Blackadder Attempts to build an Imperial Warmonger Titan - Page 33 - Wargaming Forum and Wargamer Forums
 265Likes
post #321 of 393 (permalink) Old 09-05-18, 03:15 PM
Closet Dictator
Old Man78's Avatar
Old Man78's Flag is: Ireland
Personally I would avoid making the close combat claw for the emperor titan, it really is a dedicated ranged weapons platform and too slow to be getting into a fist fight, of course, you could always use it on your warlord and it does look cool.
Old Man78 is offline
post #322 of 393 (permalink) Old 09-05-18, 03:19 PM Thread Starter
Blackadder's Avatar
Blackadder's Flag is: USA
It Really only has one purpose; to punch a Mega-Gargant in the face.
Old Man78 likes this.
Blackadder is offline
post #323 of 393 (permalink) Old 09-05-18, 04:08 PM
Closet Dictator
Old Man78's Avatar
Well as one of my sergeants used to say "..if you're gonna be a bear, be a grizzly!"
post #324 of 393 (permalink) Old 09-08-18, 12:32 PM Thread Starter
Blackadder's Avatar
Weekend Update:
I had hoped to be further along in the rear mechanisms by now but I ran into a bit of a snag when I realized the the rear section of the weapon expanded further than the surface armour surrounding the mount disk. Since my gun is wider overall than the Warlord weapon I have decided to not expand this section unless I see the overall appeal of the Plasma Blaster is compromised.
https://i.imgur.com/opWDHf4.jpg
Another modification is the rear mount must also be removable and be able to slip onto the mount disk assembly which should pose no problem but was something I had not anticipated.
https://i.imgur.com/xFNOLgE.jpg
Now that that is recognized I can proceed with the actual manufacture of the rear sections.
post #325 of 393 (permalink) Old 09-16-18, 04:44 PM Thread Starter
Blackadder's Avatar
One Week Later:
It's been a busy week but I managed to fit in a bit of building. The biggest accomplishment is a second Arms Mount section for the other armament items.
https://i.imgur.com/9yj9h3H.jpg
It is a source of irritation to me that each of these disc mount appendages seem dedicated to a particular weapon so hopefully I can circumvent this need for redundancy by making a generic disc and adding a discrete weapons module pack for each weapon I produce. The Discs are really time consuming to make.
https://i.imgur.com/6MMTHmi.jpg
https://i.imgur.com/axub5XT.jpg
So above we have the Plasma Blaster modular assembly that slips together as two pieces and subsequently in the image below the sections installed on the Plasma blaster body......
https://i.imgur.com/InJMOrY.jpg
https://i.imgur.com/G4yHwBI.jpg
Next the Meta Snail module...........
post #326 of 393 (permalink) Old 09-17-18, 10:10 PM Thread Starter
Blackadder's Avatar
Cochlear Implant:
I'm frequently asked how I develop a construction from just images on a computer screen. and I suppose this is a prime demonstration candidate. the Cochlear shaped reactor core at the back end of the Plasma Blaster. Since I already had the disc mount assembly it was a simple matter of transporting the dimensions off the disc to the rectangular grid material and eyeballing the divisions on the screen I used my compass to define where the concentric components would be arranged.
https://i.imgur.com/EWLsQftl.jpg
Using the mount block module I made a U shaped construction of the apparent size of the basic structure and alternately layered 0.040 inch sheet styrene with the same sized grid material until I had a sufficient thickness with two left pieces over for the final rough detail.
https://i.imgur.com/K31AUOk.jpg
https://i.imgur.com/U3NwU5K.jpg
So finally we have the size of the complete weapon realized at least in the rough.
https://i.imgur.com/AzHRLlZ.jpg
and now I can take on the actual upper mount arm............
post #327 of 393 (permalink) Old 09-18-18, 03:24 AM
Closet Dictator
Old Man78's Avatar
Watching you create never gets old, great stuff old boy!
post #328 of 393 (permalink) Old 09-18-18, 07:38 PM Thread Starter
Blackadder's Avatar
That's About the Size of It:
I finally can appreciate the size of this construct and I am revisiting my anxiety over the scale Vis--vis the actual Titan.
https://i.imgur.com/XLL36Aw.jpg
https://i.imgur.com/990xV1i.jpg
https://i.imgur.com/vchVYlh.jpg
https://i.imgur.com/KNciCjg.jpg
https://i.imgur.com/htf5EPr.jpg
It seems about right................
post #329 of 393 (permalink) Old 09-21-18, 05:01 PM Thread Starter
Blackadder's Avatar
Just a Quick One Today:
Working on the reactor coil (whatever) It's a complex piece of machinery with a lot of delicate parts. The Plastic cement eats through the curved 0.040 inch square stock instantly so I had to use 0.5 inch tubing for the ends of the slots.
https://i.imgur.com/IBhq3II.jpg
It seems to work okay.
post #330 of 393 (permalink) Old 09-27-18, 11:21 PM Thread Starter
Blackadder's Avatar
When Will There Be An End?
I am so sick of this weapon. It's like pushing a snowball uphill. The bigger it gets the harder it is to push it further...
https://i.imgur.com/67h9Z7P.jpg
My only consolation is; the rest of the weapons will be a piece of cake in comparison......
https://i.imgur.com/6wvPzCp.jpg
The reactor core is almost complete, I need only add 13 more silver coils and the rest will be eyewash.....
https://i.imgur.com/ZY6Yr3Z.jpg
Last night I built the obverse side and am about ready to install the silver coils on it as well.
