Beastmen VS. Empire - Wargaming Forum and Wargamer Forums
post #1 of 6 (permalink) Old 11-09-11, 04:02 PM Thread Starter
stalarious's Avatar
stalarious's Flag is: Germany
Default Beastmen VS. Empire
OK so I have a game saturday that i will be playing against empire and its is my first time going against this player and against empire we are going to be running 2000pts and I was hoping I could get some tips and tricks that I should use/look out for.
All replies will be appreciated thanks.
So I am growing my enemy.....so what I gotta kill something.
CENTER][/CENTER]
stalarious is offline
post #2 of 6 (permalink) Old 11-09-11, 04:22 PM
Aramoro's Avatar
Guns...........thousands of them. Talisman of Dark Reign is not a bad idea.
Empire have a really strong magic defence so go big or go home. But take at least a Shadow or Death wizard to get Pit of Shade or Purple Sun so you can deal with Steam Tanks, so I would say go big.
They have Steam Tanks, so have a way to deal with them, a save or die or Heroic Killing Blow.
Always refuse Challenged from Arch Lectors on Popemobiles. They'll have Van Hosrtmans Speculum and beat you into paste.
Aramoro
"Violence isn't the answer, I just like getting it wrong on purpose"
Sally Forth! - My Gaming Blog
Aramoro is offline
post #3 of 6 (permalink) Old 11-09-11, 04:38 PM
Mad as a sack of Squigs
Ratvan's Avatar
Ratvan's Flag is: England
Aramoro has pointed out the main threats, AL on popemobile advice is golden.
Character wise - General and BSB are the leadership bubbles will be laid out with 1+ 4+ saves (BSB more than General)
If you see a lot of Warrior Priests he will be trying to go for mass dispel dice and shut your magic phase down.
Artillery - I'd be very very tempted to have a suicide ambush unit, keep it cheap and go for his artillery and\or missile troops. especially mortars they make a mess of hordes
Ratvan is offline
post #4 of 6 (permalink) Old 11-09-11, 05:24 PM
olderplayer's Flag is: USA
If designed right, this is a tough matchup for beastmen, especially if you go with a heavy magic/bray stone (shard of herdstone grants +1 power die for each wizard within 6") build. Since there is no rule on this shard, you can allow it to be of decent size and block line of sight to maximize its range and give you some protection (kind of cheezy but given your army's weaknesses usually overlooked as a necessary evil to allow your army a chance; often used to bunker the casters in a protected unit and let them cast out direct damage spells at range with the extra power dice generated). The mortars knock out your larger infantry blocks well before combat and the cannons can kill chariots, monstrous beasts, and larger model units and monster and monstrous units reliably with single shots. You may need to run small harpy units and/or ambushers to try to get across to take out war machines.
The beastman ambush rule is often too random and should have been FAQed to make it a bit more reliable and/or to allow certain skirmishers in your army to have the more normal ambush rule or to simply scout (such as raiders can be deployed as scouts with a minor additional points cost). Consider lots of small drops and target saturation techniques with units of razargors and harpies and maybe raiders (bait and flee) to try to get to the war machines and counter/redirect the threats as well.
Empire army has some unique rules and units.
Stream Tank. This has a toughness 10 (GW increased the T in an FAQ to make this hard to wound by most things out there), strength 10, and armour save of 1+ and is unbreakable. Thus, you need to shoot it or cast a spell at it (charisteristic tests of lore of death and shadow) that gets past the toughness and the armour save or simply tie it up with a unit that can take the hits. Attacks in combat with the steam tank automatically hit but must roll to wound and get past the armour save. The tank has ten wounds but can potentially wound itself if it by using steam points (if the up to 5 steam points chosen plus a D6 roll is equal to or greater than the steam tank's remaining wounds then the steam tank both suffers an unsaved wound and is unable to move or shoot or attack in combat that turn) to move (3" per steam point) or shoot (can even fire the cannon while in combat at models beyond the combat and potentially cause D3 S2 wounds to the the models in combat with the tank) or fight in combat (grinding attack). The tank uses steam points to move and charge (3" per steam point plus D3 impact hits per steam point on the charge) and fight in combat two ways (grinding attack once already in combat from before is D3 hits per steam point used for the attack and steam attack does S2 hits with no armour save on models touched by a flame template with the wider part touching the tank). Once it has a few wounds, the tank is nerfed unless it is willing to risk taking more wounds (The tank controller can simply avoid wounds by choosing zero steam points that turn.). The tank can also be wounded by dangerous terrain tests as a chariot, so make sure you have terrain and use it.
Arch lector. This lord model gives hatred to the unit he is in and can cast bounds spells (prayers of sigmar) to buff its unit and stuff and adds two dispel dice to the opponent's pool. He is often given a magic item "speculum" that allows the arch lector to swamp chosen characteristic stats (not magic items) in a challenge with an opposing model. The arch lector is not a good fighting character without the speculum. Also, this model is often on a war altar that is a chariot that gives a ward save, a bound spell, and other benefits to the arch lector and is unbreakable. This chariot can be wounded (dangerous terrain).
War Priests are basically hero-level arch lectors that give hatred to the units they are in, can fight in combat decently, get one prayer of sigmar bound spell, and give one dispel dice to the dispell dice pool in the defensive magic phase.
