Some of my terrain projects. - Wargaming Forum and Wargamer Forums
post #1 of 3 (permalink) Old 09-16-10, 04:12 AM Thread Starter
Model Soldier's Avatar
Model Soldier's Flag is: United Kingdom
Default Some of my terrain projects.
As promised in my introduction post...
Three examples of the trees and rocks formations I've built including a close up of the rock paint detail.
Rocks were made from carving polystyrene into the desired shape, painting dark grey then dry brushing with a lighter grey to pick out the details. Once dry, I washed them over with a really watered down silver then gently dabbed/dried with tissue to give a mineral ore 'sparkle' (not brilliantly shown in pictures sadly).
Trees are standard shop bought.
My bunker/stronghold made using the polystyrene packaging from a small remote controlled helicopter.
First, I trimmed the mould flashes off the polystyrene then coated the polystyrene entirely with a thin (ish) layer of PVA glue and covered entirely with fine builder's sand, left to dry, then I repeated the process with a slightly watered PVA for a second layer of sand.
Once dry it becomes hard as concrete, then I based it onto grass covered card and added the upper roof level, bushes, barbed wire and ladder etc etc.
This is the first thing I ever built about 10 years ago, using the sand covered polystyrene and the polystyrene rock techniques I mentioned above.
The step slabs were made using cut and trimmed foam card and different sized sand from the builder's sand.
This is my current experiment. Building trees from polystyrene and PVA glue. It's currently my favourite experiment.
This tree isn't finished yet but is actually only one piece of polystyrene.
Firstly, I cut, trim and bend a piece of polystyrene into the desired shape, painted with a dark brown then left to dry. Then I covered the entire thing with a very generous layer of PVA glue and left to dry again.
Once the PVA was dry I painted with a single coat of light brown.
As that layer of light brown dried, it cracked the PVA and revealed the dark brown undercoat, giving a treebark effect. A very satisfying result I think.
Model Soldier is offline
post #2 of 3 (permalink) Old 09-22-10, 09:46 AM
Where is Jessica Hyde?
humakt's Avatar
humakt's Flag is: England
The cracked bark effect is brilliant, although the tree looks alittle thick limbed currently. Maybe this will look better once it has foilage added.
Some nice pieces here. I like the steps upto the stading stones, and I like you stone painting technique.
humakt is offline
post #3 of 3 (permalink) Old 10-13-10, 02:05 AM Thread Starter
Cheers mate, I need to get some foliage together for the tree.
When I've done it I'll post up some piccies.
The bunker is definitely my favourite finished piece.
Took me about 5 days to build.
The main problem with using PVA is waiting for it to dry.
If it dried quicker, I could have easily churned out the bunker within a day, maybe two.
