Blackadder Attempts to build an Imperial Warmonger Titan - Page 8 - Wargaming Forum and Wargamer Forums
 265Likes
post #71 of 393 (permalink) Old 06-25-17, 12:55 AM Thread Starter
Blackadder's Avatar
Blackadder's Flag is: USA
A Broken Precedent.
I don't usually do this but it seems such a 'gimme' that I am running it by without testing the concept.
http://i.imgur.com/hxXUwqf.jpg
I want the neck to be movable on both axes' up /down and side to side and I went to great lengths to accomplish that with my Warlord.
http://i.imgur.com/05bFt6y.jpg
With the Emperor Titan I have a lot more room so I'm trying something different. A 3 inch to 2 inch PVC reducing coupling which gives a 20 up/down and side to side flexibility.
http://i.imgur.com/gDjQ7cZ.jpg
In the coming days I'll show how this works out but in the meantime I intend to show the interim work for better or worse because once done it will be difficult to reproduce.
http://i.imgur.com/FOnI1Gv.jpg
Old Man78 likes this.
Blackadder is offline
post #72 of 393 (permalink) Old 06-25-17, 08:57 PM Thread Starter
Blackadder's Avatar
Neck Articulation:
This was so much easier than the engineering gymnastics I had to go thru with the Warlord articulation. After stripping down the head to the basic neck components all it required was drilling four holes and threading them with a 6-32 tap. I countersunk the outer holes for flat headed screws.
http://i.imgur.com/unU2vdq.jpg
I then made a collar for the neck to slide into and mounted it into the middle deck forward bulkhead. Not glued because I want to be able to disassemble the model for painting and upgrading. Everything is as close a tolerance press fit as I can make it.
http://i.imgur.com/CCUVtMC.jpg
Centering the neck in the outer ring I secured the screws.
http://i.imgur.com/0hombQK.jpg
So after all that work I got about a 15 to 20 downward tilt to the neck.
http://i.imgur.com/AwOfNFl.jpg
Sliding the assembly together gives an idea of what the finished model will be able to do by way of articulation.
http://i.imgur.com/7rEDYH1.jpg
http://i.imgur.com/9i3annL.jpg
After reassembling the head I'll be able to see how much more downward angle I can add if needs be.
post #73 of 393 (permalink) Old 06-26-17, 07:53 PM Thread Starter
Blackadder's Avatar
Hate Mail:
I'm gonna get a lot of hate mail because this damned thing works perfectly and no one is more surprised than I am.
http://i.imgur.com/l8yW8Fd.jpg
The range of motion is still rather limited but after I get the breast plate detail completed I can increase the range up/down and side to side by I'm guessing at least double.
http://i.imgur.com/QMaF2j6.jpg
I'm hoping to reassemble the head today so I can test out the balcony clearance.
http://i.imgur.com/TR2NsNa.jpg
It's really fun to sequence these thru my image viewer. Ha!
http://i.imgur.com/fJff7vh.jpg
http://i.imgur.com/fERhbZC.jpg
This mechanism is actually a two axis gimbal.
post #74 of 393 (permalink) Old 06-26-17, 11:01 PM Thread Starter
Blackadder's Avatar
Amendment:
Because of my fixation on having a railed promenade for my Tech Priests I mounted the head higher than the You tube Video Imperator.
http://i.imgur.com/LubKGr5.jpg
Since my version has a dynamic structure I feel the snaky conduits are out of place and the chin armour is too close to the deck.
http://i.imgur.com/PltSEDM.jpg
There is no need for the cramped claustrophobic appearance when all the space above is free to interpretation.
http://i.imgur.com/m4wYGvX.jpg
Of course I may just have added another 5 centimeters to the overall height.
post #75 of 393 (permalink) Old 06-27-17, 06:39 PM Thread Starter
Blackadder's Avatar
A Matter of Scale:
A side by side comparison with my Warlord. Egad this thing will be huge.
http://i.imgur.com/p3iP5PD.jpg
post #76 of 393 (permalink) Old 07-01-17, 08:06 PM Thread Starter
Blackadder's Avatar
A Yard Stick Won't Be Enough:
I'm beginning to think that even a meter is too conservative an estimate for the height of this behemoth.
http://i.imgur.com/cBNuX3z.jpg
The yardstick as presented indicate the 27 inches tall my Warlord stands.
http://i.imgur.com/qPPFq0U.jpg
The Triangular shoulders represent the width of the platform the cathedral superstructure sits on so even with out the legs the yardstick comes up short.
http://i.imgur.com/oFxMq13.jpg
The closeup of the passage to the Cockpit from the command deck.
http://i.imgur.com/3GBtkIb.jpg
Looking down at the upper reactor room
http://i.imgur.com/K4ofb9U.jpg
And a bird's eye view of the titan as it is today.
http://i.imgur.com/uWgWhC9.jpg
post #77 of 393 (permalink) Old 07-05-17, 11:00 PM
SwedeMarine's Avatar
SwedeMarine's Flag is: Sweden
Nice to see you haven't lost your touch! do you plan on detailing the interior of thisbeyond the cockpit as well?
W:9 D:2 L:5
SwedeMarine is offline
post #78 of 393 (permalink) Old 07-06-17, 11:20 AM Thread Starter
Blackadder's Avatar
As far as practical I intend to manufacture an entire interior the same as my Warlord.
Iraqiel and SwedeMarine like this.
post #79 of 393 (permalink) Old 07-06-17, 05:02 PM Thread Starter
Blackadder's Avatar
Cities of Death Bitz:
When I first started this project I stated I would be relying heavily of Prefab Bitz so as to make this model more accessible to would-be modelers. I fully expected readers to be able to make their own Emperor Titans following my examples. Certainly there are no big secrets revealed in this construction
The problem I see in most Emperor Titans that employ bitz is a lack of imagination. You cannot use the pieces directly out of the box. Witness below.....
http://i.imgur.com/h72NPQJ.jpg
The flying buttresses as they come out of the box have little application to speak of in this area of the Titan but with a bit of judicious cutting and filing they find purpose.
http://i.imgur.com/dbpQ3LL.jpg
Likewise the area below the 'head' calls for a processional egress onto the balcony/podium/pulpit.
http://i.imgur.com/vfLQMxj.jpg
Of course this is all subject to interpretation, You might have reservations about a huge vulnerable door in the front of the chest, I do myself but nothing is etched in stone and I may change my mind in the future but something is better than nothing so I'm going for it at this moment.
post #80 of 393 (permalink) Old 07-06-17, 06:14 PM
As a thought, if you fill in the seams running down the middle of the door then it can function simply as a decorative piece and not an entryway. I tend to agree that smaller hatchways on the sides might be more appropriate.
W:9 D:2 L:5
