Specific paint removal - Wargaming Forum and Wargamer Forums
post #1 of 10 (permalink) Old 01-07-15, 10:07 AM Thread Starter
Matcap's Avatar
Matcap's Flag is: Netherlands
Default Specific paint removal
Hey people,
I was wondering if any of you could help me. I'm currently at a stage in my painting where I end up really liking some parts of a painted model but want to redo some other area. Do you know of a way to reliably remove paint from a small area of a model without touching the rest of the model?
I currently use a hobby knife to scrape off the paint but this usually results in more repair work needed and is impractical for some hard to reach places.
Cheers!
Matcap is offline
post #2 of 10 (permalink) Old 01-07-15, 10:13 AM
Herald of The Warp
Nordicus's Avatar
Nordicus's Flag is: Denmark
My best advice would be to take a old brush, that you don't use anymore, and put some non-acetone nailpolish remover on it. Put a thick coat on the area you want to remove, let it sit for about 30 second and you can scrub it off with a thin scraper.
It's not optimal, but with a little practice it can do what you need to do.
Nordicus is offline
post #3 of 10 (permalink) Old 01-07-15, 10:31 AM
nice boy, daft though !
bitsandkits's Avatar
paint over the area you dont like
HUGE BITZ RESTOCK NOW ON
bitsandkits is offline
post #4 of 10 (permalink) Old 01-07-15, 11:19 AM
Jace of Ultramar's Avatar
I second this. If you thin your paints, it will look fine.
As an alternative, perhaps a Q-tip with 97% alcohol (the kind used to clean an area of skin before a nurse/doctor inserts a needle) might work too.
Jace of Ultramar is offline
post #5 of 10 (permalink) Old 01-07-15, 11:52 AM
Miniature's Surgeon
Dusty's Corner's Avatar
Firstly, I'd try to protect areas you want to keep - masking tape, blue tack, cling film etc
Then you can attempt paint removal without worrying too much about the rest of the model.
If you can get away with adding more layers of paint, then great.
q-tip with solvent (alcohol, nail varnish remover, dettol etc) will be good. Be careful not to drown the area being worked on.
Sanding pads are also great to smooth out. You can cut the sanding pad/sponge to give you sharp corners that you can work into tight areas. It's also a bit safer than using fluids.
Otherwise knife is actually great, use a blade with a rounded tip - scalpel blade no.15 is master! You can actually scrape out line work, tidy detailed features (including face) and remove fine lines.
Remember if you've removed paint completely, you'll probably want to re-undercoat it aferwards - So leave the masking in place and remove any dust particles before continuing to paint.
Dusty's Corner is offline
post #6 of 10 (permalink) Old 01-07-15, 06:32 PM
SonofVulkan's Avatar
SonofVulkan's Flag is: United Kingdom
I'd go with painting over the top. If your paints aren't too thick, it should be fine.
SonofVulkan is offline
post #7 of 10 (permalink) Old 01-08-15, 08:46 AM Thread Starter
Matcap's Avatar
Thanks for the responses guys! I would paint over the area, but often the wanting to remove paint is the result of trying to paint over an area 10 times because I'm not happy with the first try.
I'm gonna try the q-tip method and let you know how it goes.
Matcap is offline
post #8 of 10 (permalink) Old 01-08-15, 01:47 PM
falcoso's Avatar
Easiest way to remoce paint froma specific area is using a cotton bud or very stiff fine brush (like the GW stipplin brush) and rub isopropyl alcohol on it, that should remove the paint fairly easily. I personally would only use the alcohol as it doesn 't get grundy unlike simple green dettol and nail polish remover.
falcoso is offline
post #9 of 10 (permalink) Old 01-09-15, 08:07 PM
Silens's Avatar
Silens's Flag is: Wales
I've had success with a cotton bud/q-tip and white spirits/mineral spirits but I think that these might damage the plastic underneath? I'd go for some strong alcohol.
Originally Posted by Nordicus View Post
"Look they got a-OH MY GOD I'M ON FIRE FOR THE LOVE OF NAKED SANTA IT HURTS!"
Silens is offline
post #10 of 10 (permalink) Old 01-10-15, 07:17 PM
It won't be a problem provided you don't leave it on for too long. I have used an acetone soaked Q - tip and a dental pick to remove a specific patch of paint before (my advise is to use alcohol though).
Do remember to varnish the parts you like prior to attempting this though! The varnish will protect the paint against the alcohol for a short period of time though it will eventually break down if you work at it too long.
Incarnet is offline
