Legion Rising - Projects from The Dark Works - Page 31 - Wargaming Forum and Wargamer Forums
 60Likes
post #301 of 320 (permalink) Old 05-30-19, 09:00 PM Thread Starter
Subtle Discord's Avatar
+++ Compiling Data +++ Kastelan STC Alteration ∙ OngoingÖ +++ Displaying Iteration ∙ 3.3 +++ Reviewing Hard DataÖ +++
Revised Assessment ∙ DisplayingÖ
Optical Input Array ∙ Improved ∙ Visum Pattern Wide-Angle Broad-Spectrum Optical Unit ∙ Integrated
Onboard Ammunition Supply ∙ Enlarged ∙ Increased Ammunition Capacity ∙ 800%
Rate of Fire ∙ Enhanced ∙ TriaíTelum Pattern Rotary Blaster Installed ∙ Fire Rate Increase ∙ 200%
Close Combat Weapons ∙ Iteration Subroutines ∙ OngoingÖ
Correlating Data Points ∙ OngoingÖ
Generating Authority Request ∙ Active Combat Testing
∙ As hoped, casting the ammo feeds in polyurethane and creating three with different radii/radiuses solved the fit issues.
They are a bit fiddly to bend into the exact final position (I still want to tweak one of them a bit more) but polyurethane is a very forgiving thermodynamic plastic; not only can it twist and bend significantly if you warm it in boiling hot water, it also returns to its original shape very easily if you want to reset an effort.
My son was fascinated by the long piece of polyurethane sprew I was using as a test strip, repeatedly bending and twisting it into the most extreme shapes he could manage and then dunking it to watch it relax back to the original shape. He did it so much more than I would have it really illustrated to me just how much you can torture poly resin and it really holds up well. Iíve learned to take my hard data where I can get it.
∙ I was forced to partially complete the build to make the model stable enough to facilitate the fitting of the ammo feeds.
I had planned on doing a set of the close combat arms to see how theyíd turn out but my current AdMech list doesnít have them and this assembly was just being too frustrating without locking some parts in place. I guess I have no choice now but to get some more Kastelan Ďbots to make this squad a bit bigger and to add another for a bit of punch. Pun intended.
For anyone who might be wondering if/when these kits will be making their way to the shop, yes I do plan on putting the Mechanicus components Iíve created in the shop at some point in the future. However, I want to put some other projects to bed first and I also want to complete one-or-two more Mechanicus builds, with the Onager being the obvious target, but there might be more some inspiration to add to that. The upcoming AdMech transport/tank kit has me itching to get my grubby hands on it to see what potential might lay in the kit.
Oh, and donít you worry Chaos, I could never forget about you. First the Marines, then the Mechanicus. Yes, you will have your fill, I promise.
But those are Darker ideas, forming other stories, for future updatesÖ
Old Man78 likes this.
Subtle Discord is offline
post #302 of 320 (permalink) Old 06-11-19, 09:45 AM Thread Starter
∙ Juggle model man! Juggle! You got that done? Well hereís three more things you gottaí do! Hahahah! Juggle model man! Juggle!
Required to constantly keep swapping hats, Iím working on a new banner that I can use on the shop that can give a really focused condensed idea of the studio philosophy with a layout that can accommodate a range of photos. Iím hoping that if I can standardize some of the stuff like this I can make it a bit easier to add updated images to give more feedback on what the studio is working on. Being a simple setup I donít get a lot of control over the shop site so for now Iím trying to do my best with the template as-is.
Ah well, more updates coming soon. I have a distinct urge to start painting the Kastelan Ďbots despite all the things I need to do. Iíve been sacrificing my weekends that I was forcing myself to take in an effort to keep my head screwed on straight and the lack of progress on personal projects has me getting quite itchy. The Mechanicus are so close to being done, I canít help but get back finishing them, before getting lured and lost in Darker placesÖ
post #303 of 320 (permalink) Old 06-21-19, 07:44 AM Thread Starter
∙ Something(s) wicked this way comesÖ soonĎishÖ I hopeÖ *Sigh* Never enough time. Update brain-dump incoming.
post #304 of 320 (permalink) Old 07-04-19, 07:30 AM Thread Starter
∙ Forgive me Omnissiah, for I have succumb to distraction and it has lead me toÖ innovate. I suspect that I will be unable to stop. *Harsh binaric screeching!*
Wall-o-text with some more images coming soon, I promise. Trying to lay the ground work for some bigger projects (work-in-progress pictured above being the first of some much more ambitious ideas) and Iíve got a brain full of thoughts that Iím still working to sort out into some kind of coherent ramble.
post #305 of 320 (permalink) Old 07-20-19, 10:37 PM Thread Starter
Studio Correspondence Message: I apologize to anyone reading this who may have contacted the studio over the last few months but have not received a reply. I try to keep up but sometimes I get swamped and/or distracted with things inside and outside of the studio and it becomes very easy to procrastinate on replying. I will be sending out a form letter to reply to the bulk of the emails and work to reply directly where it makes sense.
