counter attack & tank shock - Wargaming Forum and Wargamer Forums
post #1 of 7 (permalink) Old 03-26-08, 05:55 PM Thread Starter
Default counter attack & tank shock
Tank shock:
In the last game i played I tank shocked my opponent's marine squad successfully killing the leader trying to death-or-glory. So the unit gave way -- my opponent moved his models in a large curve around the path of my vehicle. Some were in front, and some he pushed off to the side, giving them all nearly 2" between each other. The end result was the squad had become a foot long curve with near max 2" between each model.
Since tank shock says "they must be moved out of the way by the SHORTEST distance" doesn't this rule out being able to move some people in front of the skimmer, some to the side, some still behind it, spaced out so much? The whole goal of my tank shock was to achieve some clumping-up.
Counter Attack:
So I have my opponent's marine squad (Bloodclaws with counter attack) sandwiched between a unit of Harlequins and a unit of Howling Banshees (yes fun). I want to hit them with both harlequins and banshees in the same assault, so I moved banshees forward not even 2" before my opponent charges the Marines at them in counter-attack, taking them out of charge range of my harlequins. Is this correct?
Furthermore if this is correct, pretend that my harlequins are still in charge range, and charge the backsides of the counter-attacking marines. Are they still subject to counterattack (i.e. losing the attack for charging)? Intuitively I would think No because a unit can't countercharge in two directions.
thanks in advance guys
Absolute035 is offline
post #2 of 7 (permalink) Old 03-26-08, 06:15 PM
yes the 2nd one is correct.
but you don't loose your attack bonus for charging
conuter attack = acrobatics for banchees
FarseerNo3 is offline
post #3 of 7 (permalink) Old 03-26-08, 10:15 PM
Bogg's Avatar
Bogg's Flag is: Norway
well, to the first one, you have to move your entire squad to 1 side of the vehicle. all og them in a pile..
on the second .....you move all your charging units first,(harlys and banshees) then after you are done, he can move those not in base contact, up to 6" to get them all in BTB, he does not get the bonus for charging tho..
Orks - Salamanders - IG -Tau - Necron - Csm - Nids - Dark Eldar
Bogg is offline
post #4 of 7 (permalink) Old 03-26-08, 10:23 PM Thread Starter
Tank shock: So tank shocking should force the squad to move off to the side of the tank, and each model will move as little as it can to get out of the way, resulting in a clump.
Counter attack: this is what i had thought, i move all my units that want to assault in B2B first and THEN his unengaged models can counterattack. My opponent however, used the rule to shove his squad out of charge range of my harlequins, saying he gets to move them "in response" to me moving my banshees first.
Counterattacking models get no charge bonus, and my units charging them still do. Well that fight would have went even better for me if i had known this. Thanks all.
post #5 of 7 (permalink) Old 03-26-08, 10:26 PM
Bogg's Avatar
hmm, didnt he fail his Death or Glory?, they should be running i think, and if they are 6" to the vehicle, they keep running, so escort them out of the table....You win!
Not to sure about that 1, tho, cause I never tank shock,
Bogg is offline
post #6 of 7 (permalink) Old 03-27-08, 12:28 AM
if he doe a death or glory it means he passed his ld test so he does not run, but you need to move the models to a safe place the SHORTEST DISTANCE POSSIBLE.
so there may be a time when the models will surround the vehicle
exxample, you tank shock a large unit of orcs, they are fearless so they don't run, but you will drive your tank into the middle of them, and they will shuffel to either side, which ever is closest.
note that it is possible to sometimes breakup squad coherancy by tank shocking.
Nykster is offline
post #7 of 7 (permalink) Old 03-27-08, 02:09 AM Thread Starter
it was my intention to move my vehicle in such a way as to clump his entire squad off to the side. Because I was about to hit them with a 6-3 template from my fireprisms.
