Blackadder Attempts to build an Imperial Warmonger Titan - Page 36 - Wargaming Forum and Wargamer Forums
 260Likes
post #351 of 385 (permalink) Old 03-25-19, 04:22 PM Thread Starter
Blackadder's Avatar
Blackadder's Flag is: USA
First Inkling:
Today I got my first inkling of this model in it's entirety. Up to now I've manufactured separate components but the overall magnitude escaped me. Now I see the full scope of it's height which will be about 5 feet tall so scale-wise at the 25/28 MM the model will stand 336 to 360 feet tall or (102 to 110 meters tall.)
https://i.imgur.com/NFxfldf.jpg
I'm assuming the uppermost spires to add an additional eight to 12 inches to the overall height.
https://i.imgur.com/xha4k2k.jpg
Although some might call that cheating :D
https://i.imgur.com/g5wNzMc.jpg
Tomorrow I plan to have the other Barbican completed
https://i.imgur.com/ooaxrJE.jpg
and with luck reassembled with the legs again.
Old Man78 likes this.
Blackadder is offline
post #352 of 385 (permalink) Old 03-27-19, 08:50 AM
Closet Dictator
Old Man78's Avatar
Old Man78's Flag is: Ireland
Superb, simply superb.
Old Man78 is offline
post #353 of 385 (permalink) Old 03-27-19, 11:02 AM Thread Starter
Blackadder's Avatar
These complex structures are amoung the most difficult I have built for this Titan. Considering they will have to bear little weight in comparison they are extremely over built.
https://i.imgur.com/MKAMJX8.jpg
Compounding this the corner towers are octagonal in shape. This does not lend itself readily to the square grid material I have chosen for the substructure. Compensations in the structure have to be made to make the cross section conform to the octagonal shape.
https://i.imgur.com/ofpjp2n.jpg
The top of the Barbicans will have either spires which will increase the height to around 60 inches or AA laser cannon emplacements which will decrease the height to somewhat less; about; 54 inches as far as the Barbicans are concerned.
https://i.imgur.com/2bPuKBl.jpg
The main Keep will be another story.
post #354 of 385 (permalink) Old 03-27-19, 01:59 PM
Closet Dictator
Old Man78's Avatar
Go for AA weapons, as it is those barbican substucture look like micro versions of the Berlin flakk towers. I personally always thought the gothic spires took away from the warlord class
post #355 of 385 (permalink) Old 03-31-19, 10:50 AM Thread Starter
Blackadder's Avatar
Sanctum Sanctorum:.
Awright no comments on the man-cave.
https://i.imgur.com/MBOgm4T.jpg
As you may have gathered I'm single. Who else could dump thousands on stuff I should have outgrown ages ago but hey, I love working on this stuff. Prior to this I built 18th century American warship models plank on frame wood..... but that's for another area of FB
I find styrene a much easier medium to work with and my son was an avid player so Dad obliged him.
I spent the better part of the week building the components seen here. That and my current occupation of President of my Condominium.
https://i.imgur.com/aQgITmu.jpg
The octagonal column center of the image above represents my third attempt to make this part, successfully (Finally) I might add. The secret was, "there are no shortcuts to a quality representation." Eventually I must learn that.
The image below show the basic work of the remaining seven columns waiting in the wings for the success of the first.
]https://i.imgur.com/bSP02tN.jpg
My apologies for the crudeness of the construction appearance but the basic shape is all I need for the present. The polish and detail will come later.
post #356 of 385 (permalink) Old 04-03-19, 09:07 AM Thread Starter
Blackadder's Avatar
Corner Towers Done......
The basic octagonal structure that is. There are still two levels of surface detail to apply but aside from the AA cannon emplacements this will be the height of the Imperator version of this Titan.
https://i.imgur.com/z7u8CZ9.jpg
I'm so confused as to what the seemingly interchangeable names and classes of the Emperor Titans. Initially I set out to build a Warmonger version to match my Lucius Warlord and Warhound (seen here for scale). Lucie was my first major scratchbuild project and she is slightly more robust compared to the Forge World Warhound Version.
https://i.imgur.com/B8BcNAW.jpg
This aerial view gives a better perspective of the upper deck.
https://i.imgur.com/SV2cXJw.jpg
And finally a head on shot with the various Adeptus Mechanicus Skitarii slated to infest the upper works of this monstrosity.
post #357 of 385 (permalink) Old 04-04-19, 12:20 AM
Composite Image:
I've been asked to put this together for an overall image of the work thus far.
Well it's too tall for the work console I have to stack the two major components, legs and torso, plus the whole thing is front heavy at the moment with none of the rear counterweights installed; I'm figuring the completed model will weigh in the neighborhood of two Bowling balls overall weight when finished; i.e.32 pounds or about 14.5 kilo.
https://i.imgur.com/aoOOzdX.jpg
The only other leastwise finished component is the Sunfury Plasma Annihilator which also cannot be mounted until the top and bottom body sections are together.
https://i.imgur.com/D6Tumkw.jpg
But my clumsy photo editing can give you a general idea of where I am heading with this construction.
The Questor is offline
post #358 of 385 (permalink) Old 04-15-19, 10:23 AM
Emperor Titan Pelvic Block:
My obsession with having the option of posing my creations has worked out previously, My scratchbuilt Warhound, Warlord, Thunderhawk and Reaver have the ability to be positioned an virtually any configuration even beyond that which is mechanically sound in practice.
With this newest model I hoped to carry on the tradition but it did open up areas of concern. I designed this model to have no swivel fore and aft as in the Warlord and Warhound. I calculated the weigh of the model above the hips would collapse the hip joints were I to attempt functioning ball and socket joints as I did with the other two Titans.
https://i.imgur.com/c9K9SzG.jpg
With that resignation I began the Pelvic Block this weekend.
https://i.imgur.com/iFhj62W.jpg
My original Pelvic Block seen here was naively small compared to the 1.66 meters tall construction this has evolved to. My original estimate of the height was on the order of a meter tall.
https://i.imgur.com/KP3BAfB.jpg
post #359 of 385 (permalink) Old 04-15-19, 02:40 PM Thread Starter
Blackadder's Avatar
Yesterday Morning:
The Pelvic Block was about 4 inches square. Now it is about 6 inches by 4 inches and the basic shape is established.
https://i.imgur.com/bGo5EXn.jpg
This side view show the shape of the original Block
The Lower Body Turntable seated above the Block
https://i.imgur.com/U3z32B8.jpg
And the Turntable and Block temporarily installed on the Hips
https://i.imgur.com/xMgbYqm.jpg
This thing literally fell together last night......
https://i.imgur.com/COXuhg8.jpg
Such is the power and convenience of using this waffle material.
I really love this stuff. Not only is it cheap but it virtually removes the problem of squaring up and truing the angles on large constructions. I could never afforded to build this Titan without this material.
post #360 of 385 (permalink) Old 04-15-19, 03:04 PM
Closet Dictator
Old Man78's Avatar
1.66 meters tall, that is a pure beast of a model, that's up to my nose! I don't cast a particularly long shadow
