Lupus In Fabula - Warhound Titan of the Legio Tenebris - Wargaming Forum and Wargamer Forums
post #1 of 17 (permalink) Old 07-14-10, 12:31 AM Thread Starter
the.alleycat.uk's Avatar
the.alleycat.uk's Flag is: United Kingdom
Default Lupus In Fabula - Warhound Titan of the Legio Tenebris
So, the project I've been waiting for having gotten my hands on a Warhound Titan [justified by using money i made selling a load of minis on ebay;] picked up an airbrush and practised using it on a valkerye.
Now i've wanted on of these, like, forever so I wanted to the best job possible. To that end I made sure i'd have the tools i might need and was sure to clean flash, dry fit, clean the resin and check carefully for miscasts before I started.
I'd a colour scheme in mind based around a Titan Legion who's forgeword is from a system i'd invented for my homebrew marines, guard armies [still very much WIP lol.]
Hence the Legion Tenebris; motto: Lux ex Tenebris.
The Warhound's name: Lupus in Fabula [Speak of the wolf and he will come]
I'll admit the colour scheme changed slightly at the 11th hour. But i'm pleased with where things are going.
There is a rever Titan log on the go atm and I have to admire how helpful the real step by step stages are; sadly I'd started to document this project before that and i've no captured each stage as well, apologies for this.
Anyways, cleaning etc out the way, the first stage of assembly is the feet and legs. I'd heard horror stories but actually this part was pretty easy if a little time intensive siomply to finish the feet.
You do need to plan/dryfit carefully though as there are a couple of points where you could glue stuff and make life really difficult adding some of teh pistons. [The instruction pamphlet really isn't that helpful.]
It also should be said that I did end up with one foot further off the ground than the other. In retrospect this has caused me to make a better base than I would have... but does illustrate that you need to pay attention when gluing. So despite being for the best in this case was a definate learning experience.
[Resin and superglue adhere REALLY well due to the porous nature of the resin, this means that it forms serious binds which are less likely to break than the resin itself... once glued, things are pretty much stuck so do take care.]
So, first set of shots, the legs and feet assembled.
[BTW, my images seem to upload really large, it there a way to resize in the browser?]
And here are the parts for the torso, already part assembled with the interior undercoated so I can paint the interior before assembly. This is so on the full assembly I can fill any gaps, and sort any problems before undercoating the exterior.
the.alleycat.uk is offline
post #2 of 17 (permalink) Old 07-14-10, 02:12 AM
ClassyRaptor's Avatar
ClassyRaptor's Flag is: Australia
Location: Chamber Of Solitude, Aboard The Mortifer Umbra
Very nice, can't wait to see it finished.
ClassyRaptor is offline
post #3 of 17 (permalink) Old 07-14-10, 08:42 PM Thread Starter
Ok, as mentioned, due to the issue with the legs, i needed to make a two level base for the titan. A quick order to BitsnKits [arrived very quickly, not sure if the plea I included in the messages panel had an impact but it was super quick ] for basing materials.
Now i've not used platicard and foamboard before but it turned out to be very easy to sort out with a stanley knife. I sealed stuff in with filla since I remember a friend saying that foamboard can melt when sprayed. Here are the shots of the base planning and assembly.
I wanted a road section and figured that dampened green flock plus levelled filla would give a tarmac [aphsalt for americans] like finish. This actually turned out all right.
And painted with the airbrush:
Then Time to start the interior. Wanting to add some variety to the colour of dials and guages I decided to do them all grey scale, so I could do them all at the same time. This will then be coloured with inks/washes.
And finally, because the titan comes with four grieves and therefore effectively 'spares'; I ran a test piece for the check pattern I want on a couple of parts of the armour:
post #4 of 17 (permalink) Old 07-14-10, 11:27 PM
Angryman
shaantitus's Avatar
shaantitus's Flag is: Australia
Location: A wretched hive of scum and villany. Actually PNG. Goddamn this place is a shithole.
Greyscale gauges. Clever. Nice work on the chequer pattern, tidy. What was the issue with the legs that required the split level base?
Sorry just noticed, glue error, they can be a bitch. Especially with the complex leg arrangement of the fw titans.
Sanity is for the weak.
'Evil will triumph because good is dumb.' Dark Helmet,Spaceballs
According to LUKEVALENTINE's test i am a diciple of khorne. Figures really.
shaantitus is offline
post #5 of 17 (permalink) Old 07-14-10, 11:37 PM
Dazed and confused.
Khorne's Fist's Avatar
That checker pattern is realy impressive. Can't wait to see the finished article.
Khorne's Fist is offline
post #6 of 17 (permalink) Old 07-14-10, 11:45 PM Thread Starter
Glue error was largely due to me assembling that part in my lap at the computer desk... couldn't be bothered to move the three feet to a large flat surface... It looked straight at the time lol.
The most annoying issue was actually that on of the toes actually contracted back and ended up slightly raised from the others but this happened after about a week when a couple of paint layers had gone down and there was little that could be done to sort it.
It'll be noticable in the later pictures.
post #7 of 17 (permalink) Old 07-30-10, 03:36 PM Thread Starter
Heh, so a bit more delayed than planned, here are some more pictures.
Legion symbol, pretty pleased with this:
And some painted interior shots:
post #8 of 17 (permalink) Old 07-30-10, 03:42 PM
LTP
LTP's Avatar
LTP's Flag is: England
Ok firstly OMG is that gonna be purple? :D I love what you have done so far, i think im getting Reaver tunnel vision so its great to see someone who has a warhound showing it off .
Keep up the great work and well done on the freehand eclispe im doing a similar thing on the reaver so any tips would be appreciated.
Have some rep buddy
LTP is offline
post #9 of 17 (permalink) Old 07-30-10, 03:59 PM
Tzeentch laughs at likely
Dave T Hobbit's Avatar
Very well done; is that sprayed or brushwork?
Dave T Hobbit is offline
post #10 of 17 (permalink) Old 07-30-10, 04:40 PM
BearsofLeon's Avatar
OMYBUJEEZY. I love that moon. It is fantastic. And the purple...LOOOOVING it.
sorry if that was weird, im realluy excited for the end product.
For Lorgar! For Mortarion! Death to the False Emperor!
My WIP log. Check it out. C&C wanted.
https://www.heresy-online.net/forums/...ad.php?t=67915
BearsofLeon is offline
