Kroot master shaper and conversion idea - Wargaming Forum and Wargamer Forums
post #1 of 6 (permalink) Old 08-22-13, 10:20 AM Thread Starter
Michael valentine's Flag is: United Kingdom
Default Kroot master shaper and conversion idea
Ok so i want to model a small kroot force to use as allies for my eldar army, i have some kroot carnivores an I've been working on my master shaper he is gonna count as an Ethereal with an honor blade. Its my first conversion using green stuff an i'm quite proud of how the cape turned out. Sorry in advance for my poor painting skills though..
Now.. i want to add some knarloc riders using the rules from Imperial Armour 3. I'd rather work with plastic than resin though, so i was thinking of using the wolves from the thunderwolf cavalry box as counts as knarlocs. Does any one know if the wolves would be a good size? or have any ideas for good plastic models i could use instead?
Michael valentine is offline
post #2 of 6 (permalink) Old 08-22-13, 12:42 PM
Bringer of the Apocalypse
Deneris's Avatar
Deneris's Flag is: Canada
I'd use Dark Elf (from Fantasy) Cold Ones instead of the wolves; Krootkin are more scaly than hairy...
(Thanks to Bits and Kits for the image)
"That, and sending Leman Russ to make a peaceful arrest? That's like sending a rabid Grizzly Bear to teach Kindergarten." - Cole Deschain
"Deneris - you are a legend." - TheKingElessar
"Chingao...sigh..guess I'll stay a slut then..."- Shogun_Nate
Deneris is offline
post #3 of 6 (permalink) Old 08-22-13, 12:49 PM
SwedeMarine's Avatar
SwedeMarine's Flag is: Sweden
I agreee with Den. The cold one riders would be your best bet but maybe use the ones from the Lizardmen rather than the Dark Elf. they have a more primitive look to them that the kroot typically tend to embrace.
Image is from bitzbox.co.uk
Also the cape looks good I would suggest for future projects adding a little bit of texture to it to make it pop out. Nice work man
W:9 D:2 L:5
SwedeMarine is offline
post #4 of 6 (permalink) Old 08-22-13, 01:06 PM
Deneris's Avatar
If you want a bigger lizard (and Gnarlocs are pretty large) you could try the plastic Fantasy Carnosaur...
Deneris is offline
post #5 of 6 (permalink) Old 08-22-13, 02:09 PM Thread Starter
Thanks those cold ones do look nice might use them, the Carnosaur is pretty sweet too maybe he would work as a greater knarloc?
post #6 of 6 (permalink) Old 08-22-13, 04:00 PM
Creon's Avatar
Creon's Flag is: USA
I'm pretty sure he'd qualify as a Greater Knarloc. And you'd need permission for Knarlocs, they're Forge World. Might make interesting Kroot Hounds, tho.
Creon is offline
