skaven 1650 points - Wargaming Forum and Wargamer Forums
post #1 of 4 (permalink) Old 04-14-10, 08:18 PM Thread Starter
jacktmorgan's Avatar
Default skaven 1650 points
LORDS & HEROES
queek headtaker-215 points
grey seer (screaming bell)-440 points
deathmaster snikch-270 points
CORE
20 clanrats (8 spears, 20 shields,clawleader)-102 points
20 clanrats (6 spears,20 shields,standard bearer,clawleader,screaming bell)-109 points
9 giant rats (packmaster)-35 points
SPECIAL
2 rat ogres (2 packmasters)-96 points
20 plague monks (standard bearer, plague priest)-243 points
RARE
doomwheel-150 points
total-1660
Ive only been playing skaven for a month so any comments would help
jacktmorgan is offline
post #2 of 4 (permalink) Old 04-15-10, 08:13 PM
Torpored's Avatar
Torpored's Flag is: USA
Well, lot is going to depend on the army size you are attempting to build. A list cannot contain a lord level character until 2000 points and then only one.
As a general guideline I would recommend the addition of some clanrat slaves. I run 100 at 2250 but a few more or less can work depending on your play style. The key to using slaves, and ice found most skaven units is to just consider them all throw away units. For the most part everything is expendable. The trick is then it making the sacrifice work for you by opening up a flank or taking away rank or even just giving you the charge.
All the time I have now, hope you find that helpful. There are lots of good tactics articles on the web
Torpored is offline
post #3 of 4 (permalink) Old 04-15-10, 08:19 PM
Creon's Avatar
Creon's Flag is: USA
Originally Posted by jacktmorgan View Post
LORDS & HEROES
Too many points in Lords/heroes. Grey Seer and bell, 2 warlock enginseers, and a BSB are more appropriate at this level of points. You do need 2000 to field a Bell.
CORE
Put all of these into one group for pushing the bell. More rats is better for bellshoving. Add 2 30 rat slave units to fill out the troops requirement.
More rats is better for this. Take the special character upgrade here.
SPECIAL
Too small, eliminate or double in size
RARE
Add Hellpit abomination. No question, best piece in the army
total-2000
Creon is offline
post #4 of 4 (permalink) Old 04-15-10, 09:01 PM
Barnster's Avatar
Barnster's Flag is: United Kingdom
Can't field a Grey seer, hes a lord choice no lords till 2000pts same with Queek i think You can take up to 3 chars before 2000 none can be a lord at 2000pts you can get up to 4 chars up to 1 of which can be a lord
Look at your making an army list instructions Same with your core choices.
You can't give a couple of clanrats spears the whole regiment must be equiped the same. you even have to pay for the command group to have them.
20 clanrats are too small to be a viable unit 25 minimum if you want them to do anything
Barnster is offline
Go Back   Wargaming Forum and Wargamer Forums > Warhammer Fantasy Battles & Age of Sigmar > Warhammer Armylists > Skaven Army Lists
