Advice: Starting Armies for new fantasy players guide - Wargaming Forum and Wargamer Forums
post #1 of 8 (permalink) Old 06-23-09, 07:15 PM Thread Starter
swissdictator's Avatar
swissdictator's Flag is: Switzerland
Default Advice: Starting Armies for new fantasy players guide
This is intended to be different from the above armies summary, and is aimed at laying out some good starting armies.
This is not intended to pick to most powerful ungodly armies, but the ones are are new user friendly. In fact I shoo slightly away from two of the three tier one armies, as they play very differently.
Organized in alphabetical order. Grades are assigned as how they rank for a new player to the game.
Beasts of Chaos:
In short, right now... I'd stay away from them. Having lost many of their options, older rules for how they rank up, etc... leaves them at a severe disadvantage. If you *really* like them, then you go for them... just understand you will be challenged. On the plus side, it will force you to develop your tactics more than other armies will.
Grade: F/D-
Brettonians:
They are fairly easy to understand the basic concept of the army (Charge), and are pretty durable. They do require a little bit of talent stiil, but that's quickly developed. They have some mild flexibility via their peasants, and the peasants are not to be underestimated.
Painting can be a bit daunting at first, though this can me made easier by switching between 3 main colors or painting them the same in groups of three or four.
Background is pretty easy to familiarize yourself with, as it's based off Arthurian legend/Medieval France.
They are also likely to get an update 2010-2011.
Grade: B- for Beginners. They're forgiving in some ways, but experienced players will be able to pose a challenge.
Dark Elves
They have been rather recently updated (2008), so you'll be playing with the same book for years... which is good.
They, unlike the other tier 1 armies, are a very flexible list. You can make a soft/friendly army easily enough... or a very hard edged tournament list... and anywhere in between.
They can be aggressive, defensive... fast/slow... magic heavy/light... shooting heavy/light. Plus they have other options as well.
They have some newer sculpts (Cold One Knights) which are absolutely stunning. They have a well developed story behind them that can also hold your interest.
A small advantage: If you're clever enough... with the right paint job and figure selection... I have seen a lot of people find a way to cross use their units with High Elves. Just be a little careful about that, so people can understand what is what. Not all units can crossover, but several can. So you can have a 2nd army already in the works.
They can be fairly forgiving with above average leadership, and hatred.
Grade: A+
Demons of Chaos
A very powerful army. Mount them on square bases, and I know a lot of 40k players will let use run them in 40k for casual games. So that helps you get into both. However they're not nearly as powerful in 40k.
Going multigod will give you flexibility, but many fantasy players will frown on that... possibly getting some mild attitudes or (in a tournament setting) low composition scores as that will be seen as "cheesey". Going monogod, is much more thematic and received much better... but can be a bit limiting.
They are VERY forgiving for tactical errors. Going monogod will make you think more tactically... which why I'd recommend that route personally.
Demons are a touchy subject right now, as people have a wide range of views.
Grade: If you go more thematic (not necessarily monogod): A If you go multigod/optimal unit selection: B- only because of how many people will react.
If in doubt, ask folks in your own gaming area for advice... as you can get an idea of how demons are seen. Some will just say "Whatever, bring it and let's play!" Some will say "As long as it looks cool" or "has a cool theme" they'll be fine with it.
Dwarfs
If you like solid, determined blocks of infantry then you can look here. Right now, however, I would suggest that you has best like Dwarfs quite a bit. They can compete, but they have a very hard time of it right now.
While they have several different war machines and infantry blocks, they don't have the flexibility an army should have for beginners.
They also have no magic.
Their armor, toughness, and leadership is forgiving... however.
Grade: D+/C-
Empire
They have some similarities to Empire... they can field big blocks of infantry and guns. However, unlike Dwarfs, they have quite a bit of flexibility. They have cavalry, magic, some wild troops. They have elites and rabble as well.
While their infantry is not as good as Dwarfs, and their knights not the deadliest... they do have good guns. They can be played in so many different ways, that they can probably be run to a playstyle you like.
Their book is updated for the new edition, some say it is a bit weak... but others say no. They can still compete, but you will have to think more about them. Not quite a finesse army, but certainly one for the thinking man.
Overall: B/B+
High Elves
Their ASF rule is an advantage, but I advise you do not get to used to it if you intend to build other armies. They tend to be magic heavy, so you will learn the ins and outs of magic most certainly.
They have a little bit of flexibility. A lot of tournament players play similar lists, but there is some variety... just not much. For casual games, however, you will be able to field a wider variety and still have fun.
A small advantage: If you're clever enough... with the right paint job and figure selection... I have seen a lot of people find a way to cross use their units with Dark Elves. Just be a little careful about that, so people can understand what is what. Not all units can crossover, but several can. So you can have a 2nd army already in the works.
