Blackadder's Landkreuzer P500; Die Wühlmaus - Page 19 - Wargaming Forum and Wargamer Forums
 3Likes
post #181 of 244 (permalink) Old 11-02-15, 02:27 PM
Moriouce's Avatar
Moriouce's Flag is: Sweden
I just read this whole thread through. *phuu* Now I have a question that arose at post#1. What is the superstructure made from? Foamboard?
Good to be green
Barks Dakka Ladz: W3-D2-L3
Altansar Eldar: W3-D0-L2
Moriouce is offline
post #182 of 244 (permalink) Old 11-02-15, 03:31 PM
Iraqiel's Avatar
Iraqiel's Flag is: Australia
Originally Posted by Blackadder View Post
Eat the dog.
Originally Posted by Oldman78 View Post
They dont taste too good!
Flash burn the hair off the dog!
The situation would be dire indeed to see that happen!
Luckily, the foes I must beat before the dog to get anywhere near your skill level are my impatience and my ineptitude.
Iraqiel
Iraqiel is offline
post #183 of 244 (permalink) Old 11-02-15, 06:00 PM Thread Starter
Blackadder's Avatar
Blackadder's Flag is: USA
Black Styrene:
http://i.imgur.com/UisXGyh.jpg
Well people who have been following my threads for years know but to newcomers and new forums that I am posting on will be surprised to learn that the black plastic comes from IBM printer cartridges. My former company threw them out by the hundreds each year.
I've got enough to last me a few decades............
They're thick plastic over 2,00 MM so you need a saw to cut them, a hacksaw will do and the plastic is compatible with with standard styrene plastic cement.
And they're free........
Plus you're recycling.
Blackadder is offline
post #184 of 244 (permalink) Old 11-03-15, 05:47 AM
Moriouce's Avatar
haha! Totaly missed that! Do you believe that Foamboard would make a sturdy enough superstructure for this kind of job?
Good to be green
Moriouce is offline
post #185 of 244 (permalink) Old 11-03-15, 11:01 PM Thread Starter
Blackadder's Avatar
My Warhound titan hull and head was/is made of foam board as is the hull of my Thunderhawk but it posed more problems than it circumvented so I do not recommend the use of it unless you are constructing a paper model.
https://www.heresy-online.net/forums/...ad.php?t=42297
https://www.heresy-online.net/forums/...d.php?t=122810
post #186 of 244 (permalink) Old 11-04-15, 05:22 PM Thread Starter
Blackadder's Avatar
Stormhammer Update:
Slow going with the thousands of rivets required to make this model come alive; I'm about halfway there.
http://i.imgur.com/7S4QdUL.jpg
I'm rather pleased how the winged skulls turned out
In the view below under the Demolisher cannon...
http://i.imgur.com/eb0S3ud.jpg
and these on the tread well skirting....
http://i.imgur.com/fO2Jd5J.jpg
and a close up....
http://i.imgur.com/c1qSq99.jpg
post #187 of 244 (permalink) Old 11-04-15, 07:30 PM
Closet Dictator
Old Man78's Avatar
Old Man78's Flag is: Ireland
Fabulous, keep up the great work!
Old Man78 is offline
post #188 of 244 (permalink) Old 11-05-15, 04:31 AM Thread Starter
Blackadder's Avatar
Thanks,
View Ports:
One thing I've been dreading making is the view ports. These delicate items are frequently damaged on Baneblade resin models and I have heretofore been less than successful in duplicating them in styrene but I have stumbled onto a seemingly viable method which if successful I'll give a breakdown in the procedure.
http://i.imgur.com/KuESSrr.jpg
The port on the center right is just about finished and only needs be filed to the proper angle for mounting on the casement.
The two mounted on the strip are extras in case of failure............
http://i.imgur.com/I9Cd5gh.jpg
post #189 of 244 (permalink) Old 11-05-15, 07:23 AM
Moriouce's Avatar
Here is an extraction from a private chat I had with @Blackadder . He thought it beneficial to the masses that it be posted here aswell.
M -What problems arose using foamboard? What thickness did you use? Would it be solved with thicker sheets? What I'm planing is a larger Ork vehicle and my plan is to build the superstructure with foamboard and then cover it with thin sheets of plasticard. What problems would I encounter?
B -I used 1/4 and 1/2 inch thick foam filled posterboard and I foresee no problems with using that material for a fortress structure. My problem was adhering large expanses of thin plasticard to the poster paper and finally solved it with 5-7 minute epoxy which was messy and sometimes not successful plus as my skills improved I regretted I could not install an interior in my T'hawk and Warhound. For a few bucks more I could have build all out of industrial quality sheet styrene which is actually cheaper than posterboard and styrene glue compatible.
Good to be green
Moriouce is offline
post #190 of 244 (permalink) Old 11-05-15, 07:52 AM
Iraqiel's Avatar
At the pointy end of the project ey Blackadder? At least your victory martini will be thoroughly well earned!
Iraqiel
Iraqiel is offline
