What are the chances? - A look at 40K - Wargaming Forum and Wargamer Forums
post #1 of 7 (permalink) Old 03-18-09, 04:38 PM Thread Starter
Venderland101st's Avatar
Venderland101st's Flag is: United Kingdom
Default What are the chances? - A look at 40K
Not sure if anyone has looked at this before, but I was interested to find out so had a little look.
A quick background:
I play Imperials and my lad plays Space Marines. Always seems to me that the SM rip apart IG so much easier that IG rip SM, so I thought I would take a dig into the maths. I promise to keep the maths simple.
Simple scenario:
A SM shoots an IG with a bolter at long ranger and the IG is not in cover. A SM has BS 4 so needs a 3+ to hit (4 in 6 chance of hitting (4/6) or 67%). If the SM hits he then needs a 3+ to wound as the IG has toughness 3. Again 4 in 6 chance of wounding or 67%. The IG does not get a save against a bolter so the chance of a SM killing an IG is (4/6 * 4/6 * 100) or 44% chance of a kill.
When I worked it the other way around it did not look so jot for the IG.
A IG shoots a SM with a Las Gun, again at long range and SM not in cover. A IG has BS of 3 so needs a 4+ to hit ( 3 in 6 chance of hitting (3/6) or 50%). If the IG hits the SM he needs a 5+ to wound as a Las Gun is S 3 and the SM is T 4 (2 in 6 chance of wounding (2/6) or 33% chance). If the IG manages to wound the SM gets a 3+ armour save (4 in 6 (4/6) or 67% of saving). So the actual chance of an IG wounding the SM is (3/6 * 2/6 * 4/6 * 100) or 6% chance of a kill!
This is just some basic maths that I worked out, will work out how much better Twin Linked weapons are when I get time. Someone please correct me if I am wrong as it does not make for good reading. In case anyone is wondering, it works out you need 7 IG to have as much chance of a kill a 1 SM.
Let me know what you think.....
Venderland101st is offline
post #2 of 7 (permalink) Old 03-18-09, 04:57 PM
nightfish's Avatar
nightfish's Flag is: United Kingdom
I like this, gives a good perspective on the game working out the maths behind it.
Kinda shows the training between a gm space marine and a normal unmodified human.
nightfish is offline
post #3 of 7 (permalink) Old 03-18-09, 05:46 PM
It makes sense.
TheJackalMan is offline
post #4 of 7 (permalink) Old 03-18-09, 05:48 PM
Col. Schafer's Avatar
Yes that is true, but a leman russ can easily make its points back against space marines easy. And if you work out the maths for two to three squads of guardsmen vs a squad of SMs (about points I think) I bet things might come out diferently. Guardsmen with massed shots might pull the if we roll enughf sixes scenario and even out the odds.
"A true king is never alone, his will is equal to the will of all of his followers."
-Alexander the Great, kind of
Col. Schafer is offline
post #5 of 7 (permalink) Old 03-18-09, 05:59 PM
Sounds about right to me. Almost fluff-wise right too... hmmm. But yeah, you see the difference points wise, especially if the 4 points per guardsman rule becomes a reality and not a rumor in May.
xiawujing is offline
post #6 of 7 (permalink) Old 03-18-09, 06:06 PM
Check out my 'Method 216' it's a lot easier to calculate than what you did here, instructions are on my blog here http://mathhammer.blogspot.com/2009/...ethod-216.html
As for twin linked.
P(h) = probability of hitting
~P(h) = probability of NOT hitting i.e. [ 1 - P(h) ]
1 - power(1 - P(h), 2) = chance of hitting using twin linked
so for example twin linked that needs a 3+ to hit looks like this
1 - power(1 - 0.67, 2) = 0.89
NecronCowboy is offline
post #7 of 7 (permalink) Old 03-18-09, 06:09 PM
Also you have to look at most IG infantry are going to be in cover reducing the SM expectancy to 0.22 from 0.44, and the IG model costs 1/3 that of a SP, so that bumps up the IG expectancy to 0.17.