This ties into what I want to talk about in more depth, but Iíve got several things bouncing around in my brain so I figured it would be best to split them up. Right now, letís have a look at what Iíve been working on for upcoming kits and soon Iíll discuss how one thing led to another and a fit of distraction made future studio projects started to take form, somewhat unexpectedly.
∙ With initial work for the Rhino done the venerable Land Raider chassis is next in line.
Now, the Land Raider is an old GW kit to say the least and it comes with a few issues with fit and dimensions; some parts simply donít fit together quite right and there are numerous places where details should be symmetrical, and they arenít, or should align, and they donít. The best I can do is try to average out any differences and remember to provide a bit of tolerance to the fit of components I create. As with the Rhino chassis, once Iíve made some things that can give some feedback on the fit I can dial in the 3D model for future projects.
∙ Itís been sitting on my workbench begging me to give it some attention so I felt compelled to 3D model the Sicaran.
Someone had mentioned a while back that it might be challenging to make add-on kits for the Sicaran and I can understand why since RTV mould cast resin models can have some tolerances that might not be completely uniform for one cast to the next. After dealing with all sorts of strange issues with the Land Raider I figured Ďhow bad could it be?í and got to work. I quickly discovered that itís true and it surprising just how much so. Many of the details are completely different from one spot and/or side to the other where they should be symmetrical or evenly spaced. Even the tracks start at the exact same spot at the back of the model but by the time they reach the front theyíre slightly different lengths; this may have been done on purpose to make them look slightly different, but itís just one of many odd details and off measurements. As with the Land Raider, but even more-so, Iíve simply tried to average out any of the worst examples of this.
Itís still a gorgeous model and most issues are small enough that you canít really tell by looking at it, but it makes it very tricky to create anything with a tight fit over any of the complex geometry. I really just want to give the model some spaced armour plates, a siege ram style Ďdozer blade, and some tread plates that can be attached to the tracks, so I know I can do those without too much hassle. Anything more complex and itíll be too much of a headache I suspect. Initially I wasnít going to model the turret but once I got the rest of the model done I got lured in to the challenge of trying to do it; Iím not sure it Iíll make custom weapons for the Sicaran but at least now it wonít be hard to get started if I do.
∙ Next up, a ĎRaven thatís been sitting in the back of a dark a drawer for far too long.
If itís not already apparent, I really enjoy the 3D modelling process so itís not going to take much arm-twisting for me to get to work on the Storm Raven. Over the years itís been requested more than a few times, so now that Iíve got the opportunity it seems like as good a time as any to get the preliminary 3D modelling done. Iíve finally got the means to really do it right and get the complex fits Iíll need to make add-ons for the ĎRaven.
∙ Whatís that? You were expecting more than these little images of the tank model I previewed before? Looks like youíll need to keep your comm-link active.
Working on modelling so many GW kits I couldnít help but develop a nasty itch to create something thatís been lurking in the back of my brain for years. It also ties in well with some of the other things Iím trying to sort out and talk about, so I figured it would be a good hook for my next update. Everyone likes images after all, especially if itís (likely) going to be accompanied with a wall-o-text.
This is definitely a project for the future, but I really want to show some of the more ambitious ideas Iíve got for future larger kits. Add-ons are just where I want to start but I really do want to create much larger and more ambitious complete kits and I want to start showing off what I have in mind so people can see the images I have in my mind, even if I canít make them quite yetÖ.
But, before I get to rambling too soon, Iíll stop here, and keep it for next time.
post #306 of 320 (permalink) Old 09-30-19, 04:31 AM Thread Starter
Well then, just as I was about to get my crap together and start talking about my new plans for the studio, life the universe and everything conspired to toss a wrench into the whole works. As if I wasnít trying to juggle and sort out enough stuff an unexpected new twist has come along and really thrown me for a loop, so, Iím still trying to stop my psyche from spinning and find my equilibrium. While the studio is by no means dead the last few months has completely tripped me up just as I was going to get stared and forced me to step back and rethink many things. Life doesnít come with an instruction manual, you just gottaí figure it out as you go. *Sigh* Adulting is hard sometimes.
