Critique for da CriticGod
*Hats off*
I have a lot of respect for folks willing to tackle really ambitious conversions and sculpting projects. I feel like there's something kind of off with this guy. But I'm having trouble putting my finger on what it is.
I really like the multi-armed and multi-headed design. I think that's really working.
The cabling and exposed bones/vertebrae are also working well.
I'm lukewarm on the chaos shields. They seem too tidy and smooth compared to the texture of the daemon himself. And with the disorder of the models appearance the repetition seems out of place. Perhaps you can rough up the edges, or changed the shields overall silhouette?
There weapons (spear and knife) where the handle and blade don't continue through the hand in a smooth straight line look sloppy, and distract from the rest of the model.
I'm also on the fence about the big jagged tank ram-bar weapon. It looks wickedly evil and thoroughly unpleasant, but it might be too big compared to the rest of the model - or it might not . . . still on the fence.
I think there's something awkward in belly/going area. I think compared to other great unclean ones the legs are comparatively long, and the belly comparatively small. I think the overall belly proportion is what seems the most off to me. Can you bulk it up more without losing some of the good detail (the extended arm, guts, etc.)?
Yeah, its the belly. the more I look at it the more sure I am. I think compared to the heads, arms, and legs the belly is undersized - especially considering regular nurgle daemons, it a part of their look. If the belly got bigger that might help balance out the huge weapon too.
If the belly gets bigger and its lower edges moves toward the 'ground' I think the belly/leg proportion issue will be solved.
Keep up the good and adventurous work! I know Ilve tried a few major projects like this and whether I finished them or not, all the work and thinking and problem solving made me a better modeler and sculptor!
I can't wait to see this guy completed!
Cheers,
Kreuger
p.s. - What tools are you using? Based on the textures you've made I'm guessing a cocktail stick or otherwise pointy dental tool, and an x-acto knife. If you need a quick/cheap set to get going to further heights of scuklpting goodness I'd recommend http://www.amazon.com/SE-Pick-Set-12Pc/dp/B000SVRSRY/ref=wl_it_dp_o?ie=UTF8&coliid=IRFCZPY6RNP1R&colid=2Y3ASBVZNDZIX. They're aren't perfect, and sometimes have some divets or burrs on their edges. Burs are easy enough to smooth out with a needle file, and the tiny divets haven't caused me any problems. And they're very affordable.
