Blackadder Attempts to build an Imperial Warmonger Titan - Page 31 - Wargaming Forum and Wargamer Forums
 260Likes
post #301 of 385 (permalink) Old 08-02-18, 12:07 PM Thread Starter
Blackadder's Avatar
Blackadder's Flag is: USA
A Week's Worth Of Labor:
At this rate I'm wondering if my estimate of another year in the making is a trifle optimistic.
https://i.imgur.com/I539NPV.jpg
Old Man78 likes this.
Blackadder is offline
post #302 of 385 (permalink) Old 08-04-18, 05:58 PM Thread Starter
Blackadder's Avatar
Annihilator Muzzle:
I bit the bullet today and expanded the muzzle channels to what I believe is the proper width and depth.
Here seen in the original which is too cramped and closed in. Note I also have made allowances to extend the length of the muzzle.
https://i.imgur.com/JMqUhMZ.jpg
The muzzle ( temporarily ) installed now appears to have enough room for all the detail although I still have to jimmee the length a bit.
https://i.imgur.com/HqQ93BH.jpg
End on although crudely sanded at this point and a tad asymetrical
https://i.imgur.com/e3hwYvT.jpg
The top view reveals I glued the muzzle upside down and which in spite of all my efforts has a distinct mirror asymmetry.
https://i.imgur.com/p5EHFmk.jpg
Coil Channel detail in place and ready for fine detailing.
https://i.imgur.com/Ss3xWjI.jpg
post #303 of 385 (permalink) Old 08-05-18, 08:53 PM Thread Starter
Blackadder's Avatar
Establishing the Profile:
I remove the muzzle to work on it and reattach it for the images.
My first consideration is the muzzle length which should be about half the length of the coil section. I can extend it about 8 more millimeters if needs be hence the excess on the nose of the muzzle.
https://i.imgur.com/6hFW20K.jpg
One problem with the shape of this is the templates I have installed to make the exterior form will have to be broken out after the outer cowl is completed so I can build the inner surface of the four cowl pieces.
https://i.imgur.com/80BM2Ds.jpg
This end on shape gives some idea of the interior structure once the templates are broken out.
https://i.imgur.com/aLjohFZ.jpg
I can't wait until this monster is done and I can relax with the easier weapons. :D
post #304 of 385 (permalink) Old 08-07-18, 09:03 PM Thread Starter
Blackadder's Avatar
A Horrible Bollixed Up Mess:
Or, who knows, this just might work out after all.
https://i.imgur.com/Pl4cvpI.jpg
I've put a lot of work into this thing and it's finally time to apply the finishing strakes. Each one has to be custom fit but we'll follow this together.
Right Now I am cautiously optimistic. ;-)
post #305 of 385 (permalink) Old 08-07-18, 10:02 PM
Closet Dictator
Old Man78's Avatar
Old Man78's Flag is: Ireland
That looks sort of................complicated
Old Man78 is offline
post #306 of 385 (permalink) Old 08-08-18, 05:20 PM Thread Starter
Blackadder's Avatar
That Wasn't So Hard:
I don't know why I dreaded this, it wasn't so hard.
I figured out the secret of layering strakes ( Contoured planks on a frame ) and where I have previously gone awry with this sort of construction. What you need to do is install backing strips to the inner surface of the main planks so you have something to glue the filler planks.
Previously I attempted to add the filler planks without backing. I used 1,0 MM X 6.3 MM styrene for the planking which moulded easily but was still thick enough to take a finishing sanding.
https://i.imgur.com/GJbJxNz.jpg
The image above shows the upper nose segment rough sanded and the lower segment with the plans in the rough unsanded stage.
The image below may make the explanation clearer.
https://i.imgur.com/r0ZrGeM.jpg
Once I have the muzzle segments completely rough sanded I'll wet sand the whole cowling.
I never use filler such as Greenstuff and Milliput because it looks like hell ( Especially the Green Stuff ) and you have difficulty gluing additional styrene to the foreign surface. Plus flaws in the contours are difficult to see until the surface is painted.
Anyway, "Onward and upward" as the saying goes I'm quite pleased with the result.
post #307 of 385 (permalink) Old 08-09-18, 12:00 PM Thread Starter
Blackadder's Avatar
Rough Sanding Completed:
The business end of this construct is reaching fruition
https://i.imgur.com/yvyPN5f.jpg
Space Marine Provided for scale
https://i.imgur.com/9c3Mhe4.jpg
A couple of more layers and I'll be ready to remove the templates.
https://i.imgur.com/EZA696X.jpg
But I don't like these new light bulbs. Why is everything yellow?
post #308 of 385 (permalink) Old 08-10-18, 07:03 PM Thread Starter
Blackadder's Avatar
Template Frames Removed:
From the Muzzle
Which opens up the four highly detailed cowl segments.
https://i.imgur.com/zUwGAKO.jpg
This is where the FW artists prove their mettle. The meticulous detail that no one ever sees in the overall scope but sets their creations apart from run-of-the-mill efforts.
https://i.imgur.com/LpErLTP.jpg
I really cannot wait until FW releases a Warlord Chaos version so I can adequately demonstrate my appreciation by purchasing one.
BTW whatever turned the preceding images yellow has gone away???
post #309 of 385 (permalink) Old 08-14-18, 06:01 PM Thread Starter
Blackadder's Avatar
A Budding Neophyte:
Back in the days when the Blackadder was a budding neophyte he attempted to make a Plasma Blaster for a StormBlade variant. The result was of indifferent quality but I could not figure out a way to make the muzzle cowl long thin exhaust ports.
So today I was faced with the same problem ( Fortunately these are much bigger ) plus I have a wealth of experience to draw on so we shall see how I do.
https://i.imgur.com/ekQR0U4.jpg
I laid the groundwork for these ports and they take about five minutes each to replicate those in the screen above.
At this point we needn't worry about the length and the slight bowing of the 0.040 inch strips. I need 12 of these of exact length.
post #310 of 385 (permalink) Old 08-18-18, 05:57 PM Thread Starter
Blackadder's Avatar
Bogged Down On Minutia
These bits are time consuming
https://i.imgur.com/pelIe6R.jpg
https://i.imgur.com/dwzqeHN.jpg
https://i.imgur.com/a09Up8I.jpg
