Okay so here's the deal, I photo-shopped the image and made a static front view that prints out a model exactly 24 inches tall (On my printer using my editor's print graph I hasten to add). I'm satisfied that this is viable height for a Warlord towering almost 2.5 times the height of a Warhound.
Now that I have the overall height I'll remove the armour and draw in the structural detail.
BTW that's 24 inches to the lower margin of the image because we mustn't forget the foot pads.
I calculate the center disk of the foot to be about 3.625 inches in diameter.
Here comes the weekend and I'll be playing to an empty room. I did manage to cut out most of the basic components of both feet and hope to have them glued together this weekend. I used 2.0 mm for the tread base and the rest is 1.0 mm styrene. This beastie is going to consume a lot of plastic but the fabrication will be a lot easier as all the material will be the same so no problem with glue compatibility which is a big plus.
I'll just add this on:
The octagons are the center of the foot pads and are 2.0 mm thick and about 5.0 x 4.5 inches the larger boxes to the right are the front and back toes and the smaller boxes at the extreme left are the side toes. Both sets of these toes will be movable with hinges. The truncated toe pieces to the far right may or mayn't be movable as I haven't planned that far as yet but the disc will tilt side to side and the top surface will house a semicircular gear shape which will allow the entire foot to tilt forward and aft. This should afford a full range of motion to the feet. The semicircle will have a countersunk screw for the axis and a pal nut on the other side to provide the tension to maintain the various poses.
To quote your second ever post on this appropriately gigantic topic Mr Blackadder... When will the madness end?!
When will you finally come to the assembly, painting and jubilant celebration of this undeniably ingenious project? Do you have an end objective or is it just all in the works still?
I'm trying a different approach and actually planning my work before hand. That in mind I am not the neatest mechanical drawer but it is as true to scale as I need for gov'ment work.
These images should print out 1:1 on 8.5 X 11 paper
Automatically Appended Next Post:
This is the size I can up with for a 24 inch Warlord titan. The entire foot will cover a Baneblade tank front tread to exhaust stacks and sponson to sponson which I believe is quite awesome enough considering a Baneblade is as large as my entire house i.e. 30 X 40 feet.
However, madness is but a fine line away from genius, and I was never sure what side of the line I was looking from, so my perspective may be skewed a little. :biggrin:
I shall be watching from my suitably padded room (in case I get over excited), and will be interested to see just how bloody brilliant it turns out, as its already seeming to be. :victory:
I finished all the basic toes and suspended my printout above the feet and Damn me it looks right. The Greaves still have the side frames armour to be added and once the body is bulked up I think you would want a good solid base to stand on.
Oh dear. Blackadder is at it again. Is this a diversion from finishing the thunderhawk? If so it will be a very impressive diversion. One question though, are you planning to do this one to the same standard as lucie? If so it will be rather spectacular.Rep for the ambitious project and being one of the few people who can reliably pull this off.
My goal is to duplicate the Dave Smith Warlord but with pose-able legs and feet. I am torn between the Dave Smith camo or an olive green. I really can't imagine War Griffon colours on this model but at least to the standard of Lucie but with an interior.
I needed a break from the T'hawk after I built the engines. They were very time consuming and it got so I was thinking good enough. When that happens I have to stop working on the model because good enough is never good enough.
The dave smith warlors is an impressive piece of work. I saw that a while ago and would have to say it is the best warlord i have seen to date. Although that may be changing.......
Plodding along as is my wont I successfully attached the step pyramid style ends of the toes this morning which for the life of me serve no earthly purpose other than aesthetic appeal. (If you like toes.... Jabba )
Mine differ from DS's in that they are slightly wider but the overall design is the same.
Accompanying the feet are some figures to convey scale donated by my son.
Okay seriously now judging by the size of a normal human being and the size of these feet can anyone say that a 2/3 meter tall Warlord on a battle board will be anything less than awesome unless you have a serious penchant for the ridiculously absurd!
I mean think about it each foot is as big as a Baneblade tank!
A bit further along on the disc mount mechanism placed but not glued are the rough cylinder trunnion mount blocks which are in essence pairs of pillow block bearings. Not glued because I don't know how much distance I need for the cylinder travel and still allow the disc plate a full range of tilt. mebbe I should do a drawing.
I've been working on the disc tilting cylinders. These will allow the disc to tilt side to side while secured to a longitudinal pivot axle yet to be fabricated.
Oh my god, this is going to be a work of pure art!!!!!
I understand how you feel when you get so drawn into one project, it's nice to just drop it for a while and do something different it means when u come back to it you feel fresh again and stops you from hating it! I'm the same when it comes to painting, I'll have three, four or sometimes five on the go at once.
You have a great start going on. I believe the planning and thinking you are doing will make a differance in the long run. I will be watching this for the sheer lunacy of trying, and the awesomeness of the idea.
I appreciate the responses and the subscriptions but just so you know 'The Blackadder' is very prone to mistakes. I spent half a day building the pistons receiving the cylinders on the discs and after forming them and starting to install them found that they were totally unnecessary!
Since they are totally hidden inside the ankle discs whats the point of even installing them? added work more parts to fail; who needs that so eliminated. But all is not lost, they may be useful in another area and if nothing else they keep me humble.
It's extremely gratifying to envision something in your mind's eye and then to duplicate it in some medium. In this case extremely malleable styrene but I can see how real engineers get their rocks off. Granted the days of Isambard Kingdom Brunel and John Scott Russell are pretty much over where an engineer designs and executes an entire construct but I'm sure even today such gratification must still exist.
Case in point, this highly speculative tilting table mechanism for the foot attachment.
I believe I have come up with a viable solution to allow the foot to tilt side to side, be light and strong and also look complex enough to grace a 40K denizen. http://i.imgur.com/k07P5.jpg
Were I to build this for a real vehicle I would enclose the axle within the disc housing so the table doesn't shift side to side as much but then the mechanism would be totally hidden. so this way I have an excuse for the diagonal toes linear actuator system that give enhanced stability during the stepping process and decreases the upper body swaying which is the cause of so much seasickness in some Warhound crew members. http://i.imgur.com/adYW2.jpg
This is ridiculously awesome and yet it's still just feet.
It's still difficult to put the scale into perspective though, kinda hard to imagine that it's going to end up the size of a small child and just as destructive.
Related Threads
1.5M posts
44.2K members
Since 2006
