Scratch built jet engine plan (from my scratch built thunderbolt.) - Wargaming Forum and Wargamer Forums
post #1 of 6 (permalink) Old 01-06-13, 10:38 PM Thread Starter
Maverike Prime's Avatar
Maverike Prime's Flag is: USA
Default Scratch built jet engine plan (from my scratch built thunderbolt.)
Greetings Heretics! Been a great while since I posted here. Life has been... well life. Anyway, I've been working on a scratch build for a while, but I've encountered a bit of a delay: namely I have to wait for the supplies I ordered to show up. But I've been getting lots of questions about how I went about scratch building the engine parts that I have so far. So I decided to post information about the process and how I did it. Perhaps it will clear up some fog of mystery you have for a project or something.
So Scratch building engines. First thing to remember is we're not building working functional engines. We are attaching hunks of plastic together in such a way that it looks like it could be an engine or machine if it weren't just hunks of plastic glued together. What am I talking about? Simple.
This is not an engine. It is several pieces of plastic put together to present the image of an engine. So how do we build this facsimile of an engine? Simple, we break it down into smaller and simpler components.
Here is a structural break down of what I used to build the engine master:
Because I will be referring to different sizes, I have color coded this passage to match with the diagram. The green tube is a length of Plastruct's TB-24 piping, which is measured at 19mm outside diameter. The pink is TB-28 tubing and measures at 22mm. The blue, which slips around the forward most length of TB-28, is a segment of TB-32 and is the largest piece of Plastructs inventory of piping I've needed to order yet. It measures in at 25mm outer diameter. The sea foam green 'C' is a wrap of textured plastic from EverGreen's assortment. The precise one I used in this case is listed as E-5 '4529' "Metal Siding" and is sold in sheets of 100 square inches. Apply a little bit of heat and it becomes pliable and can simply be glued into the length of TB-28.
The floating yellow squares are just panels of .5mm thick styrene I cut and glued to the last section of exposed TB-24. The teal length between the segments of TB-28 are simply lengths of 1mm thick Hex-rod. Plastruct's got these listed as MRX-60. I also got .1mm lengths of these hex rods to become the bolts on the sides of the engine you see in the finished product.
And that's the breakdown of how I built the master for the back half of the engine.
The forward intake was a similar process but needed some innovation to accomplish.
Like with the back section of the engine the intake housing is built out of 2 lengths of pipe set into one another. The inner section, shown in pink is a length of TB-28 while the blue is a length of TB-32. The red is a disc of 1mm thick sheet styrene. For the intake blades I had to get creative. I make 4 discs of .1mm thick styrene, the same diameter as the inside of the TB-28. I then cut those dics into 8 segments, like a pizza. Then I glued down each blade separately so that each successive blade was over half of the previous one. I had to get a little fiddly with the last two or three in order to get them to line up properly but it worked out. Then I took a hold punch that measured just under 5mm in diameter and punched out the center of the assembled fan blades.
I then took a length of Plastruct's MR-190 5mm rod and sanded one end down to a rounded nub and then put that through the hole I made in the fan blades. To help simplify it all out I attached a scrap piece of styrene to back of the .1mm disc.
And that about covers the process I went through scratch building these two components for a Thunderbolt I'm building. To see more of my work on this particular project you can check out my blog linked in my signature below.
Be Sure to follow me on:
Maverike Prime is offline
post #2 of 6 (permalink) Old 01-07-13, 06:15 AM
Sangus Bane's Avatar
Sangus Bane's Flag is: Netherlands
Not bad... Impressive, actually.
But it would be even more impressive if it was an actual engine, just saying. ;)
Also, great work on the tutorial, easy and clear: thats the way I like my tutorials.
I would like to see more of that Thunderbolt.
212218457911619812520750614
Please have a look at my space marines.
Lord Bane says: "Keep your water bill low, drink more beer!"
My girlfriend said she didn't like Daft Punk. She's single now. Hahahahahaha lol, just kidding. She's dead...
Sangus Bane is offline
post #3 of 6 (permalink) Old 01-07-13, 09:44 AM
Tzeentch laughs at likely
Dave T Hobbit's Avatar
Dave T Hobbit is offline
post #4 of 6 (permalink) Old 01-07-13, 12:57 PM Thread Starter
Hmm, I suppose I could just stick some model rocket engine into tubes and build the detail around that. 'Cept those engines don't generate much in the way of lift. And this bird is already getting heavy.
you can see the work I've done on the thunderbolt thus far on my blog. It's linked in my signature. For the moment my work on it is stalled because I'm waiting for materials I've ordered to arrive. One of the things, one of the... okay one of the like 12 things, I'm doing with this project is learning how to cast in resin. Building the thunderbolt is another step I'm taking toward building a Thunderhawk. In the case of the thunderbolt rather then build 2 engines, 2 intakes, 4 autocannons and 2 lascannons, I'm going to build 1 of each and then cast copies of them in resin. Little difficult to do that when you're almost out of resin and am out of mold compound. So I have to wait for the supplies of both I've ordered to come in.
post #5 of 6 (permalink) Old 01-07-13, 04:08 PM
Powered by Squig Tea
Viscount Vash's Avatar
I popped this into Tutorials as it will get lost in the general melee of M&P
Very nice engine plan and will be of great use to someone trying to build up their very own jet turbine.
Viscount Vash is offline
post #6 of 6 (permalink) Old 01-15-13, 06:53 AM
Innovative Forge-Lord
Cypher871's Avatar
Cypher871's Flag is: England
Cypher871 is offline
