGs in Rhinos (if I can get another melta gun I will A/B them for sure)
HEAVY SUPPORT
10 man Devastator squad w/2x FMLs, 2x LCs
FORTIFICATION
ADL w/QG
I would CS the Devastators so the Flakk was manning the QG. Dreadnought with TLLC and the LCs in the Devs boost my ability to punch armour, the melta guns in the Tacs I would feel stronger about if I was facing AV14, but at most these days there's a bit of AV13 and mostly AV12 with a side of 11. This leaves me with 25 points. Is there any improvement over the initial list?
40k Army Projects
ntaw is offline
