The Battle Company - Wargaming Forum and Wargamer Forums
post #1 of 10 (permalink) Old 06-12-15, 05:29 PM Thread Starter
Rattlehead
MidnightSun's Avatar
Default The Battle Company
The formation that everyone’s talking about. Unless you live under a rock, you’ve probably seen the ideas being thrown around for getting 550pts of free Razorbacks and gunlining up. This is certainly an option – 90pts buys you 5 Tactical Marines with a Lascannon (Twin-Linked for a turn) and a Razorback with Twin-Linked Heavy Bolters with Objective Secured. That’s pretty crazy cheap for a long-range duo that can threaten tanks as well as infantry. 540pts will fill out your Company’s mandatory Tacticals with 6 5-man squads with Lascannons and 6 Razorbacks with TL Heavy Bolters. For the firepower and scoring presence that gives you, it’s good, but I think you’re wasting points in the regular berks with Bolters. I’d want to use those guys. To do that, the Razorbacks are probably going to need a weapon upgrade as they’re going to be up close and taking a more active role. While you do pay for any upgrades to the free transports, the Razorback upgrades are fairly cheap after they increased the base cost of the Razorback in 6th edition.
A 5-man Tactical Squad, Plasma Gun and Combi-Weapon in a Razorback with Twin-Linked Assault Cannon costs 115pts, which for the firepower you put out is actually a really solid deal considering the whole package is Objective Secured (and that Tactical Doctrine!). You could swap out the special weapons as you see fit, but I think the Assault Cannon is the way to go on the Razorback if you’re putting a short-ranged combat squad in it. A Razorback-based Company, for me, would look something like 3x 5 Tacticals with Plasma Gun/Combi-Weapon in a Razorback with TL Assault Cannon, 3x the same but with Meltas, 2 full Biker squads with the Captain attached to one and the Chaplain attached to the other, and then a pair of Devastator Squads with your weapon of choice in Razorbacks with Assault Cannons (these go ranging ahead of the Devastators, in the front line of Razorbacks). The best Chapter Tactic for this would have to be White Scars with Khan as the Captain – getting a Scout move with that many Razorbacks allows you to move 6” on the first turn, disembark and deliver a punishing alpha strike with your Tactical Doctrine supported by the blizzard of Str6 AP4 shots from the Razorbacks. Ultramarines can sustain an offensive with this build, given their two turns of Tactical Doctrine plus a turn of Devastator doctrine (as can, to a lesser extent, Imperial Fists with Bolter Drill), while other Chapters can make tailor it to suit their rules (Salamanders with Master-Crafted Combi-Weapons and Shredding Flamers in the Tactical squads, Iron Hands giving you some backup if the alpha strike doesn’t work, Raven Guard can… oh, Raven Guard, I am genuinely sorry).
So what about the 10-man squad? That’s fluffy, right? Indeed it is, and it has potential, but it really starts to cut into your points. Running all the Tacticals at 10-man, even with a fairly small amount of gear and frugal options in the other Demi-Company slots, is only leaving you only about 300pts or 400pts left for the other mandatory formation to make up a Gladius. 60 Tacticals with Plasma/Combis in Rhinos will set you back 990pts, which is significant, but that’s a lot of MEQ bodies and transport vehicles. You’ll Combat Squad them up unless it’s KP, because why would you not; that’s 18 Objective Secured units, plus all the OS you’ll get from the rest of the Battle Company (one of my favourite parts of the Battle Company is that your entire army has Objective Secured and Combat Squads – you can have OS Bikers, Tacticals, Biker Chapter Masters, Attack Bikes or Dreadnoughts, all in the same detachment!). Target saturation is a very real strategy, and this army has the benefit of being able to play the mission or kill the enemy as required; that much rapid OS MSU can cover a lot of table with Scoring, but they can unleash an awful lot of Twin-Linked Bolters and Special Weapons when required.
The final option is to mount the Tacticals in Drop Pods. Everyone knows what Drop Pods do, and I don’t think I need to explain the strengths of dropping down 50 Twin-Linked Tactical Marines on Turn 1 (since you can get free Drop Pods for your Assault Squads and Devastators even if they don’t use them, you bring all the Tacticals down turn 1, pop Tactical Doctrine, and bring everyone else in gradually). This is one situation where Captain Sicarius is actually a pretty good pick – you need a Captain anyway and if you’re committing to a Drop Pod Assault you’re probably not bringing Bikers, so one who lets your Drop Pods enter on a 2+ is about as good as you’re going to get. There's an army weakness that some people don't realise with Drop Pods, and while it's minor it's still present; you telegraph your plan. You can dp a really nasty alpha strike with Drop Pods, but you can't do anything other than a nasty alpha strike even if you might want to play less aggressively against a certain opponent.
A note that all of the configurations for the Battle Company leave you in a bit of a quandary as to what to do with the Captain and Chaplain. Foot Captains have no good units to join, and the Battle Company is expensive enough already without adding Biker Command Squads. However, I think that the latter is one of the better places to put the characters – a Captain and Chaplain offer some valuable melee defence for an otherwise melee-vulnerable shooting-based Command Squad such as the Apothecary/4 Grav Guns loadout. Alternatively, you can stick the characters into regular Biker squads, which fill your mandatory ‘Assault Marine’ slot, and again offer melee defence. One amusing alternative is a Captain with Artificer Armour, Storm Shield and the Primarch’s Wrath relic, which apart from being an odd model would gain Relentless from a squad of Centurion Devastators (which you can take as your ‘Devastator slot’), and in return give them 3 Storm Shield wounds to stand out front and take low-AP fire coming in. Bring White Scars for Hit and Run for added points.