Their rules are up to date, and do reflect the current trend.
Overall: B+
Lizardmen
Most recently updated army. It's a fairly flexible list, though not as flexible as Empire, Dark Elves, or Warriors of Chaos. The base troops (Saurus) are very solid and good in combat. The Cold Blooded Rule is fairly forgiving.
They can go magic heavy, or light. Which is nice as it allows you to tinker with magic and have the level you like.
Painting can get dry, but you can spice it up with different spawnings for each unit... basically warriors blessed by the different Lizardmen gods.
They're not hard to use, but not brainless either.
Overall: A-
Ogre Kingdoms
While I know some people just love these guys, I only recommend these for experienced players. The army is unforgiving for mistakes, and requires finesse.
The only advantage is the low model count will be easy to paint.
Grade: Gaming wise: F Hobby wise: D+/C-
Orcs & Goblins
The attitude of this army is perfect for "Beer and pretzal" gamers. If you're looking for a laugh, than this army is just fine. They're certainly not the strongest army, they are considered to be in the lower tiers right now... but it will force your tactical skills to develop especially since the army can not do what you want it to do at times.
If like an army that you can control and focus... avoid them. If you like a challenge, but not a hopeless fight... they're good for that.
The other disadvantage is: They play a bit differently than other armies. While the tactical skill will carry over... it will feel very different.
Grade: C-/C
Skaven
They're due for an update soon. So I'd slowly get into them if you pick them as what is good now... might not be good with the new book (or vice versa)... or could be the same. Plus the new figures might be really cool.
This is a horde army. Otherwise read as: expensive. Which will make it harder to get into the game as it will be a bigger draw on your wallet, and frustrating if you find you don't like them.
Like Orcs, they are a bit of a Beer and Pretzals army. They have a lot of humor to them, and can be a quite a treat to play.
Tactically, with the *current* book (before the upcoming update) they do require an experienced general guiding them. This could change with the upcoming book, however.
I would recommend this army as a 2nd army or for experienced players. While I personally find them very cool and fun, they are not a beginners army.
Grade: F/D-
Tomb Kings
This army is a bit older, and most would agree in need of an update. While they are somewhat forgiving in that they are undead... this can be a liability against troops deadly in close combat as you can't raise figures to the same extent as Vampire Counts.
They are a bit of a finesse army, but can be made to work. However, I think an experienced general is needed for this. Magic, however, as long as you do it in the right order is very simple and perfectly reliable... but a knowledge player will be able to counter effectively.
Background wise, they are very easy to get into being based off Ancient Egypt.
The heirophant can be a bit of a liability.
The main advantage right now is... you can cross use a lot with Vampire Counts. If you theme your VC as Lahmian vampires and paint them/base them as being desert/Egyptian style... you can switch between the two. Letting you work on two armies at much less of cost (some units, however are hard to cross over). Skeletons, Tomb Guard, and Skeleton Horsemen are easy enough to cross use though.
Grade: D-... though if you cross use with VC... D+/C-
Vampire Counts
I'm not getting into the whole debate of who is nastier Vampires Counts or Demons of Chaos, as there is no true consensus. I will not even state my personal opinion on the matter. They have a wider variety to choose from than DoC is about all I will say.
Very forgiving being undead. They can allow for tactical mistakes and let you survive. They can get to be a horde with all the zombies, but this doesn't automatically make them expensive as unlike Skaven... you can have zombies/skeletons emerging from the grave (IE: A hand sticking out of the ground, etc). Basically, take all the spare bits you have and use them! You just need to buy bases, which are not that pricey.
They will be a magic heavy army, normally. They can be run with medium magic, but you're trending to a more elite/fighty army at that point.
The one thing you need to know about VC is the general is perhaps the single most important figure in your army. Keep him alive at all costs!
Grade: B+/A-
Warriors of Chaos
Very recently updated, meaning you will be able to get used to the rules. They have quite a bit of a variety in units, and the ability to give them upgrades via marks emphasizes this even more. They can be mobile, or based off infantry (marauder horde... or several solid Chaos Warrior blocks)
They're a very close combat orientated army. A few units let them develop their tactics (Spawn) fairly nicely, and some help with buffing the other units (War Shrine).
Overall decent leadership, and except for marauders... pretty solid in combat.
Disadvantage: No figures as of yet for the War Shrine or Forsaken! You will have to convert them up.
Grade: A
Wood Elves
A very mobile list. Not a lot of flexibility, but not terrible either. They rely a lot on shooting or maneuvering. For someone who is new, this is not the best combination. Their magic tends to be low as well.