Core troops are so-so and just slightly over priced without buffed and use of detachments. Most commonly used are swordsmen (T3, S3, but +1 WS and armour and shields for a better armour save and parry save), halberdiers (+1 S on attacks but loss of shield) and handgunners (move or shoot weapon with S4 and AP shots, typically used to protect war machines). Spearmen are now used less often relative to swordmen and halberdiers. Core troops that are State Troops have a detachments system which allows a second or third unit of state troops, archers, or militia (often specialized like militia with two hand weapons) that can counter-charge a unit charging its parent unit into the flank and help with combat resolution if they are kept close to the parent unit. I do not see the detachment system used effectively most of the time when playing empire armies and often do not see handgunners or militia used as detachments.
Special troops are the great swords. They are basically like swordsmen but have plate armour (4+ AS), no shields, and great weapons so that they can hit hard but are somewhat overpriced relatively to the newer army books.
Rare troops are flagellants. Flagellants have low WS, have no armour, and are only S3, T3, I3 troops but they have flails (+2 S in the first round of combat), are unbreakable (you have to kill em), are frenzied, and can sacrifice models at the beginning of combat to gain hatred (D3 =1), hatred and re-roll to wound (D3=2), or hatred, re-roll to wound, and +1 CR (D3=3). This unit is limited to up to 30 models and can be included as core troops if you have a war priest or arch lector in the army.
Mounted cav are decent (fast cav with pistols, cav with handguns with move or shoot, and well-armoured knights with barded steeds) and the knights can be part of core.
Generals and captains (both S4, T4, WS 5) are so-so but have good armour saves and abilities to protect them with magic items for re-rolls of armour saves, ward saves, high armour save, etc. in their book.
A level 4 wizard with lore of life is pretty standard. Wizards have access to a magic item allowing unused power/dispel dice to be saved (up to 2) and carried over to the next magic phase. Lore of life is used for the ability to restore wounds, avoid damage from miscasts and boost toughness of a key unit (flesh to stone) and the best anti-horde/unit spell in Dwellers Below.
Most empire armies use war machines:
The great cannon has longer range and can be very reliable with an engineer in range (3") making it more reliable.
The mortar is a stone thrower with S3 hits but uses a large template and reduces the armour save of models wounded and is one of the best anti-unit weapons, especially with a master engineer within range.
A master engineer in range of the mortars and cannons can re-roll one scatter or artillery dice roll in the shooting phase for a cannon or mortar and, in 8th edition, gets a look out sir of 4+ if within 3" and can be in the war machine unit. Master engineers can also be equiped with repeater guns, pistols, sniper rifles, and some other goofy weapons (pigeon bombs) that they can use if and only if they did not use their re-roll abilities in the same shooting phase.
Less common are the rocket battery and volley gun which are both less reliable but occassionally can really rip up larger units.
olderplayer is offline
post #5 of 6 (permalink) Old 11-09-11, 06:06 PM
blackspine's Avatar
blackspine's Flag is: USA
vs empire you do have some legs up.
MANBANE: any Wargor or Beastlord in combat with any empire (or brett) forces gets to re-roll PF. this includes ANY units in same combat. Not huge, but helps if the BSB dissappears.
Steam-tank: take 35-40 ungors and shove it in the ST's face. they won't win, but they can hold it up for some time.
-or pit of shades the damn thing.
-do NOT let it get near your bestigors (or minos).
Artillery: Ironcurse icon in your best unit.
Raiders: units of 5-6 + musc. take 4 units and ambush w/ two.
Razorgors: never leave home w/ out it. These guys can do ANYTHING. take out gunlines. Assassinate Wizards ( you MUST), Take out WPs. They are str 6 on charge and T5. Most empire need 6's to wound it. 5s on good ones. Take them solo or run one behind the other in 2s.
take out the Fing mortars and Hellstorms first. These WMs are absurd.
Magic: Herdstone.
empire magic defense is second to dwarfs. With their wizards/ WP alive, they have crazy magic defense. Your razorpigs can take out wizards.
Razorpigs can't be challenged and can't be van-spec'd.
once their dispelling is gone, you're in a better place.
Bestigors will chew through most units. Make sure they have magic support. DO NOT place them against ST or Great Swords. better matched vs others. Knights, swordsmen, even halberdiers. Never ever ever vs Flagellents.
Gors, while I'm not digging them in most lists, are great vs empire. Run a steadfast block and take out his Sword masters with them. One wyssans and you'll win a battle of attrition.
with empire, it's about surviving the boring/ frustrating 3 rounds of getting to them. then it's about surrounding them. You want all fights, when they FINALLY occur, to happen on your terms w/ flanks, rears, ranks etc etc.
some scattered notes, hope it helps.
don't take minos vs empire gunlines.
The Doombull w/ 1+ As, re-roll strikeback is amazing vs greatswords. He'll chew them up. (just avoid van-spec)
Fury, Gore and Ruin
http://thenerdalsorises.wordpress.com/
-Beastmen 72-4-13
- Druchii 15-1-7 (rip)
- Rusted Ruin; WoC 25-3-8
- Chaos Dwarves: TBD
- Ogres: ?
blackspine is offline
post #6 of 6 (permalink) Old 11-09-11, 08:20 PM
blackspine's Avatar
Oh yes.
forgot about the Chalice of Dark Rain.
take it.
Round 2, when you might be in close range. use it.
Between this, the ungor raiders, Razorgors and harpies, you should be able to mitigate his shooting
Fury, Gore and Ruin
-Beastmen 72-4-13
- Ogres: ?
