Mind in the Machine - Wargaming Forum and Wargamer Forums
post #1 of 11 (permalink) Old 11-15-11, 10:44 PM Thread Starter
capnmoe's Avatar
capnmoe's Flag is: USA
Default Mind in the Machine
This is one of Anrakyr the Traveller's new abilities. I just want to make sure I'm reading this correctly. The vehicle cannot alter its facing, and fires as if it had not moved. Am I to assume that this means I can fire all of its weapons now since it will be treated as not having moved? Or can I only fire 1? And also would I be able to shoot Anrakyrs Tachyon Arrow or Command Barge gun regularly after using this ability? If so I'm putting this guy in a command barge and boosting>doing Sweep Attacks>Doing Mind in the Machine Attacks>Disembarking>Command Barge gun attacks>Tachyon Arrow attack> and then possibly assaulting all in the same turn? Also would all these attacks have to be against the same unit?
capnmoe is offline
post #2 of 11 (permalink) Old 11-15-11, 11:00 PM
lokis222's Avatar
lokis222's Flag is: Canada
As far as I can tell, you shoot all guns (not moving) and it is not a shooting attack, so you still get your shooting phase. From reading, you don't even get to choose to do it, it just happens.
Edit: The command barge guns are not linked to the characters guns. And the order would be: command barge and boosting>doing Sweep Attacks>Disembarking>Doing Mind in the Machine Attacks>Command Barge gun attacks>Tachyon Arrow attack> and then possibly assaulting all in the same turn, but I am not sure you can boost and disembark. Also, you always have to assault the unit you shot at.
lokis222 is offline
post #3 of 11 (permalink) Old 11-15-11, 11:24 PM Thread Starter
capnmoe's Avatar
You're correct about boosting and disembarking. I had forgotten about that. However, I could still do this at cruising speed.
capnmoe is offline
post #4 of 11 (permalink) Old 11-15-11, 11:39 PM
lokis222's Avatar
As I read it, yes. The issue with the tacheyon arrow is that you would have to assault the same target. Other than that you should be fine.
lokis222 is offline
post #5 of 11 (permalink) Old 11-15-11, 11:45 PM
Klaivex's Avatar
Simplest solution is to kill the vehicle you just took over so it can't retaliate. Between the tachion arrow, furious charge, and a warsythe, he is one of the best tank busters the necrons have. Basicaly a living meltabomb in CC if he gets the charge.
Klaivex is offline
post #6 of 11 (permalink) Old 11-16-11, 12:16 PM
Ravner298's Avatar
Ravner298's Flag is: USA
not to mention his potential in apocalypse games.
Ravner298 is offline
post #7 of 11 (permalink) Old 11-16-11, 12:35 PM
Aramoro's Avatar
He is hilarious in Apoc but going to get blown away first chance someone gets before their Titan goes rogue.
Aramoro
"Violence isn't the answer, I just like getting it wrong on purpose"
Sally Forth! - My Gaming Blog
Aramoro is offline
post #8 of 11 (permalink) Old 11-16-11, 12:44 PM
Ravner298's Avatar
Yeah. People need to play him in apoc while the codex is still new and most don't know what exactly he is capable of.
post #9 of 11 (permalink) Old 11-16-11, 12:56 PM
Senior Moderator
DeathKlokk's Avatar
DeathKlokk's Flag is: USA
I can just see a Reaver Titan blasting away at him frantically like a woman on a chair afraid of a mouse!
"EEEEEECK!! It's Anrakyr!"
Strange, but not a Stranger.
DeathKlokk is offline
post #10 of 11 (permalink) Old 11-16-11, 01:37 PM
Aramoro's Avatar
Anrakyr natrual prey is clearly the Titan or Deathstrike Launcher, I mean yes it's hard to fire the Deathstrike but worth it if you succeed.
Aramoro
Aramoro is offline
