Does 40k need new rules for Tournaments? - Page 8 - Wargaming Forum and Wargamer Forums
post #71 of 83 (permalink) Old 12-14-13, 04:16 AM
Wusword77's Avatar
Wusword77's Flag is: USA
Originally Posted by Lord_Aaron View Post
I totally agree. ;)
That's why I suggested 0-1 everything except troops. Your at the bottom of the slope, and it's "fair" to each army.
It doesn't solve everything, and there are other problems with it, but I'm still working on it ;)
Restricting any unit for a game like 40K doesn't work because, unlike something like MTG, you have a very limited amount of resources to make an army out of. Restricting cards in MTG doesn't mean asmuch because there are thousands of cards you can still construct a deck from, in 40K and FB you a limited to the 20 or so units presented in the codex. Restricting that one unit could hurt your codex quite a bit.
Units are "balanced" (a loose term in this case) based off the rules presented in the codex. To modify those rules reduces the effectiveness of said units to the point where they may not really be worth it to even play.
Think about it. A trio of Heldrakes are a badass team that will ruin another players day. Making a rule that the player can only take one makes his Heldrake a much bigger risk, as it will still be a huge target but can't produce the same results without it's team. The question then becomes is it worth the points or am I better off running an additional unit of X.
Wusword77 is offline
post #72 of 83 (permalink) Old 12-14-13, 06:37 AM
Lord_Aaron's Avatar
Lord_Aaron's Flag is: USA
Actually, there is no "balance" - no matter how loosely you use the term.
Yes, the heldrake is badass. Yes, one will probably get shot down. But it's /so/ badass that, as MidnightSun said, the fast attack slot is "the heldrake slot". There are 5 fast attack choices in the chaos codex, all relatively good. But the heldrake is miles above the other 4. The other 4 don't get used in the highest levels of tournament play.
On top of that, the existence of the Heldrake with baleflamers basically maked some armies unsuitable for tournament play. Just ask Sethis.
Edit: in hindsight, I might be getting my threads mixed up. :p
There's another similar thread
Lord_Aaron is offline
post #73 of 83 (permalink) Old 12-14-13, 07:58 AM
Kecyre's Avatar
Kecyre's Flag is: USA
Someone said Microsoft and Apple don't have forums? They in fact do. You can get to Apple forums via support and Microsoft has always had Technet.
My only complaint is the prices of digital codex. They should have really passed off the money they save from printing.
Kecyre is offline
post #74 of 83 (permalink) Old 12-14-13, 01:13 PM
Ryu_Niimura's Avatar
Ryu_Niimura's Flag is: Netherlands
Wow mate, what have you been smoking? I think you took a wrong turn somewhere along the way.
Also with the new FW release I don't think 3 Helldrakes are going to be a problem, or Screamer star for that matter
Ryu_Niimura is offline
post #75 of 83 (permalink) Old 12-14-13, 04:05 PM Thread Starter
Token Trans Mod
Zion's Avatar
Zion's Flag is: USA
Tech support forums are not the same as the kind of fan forums people want GW to have.
Also, the digital codexes include the cost of the continued support (IT for the server, cost of server upkeep, the free updates they do instead of charging you for a new one when something changes, ect).
It's all packaged into the costs and thus GW can afford to do it.
Zion is offline
post #76 of 83 (permalink) Old 12-15-13, 02:53 AM
Kecyre's Avatar
No, those are Apple servers hosting it. Even with a cut apple takes it's far more than it should be.
Kecyre is offline
post #77 of 83 (permalink) Old 12-15-13, 05:16 AM
Lord_Aaron's Avatar
Let's try to leave the price complaints for another thread please.
post #78 of 83 (permalink) Old 12-15-13, 08:59 AM Thread Starter
Token Trans Mod
Zion's Avatar
Zion's Flag is: USA
You're talking about iTunes, but GW also hosts them on the Black Library site with the .mobi and .epub versions. That's why they're only a little cheaper than the interactive ones from iTunes (which need a lot more work to setup and make sure it's all cross linked correctly and the like).
Zion is offline
post #79 of 83 (permalink) Old 12-15-13, 10:26 AM
Sethis's Avatar
Well given that the ally matrix allows everyone to ally with at least two other armies barring Tyranids, that might not be entirely correct. Consider:
In any given MTG tournament, you are restricted to a selection of cards from the many thousands available (let's assume you're playing Standard Constructed). Some of those may be banned. Most of them will not work in your deck archetype (almost all aggro cards are useless for a control deck, for example), and anywhere between half and two thirds will not fit in because of colour restrictions (with tri-colour being the most you can realistically build a tournament worthy deck from). Of those cards that match both colour and archetype that are currently in Standard, something in the region of 60% of those will be jank that have no place in a tournament deck.
Thus your pool of "potentially useful" cards that you can consider adding to your deck is often in the low tens, rather than hundreds range.
Compare that to the Space Marine codex, which has (at last count) 54 individual units in it, and suddenly the comparison doesn't look so wildly different, especially when you add in the fact that they are Battle Brothers with Blood Angels (41), Space Wolves (33), Dark Angels (34), Imperial Guard (45) and Tau (25) to give a grand total of 232 seperate units (not including upgrade characters like Telion) and that's not even considering Allies of Convenience/Desperation.
Obviously there is some overlap between codices (Tac squads are basically the same, no matter which book they come from) and there are also some terrible units in each codex, but we haven't even looked at Fortifications, Forgeworld or Apocalypse yet.
Therefore, even if some tournaments end up banning certain units (so far we've got a list of, what, 3-4 units and a wargear item?) there are *plenty* still left to choose from.
Sethis is offline
post #80 of 83 (permalink) Old 12-15-13, 04:17 PM
Wusword77's Avatar
The same idea can be applied to 40K however. If you want to play a specific type of army (say bikes) you will be limiting your self to specific types of units, much like how you be limited by the deck type you wanna play in MTG. Allies function as colors, as you will be looking for the units in the allied books to complement your deck, and you are limited by the number of "good" units that will be used in a dex as some units are just bad. Of course you can still take whatever units you want in 40K, just like you can run 5 colors in MtG, but it would reduce the overall effectiveness of your list (at least depending on MtG block or rule set).
Your actual choices for your list are just a limited, if not more so, then in Magic.
Many tournaments already ban Forgeworld/Apoc and have imposed restrictions on Fortifications. Imposing more restrictions on players just further limits options and what lists will show up at any given Tournament.
