Dark Elf warriors - crossbows or spearmen - Wargaming Forum and Wargamer Forums
post #1 of 11 (permalink) Old 10-29-09, 07:17 PM Thread Starter
Pinkmerauder's Avatar
Pinkmerauder's Flag is: USA
Default Dark Elf warriors - crossbows or spearmen
Right now I have 15 crossbowmen and 12 spearmen, both have full command. I have 32 un-built warriors. How many should be crossbows and how many spears? Should I build more commands or include then in one squad?
Here is the rest of the army for context.
2 masters
2 sorceress
1 supreme sorceress on cold one
10 cold one knights w/full command
30 corsairs some with crossbows
2 bolt throwers
Thanks.
Pinkmerauder is offline
post #2 of 11 (permalink) Old 10-29-09, 07:32 PM
Creon's Avatar
Creon's Flag is: USA
Depends, is the Sorceress going to have the sacrificial dagger? If so, 20 spears is necessary as power dice. Other than that, use all Xbows. With shields. A Dark Elf spearman isn't likely to stand up to most other base troops, not with a 5+ save, T:3 and one attack. The Xbows are actually better in HTH, with the 4+ LA/Shield/HW combination, and they get to reach out and touch all game before they're locked in.
Creon is offline
post #3 of 11 (permalink) Old 10-29-09, 07:48 PM Thread Starter
How would you model crossbowmen with shields? The kit has the xbow with two hands.
post #4 of 11 (permalink) Old 10-29-09, 07:57 PM
Heresy's Graphics Slave
Syph's Avatar
Syph's Flag is: United Kingdom
Stick the xbow on the backs, as if slung over the shoulder. I have also seen them modelled with the cut out of the top of the shield wrapped around the wrist with the shield resting on the floor.
I also think convential wisdom is to not give the xbows a command unit either - just a musician to help rally.
Syph is offline
post #5 of 11 (permalink) Old 10-29-09, 08:55 PM
Creon's Avatar
I usually sling the shield over the back. You can also model pavisse on them, or lean the shields up against the legs, or point deep in the ground (cut off the point, glue to base)
Creon is offline
post #6 of 11 (permalink) Old 10-30-09, 12:18 AM Thread Starter
Thanks for the input. Just to be clear, I should probably just make xbowmen and I should probably not put any command but a musician.
post #7 of 11 (permalink) Old 10-30-09, 12:38 AM
Wulfric_Nick's Avatar
Wulfric_Nick's Flag is: Australia
I would agree, but my choice would be
- make 3 More Spearmen, so you have 3 full Ranks 5 across with minimum Width for Rank Bonuses. this way you can still lose a few spearmen from shooting, then get 2 full ranks of Stabbity goodness.
-The rest I would make as Xbox users, like the others suggested, they are far more versatile!
Khorne Berserker [DoW] - I am not your Bootlick!
Wulfric_Nick is offline
post #8 of 11 (permalink) Old 10-30-09, 12:40 AM Thread Starter
Ok, I will do that. Thanks for all the advice
post #9 of 11 (permalink) Old 10-30-09, 04:22 PM Thread Starter
What sort of squad sizes should I run?
post #10 of 11 (permalink) Old 10-30-09, 04:31 PM
Syph's Avatar
I have 20 spears in my block because I have a sorceress on foot using the sacrificial dagger. Can either run it as 5x4 with 19 spears and 1 sorc, or 7x3 with 20+ sorc.
15 is the minimum for spears IMO. 5x3.
Xbows I have yet to purchase (had lots, second hand, but were useless even stripped). I plan to have my xbows as 10x1, but several units of.
Syph is offline
