Skimmers and flying bases - Wargaming Forum and Wargamer Forums
post #1 of 9 (permalink) Old 05-12-11, 05:34 PM Thread Starter
Nectar of the Gods!
shampawnya's Avatar
shampawnya's Flag is: Canada
Default Skimmers and flying bases
Okay here's an interesting one... For models like Valkaries and Stormravens that have large flying bases... Are they suppose to remain on their bases or are you suppose to put the model itself on the table with no base... The BRB says (p71) The skimmer must be set down on the table and left in place at the end of it's move - it cannot be left hovering in midair... Is this on the base or no base...
Obviously if it was left on it's base it's very hard to keep these suckers in cover... But at the same time the BRB as says that embarking units measure 2" from the base...
Hopefully you guys see my confusion and can help. Thanks in advance!
shampawnya is offline
post #2 of 9 (permalink) Old 05-12-11, 05:37 PM
laviathan13089's Avatar
laviathan13089's Flag is: USA
i thought the rulebook stated that models should never be removed from their bases, even if immobilized...
laviathan13089 is offline
post #3 of 9 (permalink) Old 05-12-11, 05:45 PM
KhainiteAssassin's Avatar
te BRB ruling of must be set down on the table is referring to people trying to lift the model up to an infinite height in order to fire through what would otherwise impede LOS.
IE: I put one of my ravagers behind a wall but "move it up" in order to see over the wall.
The rule is meaning that the BASE has to be on the table. get it now?
WIPS: CHECK THEM OUT!
My armies.
KhainiteAssassin is offline
post #4 of 9 (permalink) Old 05-12-11, 06:17 PM Thread Starter
Nectar of the Gods!
shampawnya's Avatar
Boo... Not the answer I was hoping for, but does end my confusion... Thanks guys
post #5 of 9 (permalink) Old 05-12-11, 06:54 PM
Jeep's and Harley's
OIIIIIIO's Avatar
OIIIIIIO's Flag is: USA
Khainite has the right of it, also the base must be removed, if possible, if the skimmer becomes immobilized.
OIIIIIIO is offline
post #6 of 9 (permalink) Old 05-12-11, 07:09 PM
Salahaldin's Avatar
Salahaldin's Flag is: Canada
As for passengers disembarking, I just measure 2" from the entry points looking straight down at the vehicle, then place the passengers at the corresponding spot on the ground.
"Trying to make some sense of it all,
When I can see it makes no sense at all"
"Fools to the left of me,
Jokers to the right,
Here I am,
Stuck in the middle with you."
Salahaldin is offline
post #7 of 9 (permalink) Old 05-12-11, 07:39 PM
Jeep's and Harley's
OIIIIIIO's Avatar
Depends on the rules for the specific skimmer.
The Storm Raven rules say anywhere within two inches of the base. So you could have a dreadnought unload up to two inches away from the front of the Storm Raven. Not sure about the wording on the other skimmer as I do not run them.
OIIIIIIO is offline
post #8 of 9 (permalink) Old 05-12-11, 08:31 PM
Terabyt3's Avatar
Terabyt3's Flag is: United Kingdom
Eldar tanks are 2" from access points. So it's rear.... (there's a joke there somewhere)
Terabyt3 is offline
post #9 of 9 (permalink) Old 05-12-11, 10:45 PM
Azrell's Avatar
Azrell's Flag is: USA
who's there?.... wait wrong joke?
It takes a pack of Wolves to tree a Lion... here is hopping the new DA codex reflects that.
Azrell is offline