More studio updates incoming at some point, once Iíve got new considerations fit into the plans. I was already committed to exploring and talking about how I want to take things to the next level and that isnít changing, but I need a bit more time to get things sorted out. Personal projects on the other hand, might just find their way into the gap, so thatís not a bad thingÖ
+++ Ö still waters run deep Ö +++
post #307 of 320 (permalink) Old 11-23-19, 08:28 PM Thread Starter
Comm-Link ∙ Active
Motivation Subroutines ∙ RecalibratingÖ *HARSH BINARIC SCREECHING!!*
Praxis Protocols Initialized ∙ Motivation SubroutinesÖ Altered
+++ Output Quota ∙ Inadequate +++ Incentive Reprimand ∙ Administered +++ +++ Information Exchange ∙ Update +++ +++ +++ Output Quota ∙ Adjusting ParametersÖ +++
Comm-Link ∙ Active
Update Incoming ∙ StandbyÖ
post #308 of 320 (permalink) Old 11-27-19, 07:57 AM Thread Starter
post #309 of 320 (permalink) Old 11-28-19, 07:36 AM Thread Starter
Comm-Link ∙ Active
Data-Link ∙ Active
Decrypting Ö
Data File Lo.4313-7 ∙ DisplayingÖ
So, life, the universe, and everything keep pulling me in several directions the last while and thatís got my brain just a bit preoccupied. I want to sit down and write more, but wording is harder than usual right now. While I have been distracted and somewhat sporadic with updates Iím striving to not be idle in the studio or the hobby bench so I figured a nice dump of large images with minimal text was the order of the day.
∙ With decals finally ready to go I can get down to actually properly finishing some models, like the Kastelan ĎBots and Datasmith.
I still think the contrast of white decals would have been interesting but Iím completely happy with the black and ultimately I think itís a better match to the blue-and-black scheme. Maybe Iíll get some white ones done in the future and use them to make alternate units using them or something.
∙ To say Iím pleased with how the ammo hoppers and feeds turned out would be an understatement. They take some tweaking to get rightÖ
Ö but the result is totally worth the effort; now thatís a Kastelan that looks like it could spray out some phosphor rounds. Youíre usually staring at the backs of your models when theyíre on the table so they may as well look good from behind.
∙ Is the Dragoon just a really large model or do I need to consider a larger photography backdrop? I think itís both, yeah?
Being all legs and Tazer Lances the Dragoons are quite challenging to completely frame in the shot as a complete unit without cropping anything. Since the projects are going to get much larger over time *glances at the Knight and Kytan sitting off in the corner* I guess itís time to consider a larger backdrop solution.
∙ I also overlooked priming the backpacks for the Skitarii riders, so theyíre not quite finished yetÖ but so close!
Iíll get around to the backpacks the next time I prime some other stuff, so these will catch up soon enough.
Speaking of things that will need to be primed in the near futureÖ
∙ Patiently waiting their turn for several years itís so nice to finally get a unit of Onagers on the workbench.
The extra time was worth the wait.
∙ Yeah, thatís it, make a build for a model thatís already chocked full of all sorts of bits and gubbins, even more involved. Good call.
Well, itís not like I can stop now, can I?
*Ponders a moment to consider the chorus of whispers endlessly taunting me with ideas and inspiration*
YeahÖ thatís not going to happen.
∙ All dressed up and waiting on the final bits and piecesÖ so many, hoses, cables, ladders, rails, and antennaÖ seriously.
Iím learning to love to hate to love the Mechanicus line. So many little bits to add to the models that make them look excellentÖ and make them more complex to paintÖ and did I mention itís only a matter of when, not if, youíll snap an antenna off? Wonderful, delicate, detailed, frustrating, unique, and tedious all in one. Perfect for my mildly masochistic tendencies really, I suppose.
∙ And of course, I had to add one last bit to the mix. Youíve come this far, so know you saw it coming.
I was going to convert the Heavy Stubber included in the kit but I figured it would just be more straightforward to simply 3D model the entire bit in one go. Nothing too complex so it wasnít hard to whip up. Still waiting on the first prints of this bit even as I write this.
Ok, so you can expect to see much more blue over the coming weeks as I apply many decals to many models and get them properly finished and table ready. Iím already eager to get on to some bigger projects but the foundation and first floor is almost done and I canít get distracted quite yet.
Omnissiah guide my hands of inferior flesh so that I might make your divine inspirations real.
post #310 of 320 (permalink) Old 11-28-19, 09:32 PM
Closet Dictator
Old Man78's Avatar
Old Man78's Flag is: Ireland
Great stuff have a rep cookie
Old Man78 is offline
Tags
