Blackadder Attempts to build an Imperial Warmonger Titan - Page 3 - Wargaming Forum and Wargamer Forums
 265Likes
post #21 of 393 (permalink) Old 03-24-17, 08:04 PM Thread Starter
Blackadder's Avatar
Blackadder's Flag is: USA
Ready To Begin Shaping:
The layering is complete and all needs be done is the shaping
http://i.imgur.com/aK44D0O.jpg
I made the helmet about an eighth inch over sized per inch to allow for carving and sanding
http://i.imgur.com/axEuWUo.jpg
Tomorrow I should be well along on the paring down to the rough dimensions.
http://i.imgur.com/l0WOVlJ.jpg
Old Man78 likes this.
Blackadder is offline
post #22 of 393 (permalink) Old 03-25-17, 06:00 PM Thread Starter
Blackadder's Avatar
First and Second Contour Cuts:
Most of which are done on a stationary belt sander.
http://i.imgur.com/7RO8KiC.jpg
One more preliminary contour cut to make.....
http://i.imgur.com/SVQpT3F.jpg
The sides have to be rough sanded at about 45 before the finishing contour sanding.
http://i.imgur.com/VYPbiO9.jpg
post #23 of 393 (permalink) Old 03-26-17, 09:36 PM Thread Starter
Blackadder's Avatar
Rough Shaping:
Final rough shaping involves truing up the block to 90 then cutting a 45 bevel each side and finally two 22.5 bevels each side on top and sides.
http://i.imgur.com/9DUyTiT.jpg
Next (and this is the tricky part because it takes a bit of an eye for roundness) sanding off the excess in a controlled arc movement on the sanding belt.
http://i.imgur.com/bdNKxBZ.jpg
http://i.imgur.com/8vAqAXM.jpg
http://i.imgur.com/W0ZiUMI.jpg
so the helmet has a slightly flattened ovoid shape in cross section.
post #24 of 393 (permalink) Old 03-28-17, 07:28 PM Thread Starter
Blackadder's Avatar
Basic Helmet and Head
Well it took far more time than I thought but I do finally have the basic helmet cut to size.
http://i.imgur.com/P1eCper.jpg
http://i.imgur.com/fNkomQv.jpg
http://i.imgur.com/J6b7rWg.jpg
http://i.imgur.com/5egDBeZ.jpg
The rear view shows how much I cut out of the interior so I can add the under helmet detail when the cockpit is complete. I may still remove a lot of the inside material but for now it's sufficient as the helmet is as fragile as an eggshell with out it's interior framing.
http://i.imgur.com/n4znz4T.png
BTW you may have noticed the background image. This is what I am hoping the finished Titan will look like but leaner and longer legs.
post #25 of 393 (permalink) Old 03-29-17, 06:50 AM
Loran's Avatar
Loran's Flag is: Finland
Ooh, amazing inspiration figure in that background pic! Slightly longer legs will work, I think, as the model in the picture seems a bit too top-heavy. The helmet size seems good, gives a nice idea of the size of the final model
Keep at it!
[Hyarion] Warning! Loran may cause addiction to mindless online games.
Loran is offline
post #26 of 393 (permalink) Old 03-30-17, 07:57 PM Thread Starter
Blackadder's Avatar
Suffice it to say I am not happy how this helmet is turning out so I am revamping it. Update coming soon.
Meanwhile:
I naturally assumed my Warlord crew would fit into an Imperator head but never really checked so while I'm waiting to complete the face shield I just tried them for size.....
There's plenty of room; even for a Princep and a few attendees And a cadre of Tech Priests as well.
http://i.imgur.com/Hgx7B75.jpg
http://i.imgur.com/ApSGtc4.jpg
post #27 of 393 (permalink) Old 04-03-17, 01:04 PM Thread Starter
Blackadder's Avatar
Now It Can Be Told:
Now that I have resolved the issue I can reveal why I had to revamp the helmet. It all boiled down to an assumption on my part that the artist drawing the two elevations of the head was a draughtsman. In a proper draught you project lines from one plane to another and ideally there should be a top elevation as well but I accepted the two elevations as sufficient for my 3D rendering. I built my model slightly oversized than the plan as I wanted the 'head' to be larger than my Warlord's head as the finished model will be 10 to 12 inches taller than my Warlord. I blissfully used the side elevation for all my calculations and after laminating all the layers proceeded to sand the contours of the helmet but after the rough sanding was completed I found the helmet dome was significantly flattened.
It did not have the look of the front elevation at all. Needless to say I was extremely disappointed as I had based my interior design and mechanism on the front projection......
http://i.imgur.com/56WnEFl.jpg
Rather than scrap the helmet and start afresh I opted to build on the original to increase the height of the dome which is seen in these to images. It was last night that I managed to glue in the compound curved pieces requisite to obtain a smooth contour; the final pieces to be installed later this morning.
http://i.imgur.com/2QebzHA.jpg
So with this setback resolved I can continue with the building of the head; my obsessive compulsive integrity intact.
post #28 of 393 (permalink) Old 04-04-17, 12:31 PM Thread Starter
Blackadder's Avatar
A Cure for a Rainy Day:
After a rough rounding sanding I scored the armour panel lines. First with my utility knife. Then with razor saw and finally with xacto keyhole saw blade
https://www.widgetsupply.com/mm5/gra...in_519x340.jpg
to widen the gaps between the armour
http://i.imgur.com/rer2DpT.jpg
Now the helmet is ready for wet sanding which will hopefully remove the striation lines.
http://i.imgur.com/Vuhruvo.jpg
http://i.imgur.com/iKwkjcl.jpg
Now we're back to making the visor.
post #29 of 393 (permalink) Old 04-05-17, 11:53 PM Thread Starter
Blackadder's Avatar
Crest:
The crest seemed a daunting task but after the helmet it was child's play. I began by laminating six layers of 0.030 thousandths styrene last night because 1/4 inch styrene is too expensive and to hard to work with plus 0.030 is what I had on hand.
I then scribed two lines and equa-spaced the drill points with my vernier calipers.
I used my #11 Xacto blade to deepen the drill points and hand drilled 1/16" pilot holes for the scallops.
http://i.imgur.com/I6LWbhV.jpg
Then I drilled 1/8 inch holes to center the 1/4 inch final holes for the scallops.
http://i.imgur.com/shluvZ1.jpg
After drilling the 1/4 inch holes I cut off the excess material and sanded to the appropriate half hole depth.
http://i.imgur.com/5ugL5iz.jpg
post #30 of 393 (permalink) Old 04-06-17, 10:01 AM
Loran's Avatar
Progress is looking gooooooooood! Keep at it mate!
Loran is offline