MidnightSun is offline
post #2 of 10 (permalink) Old 06-12-15, 11:37 PM
Closet Dictator
Old Man78's Avatar
Old Man78's Flag is: Ireland
Nice write up again, you have assuaged my fears about this dex
Old Man78 is offline
post #3 of 10 (permalink) Old 06-13-15, 12:00 AM Thread Starter
Rattlehead
Thanks
I get the problem that a lot of people seem to have with this Dex in that it's similar to the old one - too much so for a new Codex for £35 to be justified. I disagree, thinking there's an awful lot of small changes that add up to really rather big changes, but most importantly I will state that in my view, Codex: Space Marines is unequivocally the best 7th edition release. Is it going to be as easy to play as Eldar Scatterpacks/Destoyer Weapons or Necron Decurions? No. But it has truly excellent internal balances, and so much unit synergy or at least unit competition that will allow it to fight those aforementioned Codexes. Take the Space Marine assault troops - in the past, Hammernators have been what you bring, pretty much without question. Now? Vanguard, Honour Guard and Terminators are all vying for a spot, each bringing something unique and powerful in it's way to the table.
Note: for the people who are wondering how you beat Necron Decurion or Eldar with the new Space Marines, my as-yet-untested first theories are to beat the Decurion by running away screaming like a little girl for the first few turns, then bum-rushing the objectives with the preposterous amount of Objective Secured that Space Marines can have on 12"+ movement platforms; beating Eldar is much the same, but you have to alpha strike their Troops first to stop them sitting their own Objective Secured dudes on the points to stop you from taking them. Fortunately, this is often going to be Guardians (who die badly to Tactical Doctrine-sporting Tactical Marines) or Jetbikes (who are as hard to kill as regular Marines, and the destruction of which will also give you huge survivability increases, perhaps even to the extent that the Eldar literally do not have enough bullets to stop all your dudes). The new book, wit the proliferation of Objective Secured, really capitalises on the thing Marines have always been really good at - the last scraps of the game, where you've fought to basically mutually assured destruction and neither side has much of anything left to fight with.
post #4 of 10 (permalink) Old 06-13-15, 02:57 AM
tu_shan82's Avatar
tu_shan82's Flag is: Australia
if youre allowed to use FW stuff then you could take infernum pattern razors, and because the melta is part of the tanks basic wargear rather than an upgrade you get it for free. put a six man tac squad w a flamer and combi flamer each w sallies tactics and vulkan and then you've got a good little force with both anti hoarde and anti tank capabilities. Ad some mm attack bikes or flamer ass squads, devs equiped to deal with whatever opponent youre facing and then ad whatever formations you want.
Originally Posted by Varakir View Post
We don't need to use any military force to defeat the imperium, we'll just send GW legal at them. As soon as they see the first sign of a thunderhawk gunship, their IP infringement addled brains will go into meltdown - they'll smash everything out of the sky with cease and desist letters.
tu_shan82 is offline
post #5 of 10 (permalink) Old 06-13-15, 09:30 AM
mayegelt's Avatar
I personally despair at this codex with its free stuff bonanza paired with tier after tier of bonus rules. To me it seems like to much. Adding on top cheaper termys and dreads who are now A4 with no points increase, I am seriously wondering if GW has asked the guys to just throw together rules that sound cool without playtesting or checkimg to do comparison work with other codex recently done (I'm looking at you daemonkin with your now way overcost termys and helbrute/dreadnaught with only 2 attacks...)
The major thing that concerns me will be if daemonkin tzeentch will follow the style and points of khorne, or will it have the better brutes and cheeper termys like marines. Either way chaos players are pissed off. If tzeentch gets the new treatment then khorne players are unhappy about the overcost dex. If tzeentch doesnt then all of the chaos ones are confirmed (not that they were in a great shape before) as garbage.
If this is the new trend then they may as well do away with the points system :S
mayegelt is offline
post #6 of 10 (permalink) Old 06-13-15, 09:36 AM
Vaz
Vaz's Avatar
Vaz's Flag is: United Kingdom
An infernum pattern razorback is not a razorback in rule parlance. No, it wouldn't count.
As a Chaos Player, sure you're pissed off, but you have every right to be pissed off as your book was absolute dogshite. As a Space Marine player, that Space Marines are now able to play at the same table as Necrons and Eldar makes me very happy, and especially now that SM are able to be as broken as people have wrongly claimed they are for the last 15 years makes me happy.
Vaz is offline
post #7 of 10 (permalink) Old 06-13-15, 10:00 AM
tu_shan82's Avatar
Ah well not to worry, you could do it in reverse and upgrade the razors to have heavy flamers, and give the squad meltaguns instead. But it does work out a little bit more pricey.
I'm also very pissed of as a blood angels player, lol.
post #8 of 10 (permalink) Old 06-13-15, 11:51 AM
Vaz
Vaz's Avatar
I've always been an advocate of folding SW, BA, BT, and DA into C:SM. I mean, now, it's perfect design for the design company to make a Sentinels of Terra/Clan Raukaan style update booklet to the C:SM,
Vaz is offline
post #9 of 10 (permalink) Old 06-13-15, 12:08 PM
tu_shan82's Avatar
I wouldn't fold SW as the only thing they've really got in common with SM are the tanks, but I'd be happy with 3rd Ed style codexes for BA and DA (I play both, as well SW and Sallies) provided that they were the same size and quality as Sentinels/Raukaan.
post #10 of 10 (permalink) Old 06-13-15, 12:49 PM Thread Starter
Rattlehead
I think that DA, BA and SW all have too many unique units and traits to be folded in to Codex: Space Marines now, to be honest. Maybe a couple of editions ago, but no longer.
