Laser for the laser god! An A-Level design student - Wargaming Forum and Wargamer Forums
post #1 of 17 (permalink) Old 01-11-14, 08:19 PM Thread Starter
Dakingofchaos's Avatar
Default Laser for the laser god! An A-Level design student
Hello all;
Thought I'd show off some work I've been doing for my major project for product design - Essentially a cityboard in a box.
Images of prototypes and concepts:
These were just mock ups made from MDF in ten minutes to get a rough idea of size and scale. In the end each of these walls will be magnetised so they can 'flatpack' down and fit into a case which I will also be making.
This image is of my first attempt fresh off the laser bed.
I like the design because of how simple it is, plus they can stack together in theory to the roof if you so wish.
This is a 'floor' section which is set on top of a lower level to give a walkway for models to stand on.
Close up; These were only rastered on as opposed to engraved to save time for a prototype hence the faint line at the minute. Hopefully you can see how the eagle spreads over two sections after being mitred.
An image of a glued together building (not magnetised) a cool quirk of my drawing I didnt realise until actually cut out was that the eagle again lines up with the next section when mitred.
Comparison:
Floor was about the right size, but not wide enough to sit level on lower floor. Intend to tweak this on drawing.
Dakingofchaos is offline
post #2 of 17 (permalink) Old 01-11-14, 08:22 PM
Jac "Baneblade" O'Bite
Jacobite's Avatar
I'd be interested to see how this stuff looks painted up, laser cut fibre board seems cheap but I'm wondering if the level of detail is enough. Don't get me wrong the designs you've got going are really good, I'm just interested to see of the materials can deliver a detailed result.
Jacobite is offline
post #3 of 17 (permalink) Old 01-11-14, 08:23 PM Thread Starter
Default Building Mk2
This is my second attempt after a few tweaks on the CAD drawing. Added some 'turrets' which I intend to peg and dowel onto bases and roofs to be used as turrets on top levels or barricades on floor levels. I moved the access hatch on the roof to line up with the floor sections and have began to draw ladders that will run between them.
On the far right of this image you can see a jig I also drew to make drilling holes easier for peg and doweling the turret sections.
These will be magnetised soon hopefully!
Also showing off my christmas present from my brother, my Games Workshops display Huron Blackheart
post #4 of 17 (permalink) Old 01-11-14, 08:27 PM Thread Starter
Default Painting
After a priming spray of skull white this is how I have began painting them to match my army.
A blue wash.
A purple wash.
A bit of colouring in.
Another wash.
A nearly finished building!
Also here is a reaaaallly tall one:
Not wobbly due to a sturdy base level so all good!
Also began some prototyping for prometheium relay pipes; I have since drawn up some initial CAD drawings.
Now that my long list of posts is up what do we think? Any ideas for improving?
post #5 of 17 (permalink) Old 01-11-14, 08:28 PM Thread Starter
Sorry you Ninja'd me in between posts! - What do you think of the painted?
post #6 of 17 (permalink) Old 01-11-14, 08:38 PM
Jacobite's Avatar
Interesting, does the material just soak the ink in particular up?
Jacobite is offline
post #7 of 17 (permalink) Old 01-11-14, 08:40 PM Thread Starter
Not after priming; I did a wee bit of a test to see what happened and it soaks up too fast to spread properly. After priming it MDF seems to behave almost like plastic.
post #8 of 17 (permalink) Old 01-11-14, 08:49 PM
Jacobite's Avatar
Hmmmm have you thought about giving it a light coat of liquid greenstuff before or after a coat of primer to give it a concrete texture?
Jacobite is offline
post #9 of 17 (permalink) Old 01-11-14, 08:56 PM Thread Starter
I did think of roughcoat, but not Green Stuff I'll give it a thought - my only problem is I'm doing 18 of the buildings so I'm trying to keep 'finicky' work to a minimum so I'm not still painting them all past the deadline.
post #10 of 17 (permalink) Old 12-29-14, 11:26 AM Thread Starter
Default A hobbyist returns.
Good afternoon all,
Been a very long time since I've post anything, started university and sort of left all Warhammer in a crate under a table, but after a recent game with my brother actually remembered this is one project I finished! Thought I'd share.
Finished product was cut down to 9 buildings, mainly because a the case would have been un-moveable with any more.
Did a few promethium pipes in the end.
Tinkered about with some Necron defence lines for my brother.
Completely modular and magnetic.
And all fits into a wee carry case.
So aye, city in a box, first project I've actually seen through to the end!