Grade: C
I hope this helps figure out what army is better for beginners. This is intended as more of a general over view aimed at beginners.
I did not include Dogs of War, or Chaos Dwarfs (despite my liking both) for a large number of reasons including their questionable status of if they are allowed or not.
Record:
Chaos Dwarfs: Wins/Loss/Draw 20/13/7
Wastelanders (Chaos Space Marines): Wins/Loss/Draw 8/3/5
swissdictator is offline
post #2 of 8 (permalink) Old 06-24-09, 12:25 AM
Ascendant Valor's Flag is: USA
Well, at first I was confused and distraught at the idea, swissdictator. Then I realized you were putting this in the context of someone starting on Fantasy in general. Then it all clicked!
This would make 3 different methods for the lost and confused who are only entering Fantasy to get a grip! Squeek composed the "Checks and Balances" format, you just crafted this one, and then there's the Introduction to the Armies. If we could mold these three into a single method... This is to the point and succinct, the Intro is long and very informative, and Squeeks list is uber fast but is only good at making the initial selection. That's a hell of a combo!
In any case, good work! I'm sure any newbies swinging by this thread will appreciate it.
"In the eyes of the Elves of Ulthuan there exists no fear, only grim determination.
Until one has witnessed them in combat, one cannot comprehend the power that they possess."
Ascendant Valor is offline
post #3 of 8 (permalink) Old 06-24-09, 03:37 AM
keytag33's Avatar
keytag33's Flag is: Canada
Nice!! This should be really helpfull for all new players.
Virtutis gloria merces
The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at or repair. - Douglas Adams
It's a knife for gods sake, what you been useing to keep your fork company all these years, sharp side, blunt side, what you want a lesson? - Bullet Tooth Tony
keytag33 is offline
post #4 of 8 (permalink) Old 06-24-09, 09:44 PM
Ishamael's Avatar
Here's something I want some advice for, since I'm just starting this game. There is no doubt I'm doing Dwarves, so I would like to know how hardcore I should go into dispelling the enemy Magic Phase. I've only looked at the codex a little, but are there not Runes of dispelling, as well as dispel dice you get from Runesmiths?
Ishamael is offline
post #5 of 8 (permalink) Old 06-25-09, 12:41 PM
karlhunt's Avatar
karlhunt's Flag is: USA
Yes, you can get runes of dipelling.
As for how hard core you need to go for counterspelling, well that depends a lot on the points you are playing at and what you are up against. Under 1500 for sure your 4 dice should be good against any army that isn't built for magic. After that you need to start providing some kind of response. Now playing empire my response is to bring more troops, a spell can only kill so many at a time you know, but with dwarfs you have a harder time doing that. If you find that magic is really taking it's toll on your troops then pick up a runic standard with the Master Rune of Valaya. It's well and truly impressive. Asside from that, a rune priest with a rune of spell breaking or two should probably be taken every thousand points or so. Again, scale this according to what the enemy is using. Against DoC or VC your four dice will mean little to nothing.
C'mon, Click my Daemon. You know you want to.
karlhunt is offline
post #6 of 8 (permalink) Old 06-25-09, 02:14 PM
Cleitus_the_Black's Avatar
Cleitus_the_Black's Flag is: Canada
This is an awesome thread. I am just looking into Fantasy (again). I have old Bretonnian stuff, but I have fallen in love with Dwarf models... this thread made me rethink that idea (Skaven was the other army I was considering, time to start doing a little more considering).
Cleitus_the_Black is offline
post #7 of 8 (permalink) Old 06-26-09, 03:00 PM
Dafistofmork's Avatar
Dafistofmork's Flag is: United Kingdom
i always play a runesmith with the Master rune of balance (swaps 1 of your opponents PD to 1 of your DD) and a rune of spellbreaking (a dispell rune/scroll-thing)
this gives you 6 pd and a dispell scroll, usefull up to 1500pts vs all, and 2000pts vs magic light armies. magic heavy armies will give you a problem, but they are usaly lacking in something else, so can be beaten.
ps-its called an army book
humm, true. This is yet again proof the Orks are smarter the Elves.-Micklez
Dafistofmork is offline
post #8 of 8 (permalink) Old 07-02-09, 04:53 PM
MaidenManiac's Avatar
MaidenManiac's Flag is: Sweden
Nice job, but perhaps not to nessecary as shown below
This thread is done for this purpose
https://www.heresy-online.net/forums/...ad.php?t=20695
Happy reading folks
Win/Draw/Loss(5th ed results)
EC: 45/2/12
Tau: 28/3/7
Originally Posted by bitsandkits View Post
Common sense and wargamers are like oil and water
'Alessio is to 40k what impotence is to rape.' - Jezlad
MaidenManiac is offline
